(Topic ID: 269989)
the best Corsair pinball
By corsairflipper
1 year ago
  • 5 posts
  • 2 Pinsiders participating
  • Latest reply 1 year ago by MarkG
#1 1 year ago
Hello, brought again a topic with some video about THE best corsair pinball problem with Points floating long time before reach zero, and in game points goes up to the max or million too fast. And final when it get too much points or warms up it ends to buzz constantly and not making any more chime sound.
Some video (unfortunally not good quality cause camera micro usb plug broke and used a cheap one).
At start, points keep on long before zeroing
View of circuit
constant buzz, at the chime, after many points or like a game of 30 minutes it start like that.
#2 1 year ago
Have you ever seen this game work properly? I think there are several problems here.
First it looks like the 1000 point score reel has a hard time resetting because it doesn't recognize when it has reached zero. Instead of stopping at zero it seems to roll past it several times before the game recognizes the zero and stops. There is likely a stack of three switches mounted on the score reel assembly. One of those switches should open when the score reel is at zero to prevent it from advancing any further during reset. Another of those switches should close when the score reel is at zero to tell the game that it has finished resetting. Both of those may be dirty or in need of adjustment. If you're not familiar with these switches unplug the game and advance the score reel manually by pushing the plunger into the solenoid. Watch the switches as they open and close. Do the same with a working score reel and compare the two.
It also looks like the 10,000 point score reel starts up occasionally during reset after it has reached zero but this may be better addressed once the 1000 point score reel is working properly.
Finally it looks like the Ball Count step unit isn't resetting properly once the score reels reach zero. This may just be a mechanical issue due to built up dirt an hardened grease. If you unplug the game you should be able to test the Ball Count and other step units manually. For each solenoid on the step unit push the plunger all the way in and let it go. The step unit should smoothly step forward or backward and the wipers should come to rest directly above some of the contacts on the contact board. Any hesitation in the wipers, or stopping off center or between contacts may indicate that the step unit needs to be cleaned.
/Mark
#3 1 year ago
The L relay is for the 100,000
#4 1 year ago
#5 1 year ago
If there is a 5000 point target there is also probably a 5000 point relay and a 1000 point relay. What usually happens is that when a 5000 point target is hit the 5000 point relay fires which closes a switch to start the Score Motor. The 5000 point relay stays active as the Score Motor turns through 1/3 of a revolution or 120 degrees. As the Score Motor turns, the 1000 point relay should fire briefly five times to send five pulses to the 1000 point score reel and five pulses to the 1000 point chime. At the end of the 1/3 revolution the 5000 point relay should relax and the Score Motor should stop.
Given that your chime is stuck on but your Score Motor has stopped, I suspect that either the 1000 point relay is stuck on, or that the switch for the 1000 point chime on the 1000 point relay is closed somehow.
