(Topic ID: 228691)
The Beatles - Beatlemania official owners and fan club!
By Psw757
  • 2,023 posts
  • 230 Pinsiders participating
  • Latest reply 8 days ago by scottieIA
  • Topic is favorited by 95 Pinsiders
There are 2,023 posts in this topic. You are on page 39 of 41.
#1901 4 months ago
Quoted from Speck:
Wondering if anyone has a fix. Occasionally the ball bounces off of the “four” targets when hit hard. I tried tightening the springs by shortening by a few rungs but no luck. I could remove the drop target bank to clean everything up but I’m reluctant to take it apart.
If you call Stern they will send you the air ball kit to prevent that for free.
#1902 4 months ago
Quoted from Speck:
Check and see if you have the air ball kit installed or in coin box. If not email Stern with your serial number and they will get you set up with the kit. It’s basically a precut plastic that installs over the top of the drops and keeps the air balls down
#1903 3 months ago
Quoted from mlev25:
Check and see if you have the air ball kit installed or in coin box. If not email Stern with your serial number and they will get you set up with the kit. It’s basically a precut plastic that installs over the top of the drops and keeps the air balls down [quoted image]
It’s not the airball, I have the kit. The targets don’t drop when hit. They just bounce off. It doesn’t happen that often but enough to be annoying.
#1904 3 months ago
I asked about this awhile back but did not solicit much response. So I read through all 38 pages of the thread to see if anyone had commented or experienced anything regarding the spinning disk motor. But I did no see any comments. So I thought I would bother you all to ask again...
I am wondering if what I am hearing is totally normal, or if I may have an issue or bad motor/assembly. Very expensive to buy a new one and replace if nothing is different.
My machines are at home and typically its pretty quiet. Volume of pins is not up very high. That said, when the disk spins I can clearly hear it, which is bothering me. I disassembled the mech & cleaned/lubricated all the gears, had no affect. I did not observe anything problematic, its a strange motor assembly and appears to just make a lot of noise when running. I am trying to understand if it should be quiet when running, many motors are, but I have nothing to compare it to. The fact that while I am playing, I am bothered by hearing the disk spin - is making me not enjoy the game. It won't overtake the music if playing, but when the music is in a quiet spot, the spinning disk is extremely noticeable.
Can anyone share if they can hear the motor/mech or is it/should it be quiet? I am trying to determine if its me or the motor
thanks!
Mike
#1905 3 months ago
I have to say I don't notice the sound of the motor spinning myself when playing.... But perhaps I have had too much loud music and concerts in my life
#1906 3 months ago
Quoted from mjmpin:
thanks!
Mike
Hey Mike,
Is the noise like a motor hum, if that’s the case I can hear mine but I can expect that when it’s in full spin. Can you deacribe what you hear? If you spin the disc by hand is it silent?
I have Turtles with a spinning disk and don’t hear that one over the pin sound. With no volume I can hear the disk spin but not the motor running.
Let’s figure this out.
I
#1907 3 months ago
Quoted from TroyS:
Hey Mike,
I
Thanks, I'll try to describe, but if needed we can PM and I can send a brief audio/video clip. There is definitely a hum, like a transformer hum but additionally there is a slight edge to it, a ratcheting or mechanical agitation sound which is consistent with the hum.
When I took it all apart, I assumed gear noise, but cleaned & greased the gears and that had no affect. I pulled out the motor armature and cleaned it, the contacts to hit the brushes are on the end of the cylinder and its possible that the sound I am hearing is those contacts hitting the brushes, but cant be certain. Everything seems to work fine, but when it spins its not quite. turning the motor by hand doesn't create the speed needed to notice noise. With the motor removed I can spin the disk in the playfield and that is dead quiet, so its not the disk mech.
The easiest way to describe why this bothers me is...If I start a game and close my eyes, I can EASILY always know when the disk spins, cause I can hear it and I would have hoped that it would be mostly undetectable during play.
best,
Mike
#1908 3 months ago
Quoted from mjmpin:
best,
Mike
If it helps I can record my game starting and the can see if it’s the same?
#1909 3 months ago
Quoted from TroyS:
I like that plan if you don't mind the bother? Tonight I will video my disk spinning, I'll turn the audio volume off and capture the sound from above the playfield, glass on. I'll PM it to you
maybe you can do the same & we can get a quick answer from comparing them
you support is extremely appreciated!
thanks
mike
#1910 3 months ago
What is the trick/what am I missing when trying to start a second mode on the same ball after completing it or timing out?
As I understand it, you hit the fab and four drops, then shoot the loop tot he magnet and it starts another mode.
I have seen this happen a couple times, but more often...
I complete a mode, then the Fab Four drops may be partially up or down, not sure if I have to wait until they reset so they are all up?? Regardless, when I complete the fab - the video colors in FAB, then when I hit the FOUR, it colors in FOUR, but rarely will it color in both and say "Fab Four" which I assume is what you need? mine just keeps alternating back & forth. Shooting the magnet does nothing most often, so I just keep hitting FAB & Four drops over and over again but never accomplish what is supposed to happen. A few times, when the bonus light is lit behind FAB, the FABs won't even come back up, unless you hit the target, but I thought you could stack modes for that bonus, but could never start another one if the FABs are down ???
I must be confused
I am seriously missing how this works and the rule sheet must not be telling me something, its apparently not as simple as it sounds
thanks!
mike
#1911 3 months ago
Quoted from TroyS:
I sent you a PM
#1912 3 months ago
When the timer ends on the first mode, the FAB and FOUR target banks will both reset, and the Super Jackpot target lights. This is when you need to hit the FAB FOUR drops again. Any completions you earned during the mode don't count. When the FAB targets are down, they will stay down until you either hit the Super Jackpot target or start the second mode.
You can't light the next mode until the first one ends, and there's no way to finish a mode early.
#1913 3 months ago
Quoted from CaffeineSlug:When the timer ends on the first mode, the FAB and FOUR target banks will both reset, and the Super Jackpot target lights. This is when you need to hit the FAB FOUR drops again. Any completions you earned during the mode don't count. When the FAB targets are down, they will stay down until you either hit the Super Jackpot target or start the second mode.
OK this is helping a bit! So the mode isn't over when you get even 5 and the screen says "completed" ? you have to wait for the timer to end, that seems odd, but may be the biggest part of my issue. I am trying to hit the Fab Four drops immediately after I achieve level 5, thinking the mode is complete.
#1914 3 months ago
What may have confused me is this statement from the rule sheet - "Once a mode has ended (whether by time running out, or by completing it after level 5 has been reached), the next mode can be started by completing F-A-B and F-O-U-R, then shooting the upper magnet"
#1915 3 months ago
Quoted from mjmpin:
I always go for the super jackpot after the mode ends. This is not the right thing to do?
#1916 3 months ago
Quoted from Methos:
I'm not sure, I read that you can stack and get more points, but I haven't done that yet.
"if multiple modes are completed on the same ball without scoring the Super Jackpot, the value will be multiplied by however many modes were played beforehand. (i.e. if you complete 2 modes without collecting the Super Jackpot and then collect it, it will award a 2x Super Jackpot for your 1st mode and a 1x Super Jackpot for your 2nd mode. This can go up to 5x for completing all five modes!)"
#1917 3 months ago
I've been meaning to update that rulesheet, because at least on the latest code it's incorrect. After you reach level 5 (or whatever it's set to) to complete the level, you can continue to hit more of the objective. Each extra levels worth of the objective gives you 100k and adds that score to the super jackpot at the end of the mode.
Quoted from Methos:
It's often the right thing to do, but if you're pretty confident you can let it ride and collect it at a higher value after another mode.
Say you play Ticket to Ride first, and then you start Drive My Car before collecting the TtR jackpot. If you complete Drive My Car, now the super jackpot target will be worth 2x TtR + 1x DMC. If you delayed collecting the super again and played/finished All My Loving, then the super jackpot target would be worth 3x TtR + 2x DMC + 1x AML.
14
#1918 3 months ago
Two great things tonight:
1. New high score.
2. FINALLY, TAXMAN!!!
I will NEVER get sick of this game. Ever.
So good to finally get to Taxman. I could feel myself getting closer and closer over the last few months. Now to get there again and keep building on that score. Cheers to all you Beatlemaniacs out there who have one of these amazing machines.
#1919 3 months ago
Quoted from SilverBallKid:
1. New high score.
I went a few months without getting there then 3 times in one week. The points rack up quickly and the light and sound show are just amazing. Of course once that ball is done, that’s it, you’re back to square one which is a bit of a letdown. I wish it built from there and have you a new goal.
#1920 3 months ago
Quoted from mjmpin:
- I think - that after you’ve completed the mode but the timer is still running - that’s when you rack up the big bonus points. Not sure though. I keep at it even after completing to continue building.
#1921 3 months ago
I think that is what my problem/confusion was. As soon as I see the level 5 info, Id start trying to hit the fab four drops to start another mode, but in reality, the mode I'm in hasn't ended yet! Have to let the timer run out, should clarify that on the rulesheet
thanks!
#1922 3 months ago
Thanks - i thought it was all for non - meaning that each mode had it's own JP and if you missed it, it was gone.
#1923 3 months ago
Quoted from A330FOATL:
I played a Beatles Gold yesterday and really enjoyed it. Was thinking of picking it up, but a friend pointed out that it's a lot like the JB60th that I have and that they play very similarly. For me, theme is #1 and I love the Beatles and the way they were integrated into the game. Curious if any collectors have both of these pins and their opinion.
If I had to choose, I’m take the Bond 60th over Beatles everyday.
Beatles are my favorite band ever. I’ve only ever seen a couple Bond movies. I think the Bond plays better and has deeper rules.
#1924 3 months ago
Quoted from Trekkie1978:
If I had to choose, I’m take the Bond 60th over Beatles everyday. ... I think the Bond plays better and has deeper rules.
And requires a lot deeper pockets of course.
#1925 3 months ago
I noticed my game stopped keeping the time and date after turning it off, even after changing the battery. I think maybe the contacts got bent in the battery compartment, but I’m not sure exactly how they are supposed to look.
Would someone take a closeup picture of the battery compartment for me? Nothing I found online has a detailed enough picture to be helpful. I attached a few of mine for comparison. Thanks!
IMG_1358 (resized).jpegIMG_1358 (resized).jpegIMG_1359 (resized).jpegIMG_1359 (resized).jpegIMG_1360 (resized).jpegIMG_1360 (resized).jpeg
#1926 3 months ago
Finally was able to add a Beatles to my collection...love it!
#1927 3 months ago
Quoted from Spelunk71:
Would someone take a closeup picture of the battery compartment for me? Nothing I found online has a detailed enough picture to be helpful. I attached a few of mine for comparison. Thanks![quoted image][quoted image][quoted image]
Update: Pablo at Stern helped me to get the battery working. He’s a good guy.
#1928 3 months ago
What was it?
#1929 3 months ago
Sweet collection. A 007 LE and the Elwin! Just perfect. Oh yeah lol… congrats on the Beatles!
#1930 3 months ago
Don’t just yank the battery out like I did and bend the contacts. I was able to get it back in shape with some trial and error but learned my lesson.
#1931 3 months ago
Quoted from TroyS:
#1932 3 months ago
That was quick. May want to look at Pulp Fiction down the line also. I am not sure because I haven’t played it yet but it may fit the Bond 60th/Beatles vibe. I will give it a look for myself.
I say down the line because CGC is soooo slow.
#1933 3 months ago
Beautiful collection! Now get those windows covered!
#1934 3 months ago
Quoted from pinnyheadhead:
Pulp Fiction would totally fit that collection!
#1936 3 months ago
Why doesn't the post between inner/outer lanes have rubber? Seems odd and would mark up balls? Looks like its designed for a rubber. Can a small rubber fit without disrupting ability to flow into lanes?
thanks!
#1937 3 months ago
Quoted from mjmpin:
thanks!
should be in your goody bag in the coin box
#1938 3 months ago
Quoted from ccbiggsoo7:
Yep mine had two in the bag. When I put the one on the right outlane the ball could no longer roll down the right outlane and would get trapped. I didn’t investigate if there was an adjustment I could do to make it work.
#1939 3 months ago
Quoted from thekaiser82:
no adjustment, just have to trim it down a bit or find a slightly smaller one.
#1940 3 months ago
Ahh. Yeah it didn’t occur to me to trim it a bit.
#1941 3 months ago
Thanks, interesting, why would they not have been installed? I bought mine used so no goody bag, can you share what size/diameter, so I can grab some?
#1942 3 months ago
I had issues with rubber on the left post. Sometimes when I hit a super jackpot it would hit the rubber and bounce to the out lane.
I just keep them both off.
#1943 3 months ago
Hi all! Just got a late build Beatles Gold (12/21 - with Insider Connect) - Love the game as I knew I would, but I have toppers on my other Sterns - so you know what that means
Does anyone have a topper for sale? I know they're expensive - I'd buy a used topper as well if someone is selling their machine and wants to make more money. Last few I've seen have gone around 1500-1800 new.
Thank you!
#1944 3 months ago
Quoted from adam12hicks:
Thank you!
unfortunately used ones are about 1800 plus now.
#1945 80 days ago
After about 300 plays this happened. Anyone else have this happen? Parts on on order from Stern.
IMG_0968 (resized).jpgIMG_0968 (resized).jpgIMG_0969 (resized).JPGIMG_0969 (resized).JPGIMG_0970 (resized).JPGIMG_0970 (resized).JPG
#1946 80 days ago
Yes, it happens constantly, unfortunately. The part is made of inferior materials. Stern knows about the issue but doesn’t care. At least the part is cheap, so just order a bunch of them in the different sizes (3 and 4 target) and replace as needed. Hopefully someone will make a more robust version for sale at some point.
#1947 80 days ago
I had this happen a few times to me, too. I finally made my own replacements out of aluminum 2 years ago; they have been rock solid ever since:
https://pinside.com/pinball/forum/topic/the-beatles-beatlemania-official-owners-and-fan-club/page/22#post-6372756
#1948 79 days ago
Quoted from Scotty_K:
Wow....love that! Are you able to make one for sale? If so, please let me know!
#1949 79 days ago
Put them on the pinside marketplace - I would buy some. I just had a single drop target one break on my GB that is waiting for me to fix today (by coincidence).
#1950 79 days ago
I would buy as well.
Manchester, NH
Pinhead mods
Protection
$ 649.95
Pin Stadium Pinball Mods
Led
$ 6.00
Apron Envy
Protection
Hardware
ScottieIA Mods
Hardware
$ 135.00
Sparky Pinball
Toppers
Precision Pinball prod.
Flipper parts
7,400 (OBO)
Grand Rapids, MI
$ 69.95
Hookedonpinball.com
Toys/Add-ons
$ 54.99
Shooter rods
$ 130.00
Shooter rods
Space Coast Pinball
Other
$ 26.00
BomberMods
Other
8,999
Los Angeles, CA
$ 54.99
Shooter rods
$ 420.00
PinWoofer
Sound/Speakers
$ 39.00
Arcade Upkeep
Other
$ 54.99
Shooter rods
$ 75.00
FlipMods
Shooter rods
$ 150.00
PinWoofer
Sound/Speakers
Filament Printing
Other
$ 52.99
Pinball Shark
Shooter rods
Flipper parts
Gweem's Mods
Sound/Speakers
$ 299.95
Led
Sparky Pinball
Toys/Add-ons
$ 44.99
Pinball Shark
Shooter rods
$ 54.99
Shooter rods
$ 69.99
Pinball Shark
Shooter rods
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/the-beatles-beatlemania-official-owners-and-fan-club/page/39 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
