My "Nell Log" is not working at all. Is there anything that I should check before I remove it from the playfield?
If not, how do I remove it? Thank you.
its pretty basic to remove it. start with the screws on top then I think that it might come off from there. the motor disconnects under the playfield.
Yea the removal isn’t that hard . Disconnect underneath and remove the screws on top . It’s probably either the motor or belt . Both parts should be available at Marco . The belt is put on a certain way almost figure 8 if I remember correctly .
OK...I disconnected and removed the Nell Log. If I pull the rubber band with my hand, the 'saw' turns. However, I cannot move the gear and the Nell Log is stuck in the 'all the way' back position. Should the gear turn freely without the motor being on? How would I test the motor? See pictures.
RB1 (resized).JPGRB2 (resized).JPGRB3 (resized).JPGRB4 (resized).JPGWanna join the discussion? Please sign in to reply to this topic.
This page was printed from https://pinside.com/pinball/forum/topic/the-adventures-of-rocky-and-bullwinkle and we tried optimising it for printing. Some page elements may have been deliberately hidden.
