Quoted from rockinganker:One suggestion before gluing, sand all your joining surfaces smooth. It looks like your edges are a little rough either from a CNC or table saw, your clue will not bond 100% if they are not smooth. I've made a lot of acrylic displays, shelves and misc. pieces and block sanding your edges is a must.
Table saw. It looked really good until it passed by the backside of the blade. Had access to a high end jointer which we did use for the flat edges but doing the 45s on them was difficult to do well. I will be block sanding them to make a much better joint.
Quoted from browne92:If you have trouble with the areas around the glue joint turning white, or "clouding", use Weld-on 4 instead of 3. It's made to avoid that.
Same thing happens if you flame polish edges with a torch. The heat creates stresses in the acrylic which can be released by the solvent cement, or even changes in ambient temperature. The only way around this is to anneal the parts, which is a long process of heating the whole part to an even temperature, and gradually cooling. See here:
http://en.wikipedia.org/wiki/Acrylic_glass
Neat project. Best of luck.
I'm thinking the clouding/crazing is due to the high humidity we still have going on here. If it doesn't get any better with later tests I'll be switching. Also, no flame polishing for me.
Quoted from KingNine:This is beyond cool. I'll bet after you get it done you'll find keeping it clean is the hardest part lol. That was always the problem with me see through computer case.
My wife has a clear acrylic computer case I built for her from a kit. Part of the inspiration for this project. I agree... It's awesome when it is clean. When.
