(Topic ID: 67163)
*FINISHED* The Acrylic Pinball Project - I am "clearly" insane
By Mk1Mod0
6 years ago
  • 1,333 posts
  • 259 Pinsiders participating
  • Latest reply 2 years ago by Mk1Mod0
  • Topic is favorited by 190 Pinsiders
There have been 487 images uploaded to this topic. (View topic image gallery).
There are 1333 posts in this topic. You are on page 12 of 27.
#551 5 years ago
Back door for head. Drilling the lock hole. 3/4" spade bit.
Looking good.
Added some pieces across the back to make the door "thicker." Remember, it is replacing the galvanized piece which had thick sides. To make it sit well in the track I had to add some so it would not shift around.
#552 5 years ago
Very cool ,the lock looks like its floating .
#553 5 years ago
One piece up top and one for each side to keep the door panel from caving in. Tomorrow I'll install the latch on the top so it can be locked. These were made from the leftovers of the piece that went at the front of the head to hold in the back glass. Will have to purchase a new lift channel for my backglass as the one on the original back glass has apparently been glued on. Really??? Yep.
#554 5 years ago
Are you still worried about the weight, and cracking around the legs? I tried to think of possible alternatives (as I'm sure you did), like a pedestal or something that would support from underneath. A Plexiglas pedestal might work, if you could figure out a way to allow for some shaking, but it's not an ideal solution (even if you made it really cool). Plexiglas pillars would probably fail catastrophically... unless they were 5x5 or something.
I thought maybe you could add two more steel legs... but then I thought "well that's just stupid."
I guess I just hope you have no problems. You're building a GEM here---one that I'm sure will be desired at shows. You just may find yourself taking those legs on and off a bit more than you initially planned.
I think what you're doing is great.
#555 5 years ago
Quoted from cheesewhisperer:
Not as much as I was. It's been on the legs for a couple of months now and getting shoved around the garage with no problems. The guy(s) that designed the modern leg attachment system knew what they were doing. It is essentially a big corner clamp that puts a lot of the weight into the sides and off of the bolts. I doubt there is near as much shear weight on the bolts as I thought there might be.
I did design a H-shaped frame that would have been welded onto each leg with angle iron running front to back to support the weight. With that I might have worried less, but it would have been stiff as hell. I am relatively confident that all will be well, but I intend to have the local pinsiders come over and play the heck out of it once completed. I would much rather it fail here than at a show.
#556 5 years ago
Quoted from zippydapinhead:
My god man, everytime I open this thread it gets better. Most epic project on pinside. Can't wait till its done, but like a good book, will be bummed when it's over.
+1
#557 5 years ago
Latch/lock mech complete.
#558 5 years ago
Very Interesting! You must bring it to the Texas Pinball Festival after you get it all finished!
#559 5 years ago
KIller
#560 5 years ago
Do you think It'll be ready for the Houston show in November?
#561 5 years ago
Quoted from phalcon_2600:
That's the goal.
Quoted from KingNine:
I expect to be done in a month or two, barring any disasters or, you know, life getting in the way. If I can swing the time off, I intend to bring it to Houston. That's a short drive for me and we've yet to attend that show. Would be fun.
#562 5 years ago
houston is a lot of fun. it's more of a big party. versus the giant 'show' of dallas.
#563 5 years ago
Yes - please bring it to Houston!! ....awesome work here!
#564 5 years ago
Quoted from retired_user_101:
Night and Day different! If Houston would just turn down the music so it doesn't overpower the games it'd be so much better. It would also be better if it had an acrylic pinball machine!!!!
#565 5 years ago
Quoted from Mk1Mod0:
Well yesterday was fun! Huh, Radroxx????
Dumbass 4 wheelers...
IMG_7732.JPG 166 KB
Was out there 5 hours in the heat puttin' that thing out. Not much fun. Kids in a truck were trespassing and got stuck. Needless to say, truck has custom flame job to it now ala Crispy.
#567 5 years ago
That IS an interesting way to attach legs. Very relevant here. Never even considered doing something like that. It would certainly be more supportive of the game.
As for the game itself, well that's a whole other topic that practically writes itself. (Fancy a game of "Baby in the Hole?" That's what she said!!) Oy-vey...
#568 5 years ago
Time to whip out the ol' human CNC again...
#569 5 years ago
As always, super impressed by your craftsmanship on this.
Even with the right tools, it takes skill to work with materials like this.
#570 5 years ago
Step 1, drill all the holes and four corner all the cut outs. On the press when I can, by hand when I can't.
A side shot of the holes and cut outs through the polished side. One can also see the sabre saw blade as I get ready to do the rough cut outs. The fine cut will be done with the router using a 1/2" bottom bearing bit to follow the outline of the original.
Getting ready to route.
Here's how it works -
#571 5 years ago
I'm loving these updates! Amazing work....
#572 5 years ago
So good it's almost like cheating. Almost.
Done and done.
A quick side by side. Now comes the"fun" part.
#573 5 years ago
Done and done.
IMG_8020.JPG 116 KB
IMG_8021.JPG 114 KB
IMG_8022.JPG 120 KB
IMG_8023.JPG 244 KB
Are those glass insulators from telephone/telegraph poles?
#574 5 years ago
Quoted from chadderack:
Or beacons?
#575 5 years ago
Runway lights. The airfield at my base went LED and they were just tossing these out. I grabbed a buttload of the older true cobalt blue ones. They're purty. I'm certain one will end up in a pin at some point...
#576 5 years ago
Order of build problem #1 - The holes in this should have been aligned and drilled before assembly. Lesson learned and noted.
Here's the easy solution. No one in my rinky-dink town had one with a mini chuck at the end so I had to get a few bits to go with it.
Marking for depth,
Aaaaaaaaaand Bob's your Uncle! (Or actually a great uncle in my case, but that's too much of a mouthful.)
#577 5 years ago
Here's the payoff. Now to just add in the light guards...
#578 5 years ago
Order of build problem #2. I REALLY should have drilled and routed these before cutting them out. Would have saved me a world of trouble and all the risk potential of close order drilling. The four for the player number were, but the others were not. Noted, lesson learned.
These were done right. No way I was going to try and hold these while drilling. (I really need a heavy mounted clamp for my press...)
These will be welded into place right after I drill the holes for the score mechs. Then reassembly!
#579 5 years ago
Looking good!! I'm so anxious to see the final product. But then I wouldn't have this thread to follow so take your time
#580 5 years ago
how heavy is this machine going to be when completed. I looks like it's going to be a monster
#581 5 years ago
I can see a nut exploding picking up the head alone.
#582 5 years ago
Quoted from castlesteve:
Quoted from CaptainNeo:
Yes on both counts. Moving and setup on this sucker will be a team effort.
#583 5 years ago
Ok. Not that it isn't beautiful work... but I gotta ask.
Why even do the lite blockers in clear acrylic. Isn't the point to block lite leakage from around the backglass features?
Wouldn't it have been better do this in smoke transparent... or maybe even black opaque?
#584 5 years ago
could always use a silver adhesive backed opaque sticker material. Just line the inner wall of the ring. Would keep the light focused in the area its' suppose to. Since he has it cut out already anyway. And would still look transparent from the front.
#585 5 years ago
Back box relay board.
#586 5 years ago
#588 5 years ago
It's really coming together now. THANKS for posting pics of this project!!!
#589 5 years ago
WOW !
#590 5 years ago
I have been following this for some 6 months now and I can now answer your question. Yes you are "clearly" insane.
#591 5 years ago
Quoted from fiberdude120:
It never was a question - it was a statement.
#592 5 years ago
When ur ready to load just holler.
#593 5 years ago
Quoted from raddroxx:
Wow, your brave. I wouldn't want to have to lift 1000 lbs.
#594 5 years ago
1000 lbs really ?
No way.... holy F%$K
i knew it would be heavy but that is mind blowing..
#595 5 years ago
Quoted from Gerry:
1000 lbs really ?
Not really.
3/4" acrylic weighs 4.3 lbs per square foot (137 pounds per 4x8 sheet).
3/4" plywood is 2.15 lbs per square foot (69 pounds per 4x8 sheet).
It could weigh 500 pounds! (I can't wait to see the final weight)
#596 5 years ago
Quoted from SunKing:
All these months and I have been reading it wrong. Silly me.
#597 5 years ago
As long as you understood the "clearly" reference...
#598 5 years ago
Yes I "clearly" did.
#599 5 years ago
I love Vid- Facts to the rescue once again.
But I vote final weight including the tilt and play balls- with the manual in the cabinet
@459.8.3 lb
We need a survey!
#600 5 years ago
I had a lot of catching up to do on this thread and what a fantastic read its been so far. keep up the excellent work and thank you so much for all of the updates
$ 7.00
APB Enterprises
$ 17.00
$ 7.00
$ 14.95
$ 96.95
Professor Pinball
$ 9,000.00
Operation Pinball
$ 2.50
Doc's Pinball Shop
$ 400.00
Playfields
Maple Street Sign Shop
$ 17.50
Hardware
Apparel - Unisex
ArcadeMade
$ 76.95
nvram.weebly.com
$ 89.99
$ 22.00
$ 27.99
