(Topic ID: 67163)
*FINISHED* The Acrylic Pinball Project - I am "clearly" insane
By Mk1Mod0
6 years ago
  • 1,333 posts
  • 259 Pinsiders participating
  • Latest reply 2 years ago by Mk1Mod0
  • Topic is favorited by 190 Pinsiders
There have been 487 images uploaded to this topic. (View topic image gallery).
There are 1333 posts in this topic. You are on page 11 of 27.
#501 5 years ago
I started reading this thread a few weeks ago. It looks awesome, great skill there.
There's one thing creeping my mind though, if you say the polycarbonate scratches easily, aren't you afraid of playing the machine leaving scratches where the ball moves and bounces? I never read anything about protecting the playfield against that.
#502 5 years ago
Quoted from Gerry:
I told ya collinite 885 rules !
There is NOTHING better !
I put it in my Amazon wish list for my next order.
#503 5 years ago
220 grit.
600 grit.
1000 grit.
2500 grit.
And now for a little polishing.
#504 5 years ago
w o w ! ! !
#505 5 years ago
take it to 1500 then 2000 you will thank me in the end...
3000 on an orbital 6" DA would be even better before you machine buff after the 2000...
#506 5 years ago
Thats how i do all my automotive resto big dollar paint jobs, and it is just amazing...
and it cuts the buffing to a minimum...
#507 5 years ago
you clearly have mad SKILLS very nice work
#508 5 years ago
If there is any chance machine buffing will induce any heat into the material, I suggest hand polish only.
#509 5 years ago
That stuff is actually tougher than paint, unless you lay on it hard with the buffer in one spot there should be no chance of damage...
#510 5 years ago
Since it does scratch easily, the ball might chew it up in a hurry, maybe you should scuff it and clearcoat the playfield. Would hold up to ball traffic and be easy to fix and buff when scratches do occur
#511 5 years ago
So after yesterday's marathon upper body work out, I decided to take it easy today. I thought I might finish the reassembly of the coin door and connected electrical items. (Flipper switches, game start switch, tilt mechs, etc.) I get the door aligned with coin return at the bottom...
and the coin insert slots at the top...
and go to close the door, only to see...
Another "WTF" moment brought to you by the coin door and "It's one thing after another" amusements inc.! All I can do is laugh...
#512 5 years ago
Thats odd !
#513 5 years ago
you sure that whole panel is mounted correctly? I've had this before and found out I was using the wrong holes.
#514 5 years ago
that is an opps for sure. Happy Easter!
#515 5 years ago
Quoted from CaptainNeo:
Boy I sure hope so!! Anything is possible, but the coin return would also have to be moved on the inner panel to still line up with the cut out in the outer panel. Had to walk away and go run some errands so I haven't been back to look at it yet. If it was off by a little I would think I just didn't get the frame in right but it's off by a quarter inch. HAS to be an easy answer.
#516 5 years ago
are the frame bars correct? Is it one piece or 4 separate pieces?
#517 5 years ago
Four separate pieces. And by itself, the outer panel shuts quite nicely. Was only upon adding the guts that this happened. As far as I can tell this is how it was in the original machine, but it couldn't have been.
#518 5 years ago
and your 100% positive those panels are in the right order? there isn't one without a lip edge at all? or a notch cut out in a section? If not, your back return panel isn't properly reassembled.
#519 5 years ago
Quoted from Gerry:
Was more concerned with heat stress than damage. I tried to use a piece of cloth and Novus 2 on the end of a oscillating tool. It cracked before my eyes.
#520 5 years ago
Fixed it...
Noticed this...
All better.
#521 5 years ago
Quoted from browne92:
I've done a buttload of testing with this in mind just like I did earlier with the screw hole sizes. Reason #1 for not flame polishing the edges. Makes for a brittle piece. Turns out that the buffer and buffing compound I am using will burn my hand before it really harms the acrylic or polycarbonate. I often buff the smaller pieces with gloves on. Keeps me from buffing off my finger tips.
#523 5 years ago
Hoping this makes it to Expo this year in Chicago. There are going to be a ton of custom machines.
--Scott
#524 5 years ago
Looks like it's coming along real nice. Think I met my match when it comes to OCD. Keep up the fine work.
#525 5 years ago
Quoted from TheNoTrashCougar:
--Scott
I forgot to mention that I really love this project. Great work!!!
--Scott
#526 5 years ago
Murphy's law strikes again.
Glad you figured this one out so quickly.
#527 5 years ago
This is going to look so sick when finished. Amazing!
#528 5 years ago
Yaaaa, I gave some good advice. I know cuz i've done it before.
#529 5 years ago
This project is so cool. Thanks for letting us watch the process.
#530 5 years ago
Oh, you nailed it all right. I managed to mislabel them from the get go. And with the short one being up top, the angle made them appear to be the same. Lesson learned.
#531 5 years ago
I finished attaching the three trim pieces to the back box. Not sure if I like it or not but there is no turning back now!
The old back box had vents angled under the trim and through the top.
Mine will have some simple holes drilled through the top with this screen attached underneath.
#532 5 years ago
I like the trim. I think once there are lights inside of it, the extra edges the trim provides will be great.
#533 5 years ago
+1 on the trim
#534 5 years ago
WHOAH. Wait. Screen. No.
What would you do if I offered to laser cut a grill for you at Techshop out of clear acrylic?!
#535 5 years ago
Looking good.
Zitt is on the right track. No mesh make it acrylic also.
#536 5 years ago
I JUST discovered this thread... and have spent well over an hour enjoying the details.
Looking forward to seeing this completed.
Hurry up, dammit.
#538 5 years ago
Or just use clear plastic screening.
Yep, staggered hole perforated sheets are readily available in clear.
#539 5 years ago
Wow. Didn't see that one coming...wink, wink! While I REALLY like the look of the polished s/s through the acrylic I am nothing if not open to suggestion. The jury is still out between steel mesh, plastic mesh and simply drilling a nice pattern into the top itself. Being as acrylic sucks at absorbing/transferring (as compared to plywood) heat and excels at passing it along I expect there will be a fairly healthy exhaust from this thing. Any plastic mesh would have to be thick enough to handle that. We shall see...
Quoted from Zitt:
A very kind offer, but no thanks. I'll work out something here.
#540 5 years ago
Meanwhile, a banner work day where much got done... for my employer. 8am phone call to go spend 8 hours in the hot Texas sun fixing the mistakes of the young and stupid with too much pick-up under their feet. Amazing how much damage a speeding, out-of-control 2500HD can do. Yikes. Truck destroyed, young-un got away with 5 staples in his head and a healthy hike in his parent's insurance rates. (Thanks for all your help, Buildy!)
Back on subject, I was very displeased with the way my playfield polishing was coming along. The final stages were hazy and awful.
Quoted from Gerry:
Actually, I figured out that the problem was the 600 wasn't enough to rid all the scratches of the 220 and the 1k wasn't enough to eliminate the scratches of the 600. Tried too much too fast. While it worked like a champ on the acrylic, the poly is a much different story. So after 3 attempts to get it right I figure this out. I am now going 220, 400, 600, 800, 1k, 1500 and we'll see from there. I got through 600 tonight before I lost the light and I already have better results than I did the week before.
BTW, Gerry, thanks for reminding me that I HAVE a DA sander. (Cheap 4.5" model, but it works well enough.) I had been on my 1/4 sheet palm sander. Plum forgot all about that thing. Dee, dee-deeeeeeeeeeee!!
#541 5 years ago
On a related note, I decided I was spending way too much money on the little polishing compound sticks from Sears. So using the wife's Amazon Prime account, I got a pair of 1# blocks in two days, free shipping. MUCH more economical.
#542 5 years ago
I was just thinking with those new fangled UV LED's and a little spray on the wires and some powder dusting and you could really have the wiring look cool.
http://www.blacklightworld.com/HandPowder_1_1.jpg
Is anyone else helping this guy past the insane point?
#543 5 years ago
Well yesterday was fun! Huh, Radroxx????
Dumbass 4 wheelers...
#544 5 years ago
Today was much more relaxed than the rest of the weekend. Finally got some quality me time with my favorite project. After spending a couple more hours on the playfield rehab, I cut, trimmed and edge polished the rear panel for the head.
#545 5 years ago
A little warm for it today...
Cut, trimmed and edge polished the piece that holds all the scoring mechs and back box lighting.
#546 5 years ago
Polished up some more misc. parts for the score mech panel. Note the one piece with the purple looking edge. If you are buying poly from a shop here's the clue that they are not ripping you off. Real poly will have that darkish tint to the edges. Plain acrylic always looks clear. Even when rough cut it looks the same.
More...
#547 5 years ago
Very cool. I really can't wait until the final project gets a video posted.
#548 5 years ago
My god man, everytime I open this thread it gets better. Most epic project on pinside. Can't wait till its done, but like a good book, will be bummed when it's over.
#549 5 years ago
Quoted from zippydapinhead:
$ 300.00
Tools
PinDoc Restorations
$ 4.49
$ 11.95
$ 17.50
Playfield - Plastics
$ 239.99
PinballBulbs
$ 54.99
Singer Pinball Designs
Flashinstinct
$ 79.95
pinballmod
Various Novelties
GC Pinball
Pinball Mod Co.
$ 54.99
$ 99.99
Pinball Photos
Third Coast Pinball
$ 84.95
PinWorlds
$ 65.00
Texas Pinball
