FINISHED! Astro is back together and works. I played it, and it works well. I have some small problems to work out. Maybe one of you can help me with the newest...
I GET SHOCKED BY THE FLIPPER BUTTONS!
The fiche paper wore off or something. Is there a work around that is good, perfect, easy, or reliable? I was looking for pre-cut fiche paper, but couldn't find it. Am I just to do my own cutting?
Side rails need to be sanded to a shine. That might happen tomorrow.
The bulbs in Astro's backglass are...wrong. I need frosted guys up there. The new back glasses work, but they lack an extra-black layer behind everything to halt residual light leaking about.
Firstly, reverse the line cord plug in the socket. Secondly, you can put some shrink tubing on the wire forms both where they contact the flipper switches, and where they contact the buttons.
Quoted from jrpinball:Firstly, reverse the line cord plug in the socket. Secondly, you can put some shrink tubing on the wire forms both where they contact the flipper switches, and where they contact the buttons.
Oops! Never mind. "Astro" has the switches mounted in the cabinet, directly in contact with the buttons. No flipper contact wireforms on that game!
And, if it has the correct three prong power plug, you can't reverse it in the outlet.
Quoted from jrpinball:Oops! Never mind. "Astro" has the switches mounted in the cabinet, directly in contact with the buttons. No flipper contact wireforms on that game!
Would scotch tape work?
Or regular paper?
The shock is mild, because I am on carpet with wood underlayment, but if I was connected to water or concrete it could be bad. Plus it ruins the game to get shocks every flipper hit.
Isn't it only 6v at that point?
Fix it. If you can feel it, regardless of the voltage, it's being conducted to your body.
Only .5A can kill you if it has a good path through you to ground.
The worst shock I ever got in my life was from a 24V power source. I was barefoot, soaking wet, and standing on a concrete floor, so I got the full effect.
Forget scotch tape. Order new flipper switches with the insulating paper from PBR.
Also, if you installed a new power cord, the hot wire should be connected to the fuse. That game should have a grounded cord, but I don't think they did a really good job grounding these games from the factory.
Quoted from jrpinball:Also, of you installed a new power cord, the hot wire should be connected to the fuse. That game should have a grounded cord, but I don't think they did a really good job grounding these games from the factory.
DONE! It's all done properly, and I just installed the new cord today. I'll just have to get those new switched.... these are old-moldy anyway.
Quoted from HowardR:PBR has fish paper
http://www.pbresource.com/pfswitch.htm#common
Excellent! I'll grab those after I move house in 2 weeks. Thanks for that!
Quoted from Gott72:Excellent! I'll grab those after I move house in 2 weeks. Thanks for that!
I wouldn't bother replacing the fiche paper. Just order two new switch assemblies and be done with it.
RAILS ON.
I did the old 220-400-800-1500-3000-5000-foam buffer-steel wool+polish routine. My hope was to get MIRROR rails with super reflective qualities. However, I got what you see... which is nice, but not the desired result. Instead of mirrors, I have semi-reflective with buttery smooth feel. mmmm.... buttery smooth metal. They look good, just not AS GOOD as I envisioned.
Now they get packed up and shipped to Palm Desert, where we move in 10 days. After that I can begin revisions again and get these guys closer to excellent.
Remaining issues:
KING KOOL--AS relay needs total fine tuning, new glass, various tightenings and adjustments to switches, still fooling with the kicker down front tossing the ball too far and not enough simultaneously. (And playfield touchup)
ASTRO--extra balls come fast and furious for no reason once you light up everything, new flipper switches, new glass (and playfield touchup).
NOW--1st Player 1000 reel is a clunk-o-junk and needs work, mild tweaks to switched and targets, new flipper switches.
Quoted from Gott72:No way. These are keepers.
After all that work, I don't blame you.
