(Topic ID: 146487)
"That trick never works!" - Rocky & Bullwinkle Club!
By RDReynolds
8 years ago
  • 1,512 posts
  • 161 Pinsiders participating
  • Latest reply 2 days ago by DanMarino
  • Topic is favorited by 70 Pinsiders
There are 1,512 posts in this topic. You are on page 6 of 31.
#251 7 years ago
Thought there were plenty on eBay?
#253 7 years ago
Quoted from shicketmaster:
eBay seller is very "proud" of his. $49 at Marco, $79 on eBay.
#254 7 years ago
I have old ROM's in my game. CPU says 1.1. 1.3 seems to be the most current. Anyone know what was updated in the 1.3 version? Is it worth updating?
#255 7 years ago
Well, when I bought mine on eBay, it was the only place I could find one. Sometimes you have to pay a premium if you aren't willing to wait for a restocking of supplies
#256 7 years ago
cross posted this to Data East club page..
Having a small issue on my R&B. My right ramp exit switch has quit working. i checked the wires to the CPU, both have continuity. I looked at the switch matrix, unfortunately, there is only one other switch in the column. It is working, the switches in the row seem to be working. I went through the switch tests, had 2 other switches that weren't registering. I activated them several times, they started working intermittently, then consistently they started working???? Seems odd to me.
There is a diode on the switch terminals. Well technically it looks like its hooked to 1 leg, then to a different point then the other wire is hooked to.
Separate question while running through the switch tests, the 3 hat trick targets, the outside ones, when i activate them and hold the target, they register once. When i push and hold the center one, it keeps registering. Any ideas what to check, or what is wrong there. probably why i get the wrong...wrong...wrong hat. thanks in advance.
i'm guessing maybe the switch is bad on the ramp. I can here it clicking when i move the arm. so i know its "actuating". Also anyone point to a place to buy the switch. I looked at Marco and Pinball life, neither had the correct pn. Maybe have to buy without the arm, or buy with straight arm and bend?
#257 7 years ago
the ramp switch is a cherry switch right? do you ever get over to westland? there is an electronics store that may have one. can you post a pic?
#258 7 years ago
Unfortunately wrong side of the state. i am basically on lake michigan. Here are the 3 switches i am having issues with, 2 that seem to work after actuating them a few times, and the 1 that doesn't work at all. Pic 1 & 4 are the one that isn't working at all DE pn 500-5633-00, 2 and 3 are the intermittent ones. DE pn's 180-5090-00, and again 500-5633-00. I'm not sure if they are "cherry" or not. First real experience with them.
#259 7 years ago
Hmm... i never thought about it but i get wrong wrong wrong hat sometimes too. Could your diode be bad on the switch that isnt working? Or possibly stuck closed? (Or open)
#260 7 years ago
Quoted from amkoepfer:
not sure, is something to check though.
#261 7 years ago
maybe someone can clarify, are these switches just the Cherry DA3 switches. New version PN DB3C-B1AA? of so i can just order from mouser, and move my arms over.
#262 7 years ago
I think everybody gets the wrong, wrong, wrong hat.... I always thought it was just in the code
#263 7 years ago
Quoted from tilted81:
There are some things that can be done to lessen it. This is from earlier in the thread from FirebrandX
"Padding and also re-gapping the contacts. Over time (especially on these old machines) the gaps become nearly closed, and the impact of the ball vibrates the gap in a rapid open-close-open-close manner. This causes the "wrong-wrong-wrong hat" audio issue. Basically just proper upkeep and service will prevent it from becoming an annoying problem. "
#264 7 years ago
Quoted from Insane:
I will take a look at mine later today. I will see if they are cherry brand but they are cherry style. basically they are a micro switch and can wear out. once I figure out what they are I can see at my local store and how much they will be. I could always mail them to you. I may not be able to get to the store till Saturday though if you're not in a rush.
#265 7 years ago
I thought it was code also as I don't have the most current.
#266 7 years ago
Quoted from rwarren28806:
i would be curious to see if anyone else has the same results that i have, where in switch test mode, if you push and hold the outside ones only say it once, and the middle says it repeatedly.
#267 7 years ago
Mines at my sisters or else I'd check
#268 7 years ago
Sometimes when the ball goes up the right ramp on mine and doesnt get all the way up and comes back down, the ball gets stuck on the gate. Is the gate supposed to lock or is mine not working properly?
#269 7 years ago
My machine is in pretty good condition. Though the left flipper can not make the right ramp. It never makes it all the way up. I have to backhand it up the ramp to make it and this is a very difficult shot . Has anyone put stronger solenoids in this to make the flippers work better?
#270 7 years ago
Quoted from Don44:
I would say not working correctly, mine will go through either direction.
#271 7 years ago
Quoted from toddsolus:
I rebuilt my flippers, and have no real issues now. My flippers were in desperate need of being rebuilt.
#272 7 years ago
Quoted from Insane:
The double "wrong" occurs when you hit 2 targets at the same time.
#273 7 years ago
Insane
Check out this one. May not be the right part but these guys are on your side of the state. you might want to call them and see if they have it.
ebay.com link: Pinball Microswitch Assembly Data East Sega Stern Bally Williams
#274 7 years ago
Quoted from Bax1:
Insane
ebay.com link » Pinball Microswitch Assembly Data East Sega Stern Bally Williams
yeah, i'll check them out, thanks for the tip.
#275 7 years ago
ok, got my switches in, now to install. Upon removing the ramps to get the switches off, i noticed a couple of things that i don't think are correct, can you guys look and let me know.
Appreciate any and all help.
Pic 1 overhead view of the same plate as pic 2. Screw obviously isnt factory, and it looks like there was a post behind it, again factory? what about the small hole slightly diagonal up and right from place where it looks like post is missing.
Pic 2 the metal plate behind the blue post. Is it factory, or someone's attempt at protecting the ramp.
Pic 3 the small piece of spring steel on top of the post
Pic 4 the screw up against the metal plate right next to yellow post.
#276 7 years ago
Quoted from Insane:
1. The screw is a replacement. Nothing to worry about.
The electrical wires under the gate wire should not be there. I can't see where they are going but mine doesn't have anything installed in front of it that requires wiring. But he white/violet-green/black combination indicates the right return lane gate. Definitely should not be on the left side.
I'd ignore the small hole. Might have been a mod that was removed. What I did notice is that typically a micro switch is attached to the bar extended from the wire bracket. Sometimes the hat trick switch is removed to disable its functionality. You can see this better in the second picture.
2. More of an add because the ramp is broken.
3. No idea why that is there.
4. That is to hold the metal plate in place. The plate, I believe, is non-standard as what I have is attached to the screw on top of the post in front of it.
Just starting to refurbish mine. It is an import from England so some of the switches and wiring does not match the manual. It will make my job interesting.
#277 7 years ago
Quoted from Insane:
Does this album help you at all?
https://www.flickr.com/photos/37999418@N04/albums/72157629437568588
RussMyers
#278 7 years ago
As an FYI, some machines are different than the pictures. Mine is an England build and, for example, the hat trick micro switch is under the playfield and the WABAC ramp is at the foot of the ramp and not 2 inches behind it. I'm not sure how many other things might be different. I'm just getting around to refurbishing it so there may be more.
#279 7 years ago
Russ, I looked at your pics, and think they answered some of the questions. I couldn't tell on the metal piece in pics 1 & 2 as the pics you showed had Cliffy's installed. I have the switch pulled out in the picture as I am replacing it. So disregard the wires pulled the way they are. So was there a metal plate there originally? on the last pic, the screw, I think the plate is correct, it seems to be mounted on the inside ( I haven't pulled the plastic yet to double check). On the screw holes (pic 1), Russ, it looked like yours had the same thing, at least the small one, can you verify?
Rwarren, appreciate your information as well. Will post more tonight.
#280 7 years ago
That curved metal plate behind the blue target and post - definitely non-factory. Added by someone to help with the ramp damage.
Have a look at these:
http://www.passionforpinball.com/RnB.htm
The before pics show the original setup
RM
#281 7 years ago
Quoted from RussMyers:
RM
Perfect, thanks for the link. I already have a couple of my cliffy's installed, just not all of them yet.
#282 7 years ago
Ok, new questions. On the attached pic, the screw was holding the metal piece in place, as the bracket at that end that holds it, is broken away from the main part. UUUGGGHHHHH. Also on the plastic that surrounds and covers the bottom pop, there are 3 screws, 2 go into the pop body, and then there is a third. Does it attach to anything? Mine just has a long hex post nut on the bottom, not attached to anything, just sits between the 2 posts that are there. The more i get into this the more things i find wrong. And the metal piece in the top picture before was definitely a route add, custom cut and filed piece.
#283 7 years ago
#284 7 years ago
Not on mine. It's in between the ramps so nothing functional.
#285 7 years ago
This is what mine looks like.
Alan
#286 7 years ago
Quoted from P2K:
Alan
ok, so nothing there originally. thanks
#287 7 years ago
Quoted from Insane:
Anyone know a pn for this ball guide, or where i can get one?
#288 7 years ago
Quoted from Insane:
#289 7 years ago
not the cliffy, i have those i mean the curved one behind the yellow target. The one highlighted in the picture above i posted with the red arrows.
#291 7 years ago
Quoted from Bax1:
ebay.com link
This one insane?
I don't think any of those 3 are the one I need. I will have to double check tonight. I had seen those before.
#292 7 years ago
Before I break something, I need to change the bulb in the Boris shooter. I removed the microswitch. I unscrewed the large plastic nut from behind it but I don't see how to get to the bulb. It appears as if the plastic bracket that holds the switch might unscrew but when I try to do that, it doesn't budge. I don't see any tabs or locking mechanisms. And forcing it, "That trick never works". This can't be that hard but, again, before I break something that I can't replace, I thought I'd ask.
#293 7 years ago
i'll have to double check tonight when I get home, but I think it just twists 90 degrees and pulls out. I will verify tonight and let you know.
#294 7 years ago
on mine, you don't have to remove the microswitch, just grab the switch, and turn it counterclockwise and the whole switch and bulb assembly comes out. only have to turn it about 20 degrees or so.
#295 7 years ago
Quoted from Insane:
Thanks. Did you have to force it at all or did it turn off easily? I'm sort of thinking that it may not have been put back in properly and it is stuck.
#296 7 years ago
It takes a small amount of force, you are turning it over a notch (for lack of a better way to describe) But with the switch installed, should really be no issue. I do mean small amount of force, not anything massive.
#297 7 years ago
Ok, joined the club yesterday, a few questions, anyone have a shooter housing? What paint is best to match cabinet either rattle can or brush?
#298 7 years ago
My saw does not turn much, do you think I need to replace the black rubber band? Or the pulley it rides on?
#299 7 years ago
Should the spin wheel be white or is it an ivory/off white?
#300 7 years ago
Quoted from T2play:
If it turns, leave it alone. It does not turn at 900rpm...
Professor Pinball
$ 29.50
$ 27.95
YouBentMyWookie
Daddio's 3D Printed Mods
Hardware
Filament Printing
$ 18.00
Playfield - Plastics
3,900 (OBO)
Filament Printing
$ 14.95
$ 32.00
$ 18.00
$ 69.99
$ 49.95
Mitchell Lighting
$ 12.00
This page was printed from https://pinside.com/pinball/forum/topic/that-trick-never-works-rocky-bullwinkle-club/page/6 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
