Quoted from amkoepfer:So could a bad bulb socket (or diode if the flashers have diodes) cause a coil to lock on? I would think that if the flashers locked on they would burn up and be not as noticeable. Im going to test mine when i get home after disconnecting the super vuk coil.
I don't think so because the coil circuit and flasher circuit are not connected directly together - the relay board bank-switches between them, but I may be wrong and it is possible.
The flashers don't have diodes because they are DC and are not controlled in a matrix the way the controlled lamps are (like inserts).
RM
