(Topic ID: 149896)
TFTC...too many balls
By transprtr4u
8 years ago
#1 8 years ago
When starting the game ... Error message " too many balls" 6 ball game , with six balls installed?
Any suggestions would be greatly appreciated!
#2 8 years ago
Seems like it has to be a trough switch detected closed when it should be open.
What does switch test say?
What does it say with all the balls removed?
#3 8 years ago
Quoted from cody_chunn:
Good call. Could it also be a closed switch in the shooter lane? So the game thinks one in the shooter, 6 in the trough?
#4 8 years ago
Haven't tested the switch-test,have removed balls ... Screen says 6 balls missing ?
#5 8 years ago
I would also check shooter lane, scoop, tombstone and VUK switches to make sure it does not see all 6 trough balls plus one other phantom ball stuck somewhere in the machine....
#6 8 years ago
Remove all balls. Do switch test.
Add balls one by one. Does the switch test reflect exactly as you add the balls? It's possible there is a bad diode on one of the switches that won't show unless the switch is pressed and could be causing another phantom switch.
#7 8 years ago
I agree with everyone else, definitely a trough switch error of some sort.
#8 8 years ago
Thanks too everybody for the advise and guidance... Will endeavour to rectify this issue over the weekend!
Pinsiders are the best!
Regards
#9 8 years ago
Quoted from futurepinhead:
[Edit] If it's an opto switch, it should read closed with no ball there, and open with a ball present (opposite of microswitches and leaf blade switches).
#10 8 years ago
Thanks again to all ... Problem found "switch 7" broken blade !
Regards part switched out , annoying my wife again with the crypt keepers laughter!
#11 8 years ago
here is a tale of man with 3 balls lol
#12 8 years ago
Quoted from transprtr4u:
Which has been reduced a bit in version 4.00.
#13 8 years ago
Quoted from ChadH:
Quite a bit--now I almost miss all the inane cackling! Almost...
#14 8 years ago
Installed version 4.0 ... If I play it to much it will be " here comes the man with no balls! "
£ 32.00
PinballToys
YouBentMyWookie
$ 26.50
$ 19.95
Mitchell Lighting
$ 18.95
$ 12.00
$ 18.00
Mitchell Lighting
$ 18.95
$ 345.00
Metal-Mods
Playfield - Plastics
Mad Czar Games
Daddio's 3D Printed Mods
$ 27.95
$ 18.95
$ 18.95
4,850
Lake Elsinore, CA
PinSound
Metal-Mods
$ 64.00
This page was printed from https://pinside.com/pinball/forum/topic/tftctoo-many-balls and we tried optimising it for printing. Some page elements may have been deliberately hidden.
