Quoted from Irishbastard:Ok, pulled board, tested Q44 along with Q36 (shooter coil trannys), then both rows of transistors and drivers... All are in spec, all reading similar. Also put one lead to tab of each tranny and ground, no shorts..
Found bad Q5 on PPB, replaced
Played two games, "appears" fine
I meant to tell you to also test the PPB board, along with reflowing solder there, just my A.D.D didn't co-operate.
