just purchased a TFTC. last owner did a lot of work. playfield replaced, all new leds, new power board, lots of mods and pinstadium lighting. everything looks and works great but when getting the pin home and after playing a few games noticed the crypt tombstone doesnt go up or down. looked under the hood and checked for loose wires etc and everything seems good. took the motor and switch assembly apart and nothing broken etc. did the tombstone test in diagnostics and switches for up, down, target all working and when holding start button still no movement on the motor - even tripped the switches manually with no luck. took the whole motor assembly off again and did the test with assembly resting on the side of the machine and with lever removed (lever that couples to motor shaft) tripped the switches manually and watched the motor shaft with no load on it and it did not rotate at all when hitting the start button during the tombstone test. disconnected leads going to motor and did the test again - measured the voltage across the leads and got zero. so after all this i am thinking there is no signal from cpu / relay. i have no idea where the signal is coming from on the board and i am hoping one of u tftc pros can guide me where to measure the signal coming from the board in the backbox and or point me in the right direction at this point.
