I just got a TAles from the crypt this week it has plenty of issues to iron out to get it up and running unfortunately. The tombstone motor is not working it gets power but runs intermittently. The main ball trough has the 6 balls missing issue and let's more than one ball into the vuk at a time the balls don't sit directly above each microswitch as I believe the should. I'm not sure if this is the ball stop solinoid mech adjustment or what here. The laser kicker is not working at all as well as the knocker. The indicator light for the laser kick is also not working. The entire flasher system is not working and I have turned it on in the diagnostic settings as well. I'm just looking for a little help to point me in the right direction. When I hit an eyeball target I hear the ball stop solenoid fire under the apron is that suppose to happen? I checked all of the fuses throughout the machine and they are all good full continuity in all. I can't wait to have this thing working correct. Thanks in advance.
