I don't think it has a knocker
The knocker is supposedly be on the left side of the 8 inches speaker and hitting the wood transversal piece . But i switch mine on the right side wall of the cabinet and hitting down to a piece of hard wood....knock much better and harder
Quoted from PanzerKraken:I don't think it has a knocker
Quoted from Pommy:The knocker is supposedly be on the left side of the 8 inches speaker and hitting the wood transversal piece . But i switch mine on the right side wall of the cabinet and hitting down to a piece of hard wood....knock much better and harder
So there is one? Mine doesn't have one I don't think. The previous owner did some weird shit to the game. Things were removed or cut in order to "quiet" things down. I didn't notice any knocker so would like to get one if the game does indeed have one. But I can't find any evidence (screw holes) or any coils that would be a knocker.
A pic would be helpful to show location and a closeup of the wiring so that I can get one installed.
Nice. Yeah mine is pretty quiet... I should make that adjustment.
Too bad it isn't used more in the code.. Maybe a knock after the door bell.. Or used in some creepy way for a mode.
Quoted from gregcube:I have a knocker in mine. Located to the left of the sub.
Thanks for the pic. The PO must have taken that coil for something else. Gotta get one to replace it. I did see cut purple and brown wires in my game. Much appreciated!
Quoted from koji:Nice. Yeah mine is pretty quiet... I should make that adjustment.
Yeah ! That's why i move it. Now it's a real knocker hit ! And can't imagine a pinball without a knocker....i mean we are playing to beat the score and hear this marvelous kick sound...don't we ?
Swapped in a replacement DMD for now, it flickers but its not garbled. Getting a colorDMD this week. Finally after a month, it's playing again! Lots of route hacks to clear up, needed to do a bit of work to get the launcher to fit well and repainted (From Back Alley Creations).
Such a fun game! Chad code really addresses a lot of the games shortfalls. Can't wait to get the GI smoother board to eliminate Seizure Multiball.
Just a few other odds and ends, but it's almost there.
Quoted from FatPanda:Can someone tell me where the knocker is in this game, or if it has one? I assume so, just can't find it.
The manual shows that the game does have a knocker assembly.
Brn wire 32 volts.
I would look to the bottom left side, just in back of cashbox cabinet wood wall separator.
Mine is in the same location.
Gord
Quoted from FatPanda:Swapped in a replacement DMD for now, it flickers but its not garbled. Getting a colorDMD this week. Finally after a month, it's playing again! Lots of route hacks to clear up, needed to do a bit of work to get the launcher to fit well and repainted (From Back Alley Creations).
[quoted image][quoted image]
When you say "GI Smoother board", do you mean an LED OCD board? I don't see a GI board available for DE, but they do have one for the inserts that I've considered adding to mine.
Quoted from cookpins:When you say "GI Smoother board", do you mean an LED OCD board? I don't see a GI board available for DE, but they do have one for the inserts that I've considered adding to mine.
No, I mean the EnerGI Maestro Board.
https://pinside.com/pinball/forum/topic/led-gi-smoother-for-data-east
It's made by a pinsider and he only does runs when he has enough people sign up for them. The board takes the harsh on/off of the relay and smooths it out so it's not so stroby. It's all user adjustable, so you can adjust the brightness, the ramp up/down time, etc.
Must have for aby DE/Sega game imo.
He'll be doing a run soon and he says it's been slowing down, so I would sign up if you want one.
Need some help. Got a Crypt that needs a lot to get it back in working condition. I can't tell from the manual what these wires go to as I think I'm missing a board? These are on the right side of the cabinet. Second picture is the boards on the left side. Other than reinstalling the on/off switch and plate, what's missing? Thanks!
missing (resized).jpgother side (resized).jpgQuoted from BSavage:Need some help. Got a Crypt that needs a lot to get it back in working condition. I can't tell from the manual what these wires go to as I think I'm missing a board? These are on the right side of the cabinet. Second picture is the boards on the left side. Other than reinstalling the on/off switch and plate, what's missing? Thanks!
Pretty sure those are not connected to anything. There's a printer mapped in the schematics that these might go to, which wouldn't apply here obviously.
The boards on the left side of the cabinet are your shaker motor board (left side) and your flipper board (right side), which have their respective connections accounted for.
And just saw that yout knocker is missing the coil.
And the fuse in F1 on your shaker motor board (right most fuse) isn't needed.
OK. Printer is probably right. Yes, there are several other things missing too like the MPU board. Just wanted to check before I started ordering.
Brian
hello to all of you TFTC fans! I always wondered if it was normal to hear a bit of speech....sound’s live "no'p" only when I put my TFTC on power. My pinball works great...but there's always that "no'p" that keeps coming back once a day...like the beginning of the phrase no pain no gain...your feedback would be appreciated. Thanks gang!
Quoted from Pommy:hello to all of you TFTC fans! I always wondered if it was normal to hear a bit of speech....sound’s live "no'p" only when I put my TFTC on power. My pinball works great...but there's always that "no'p" that keeps coming back once a day...like the beginning of the phrase no pain no gain...your feedback would be appreciated. Thanks gang!
Yeah the audio seems to get clipped when set to freeplay. When on credit play, you hear "no payem no game"
Mine does this as well. Wasn't sure if it was normal or not, but the game works so I didn't really care. When I had my R&M, every time I powered it off, Rick would start yelling something before eventually the power cut out.
I put my game on free play and now my door prize mode always awards 30 million and only one door. How do I get it back to normal but still use Freeplay?
Quoted from MStem80:I put my game on free play and now my door prize mode always awards 30 million and only one door. How do I get it back to normal but still use Freeplay?
Do you have the Tales From The Crypt v.4.00 ROM?
If so...
"If any tournament mode is active then door prize collects 30M and mode ends."
Is shooting the left ramp to advance the right ramp worth it? I haven't looked at the rules. I'm on Chad code.
Love this game btw. I've been playing it a ton over the last few weeks. Honeymoon phase? Sure, but I really love the layout, animations and callouts/SFX/music.
Quoted from FatPanda:Is shooting the left ramp to advance the right ramp worth it? I haven't looked at the rules. I'm on Chad code.
*Sometimes* I guess it depends how difficult/safe the left ramp is for you. I usually like to keep 1 or two levels lit on the right side, so when you hit the ramp in Multiball.. *or* in Electric chair, you can get a fair value out of it.
I think it is the default (and a decent) setting that it resets to level 1 on each ball. In a way, play the organ can be quite a challenge to make it to and collect which is kind of fun.
_IF_ the code could be adjusted so that the frenzy timer would pause during the multiball animation sequence, that would be amazing and would add a lot of viability to keeping the right side stacked)... IMHO-
Quoted from koji:*Sometimes* I guess it depends how difficult/safe the left ramp is for you. I usually like to keep 1 or two levels lit on the right side, so when you hit the ramp in Multiball.. *or* in Electric chair, you can get a fair value out of it.
I can hit the ramp 60-70% of the time. If I'm in the groove, I can hit it 5 or 6x in a row. Just wondering without taking the glass off if hitting it 12x is worth it. I will focus on maxing out the right ramp one of these times just to see the modes, but was wondering if it was a viable scoring option in a typical game.
Quoted from FatPanda:I can hit the ramp 60-70% of the time. If I'm in the groove, I can hit it 5 or 6x in a row. Just wondering without taking the glass off if hitting it 12x is worth it. I will focus on maxing out the right ramp one of these times just to see the modes, but was wondering if it was a viable scoring option in a typical game.
Well frenzy scoring starts at 250k per switch and goes to 1m per switch. It is decent, but IMO, modes and Multiball are what you want.. and when you can introduce a frenzy during a multiball mode.. it's the icing on the cake.
Hi everyone. Have two issues with my Crypt. The right coin door light gets hot and burns out, giving me the ozone smell. But not immediately. It seems to happen after a few games. Possible transistor issue or just a faulty wire?
Second, I hooked up the shaker motor (which I was apprehensive to do) and it’s cool, but man it’s powerful. Is there a way to reduce the setting on it?
Quoted from MydknyteStyrm:Second, I hooked up the shaker motor (which I was apprehensive to do) and it’s cool, but man it’s powerful. Is there a way to reduce the setting on it?
https://pinside.com/pinball/forum/topic/how-to-adjust-a-shaker-motor-on-tftc-tutorial
Quoted from Pommy:Hi @cobrasvs. I power coated mine same color of the handle. Quite a nice look IMO but i hope it will help you
That color powder coat looks amazing on your TFTC. You chose well.
Gord
I’ve been wanting to do a gold vein powder coat on mine just like that. How bad is it removing the side rails? Also curious if it’s possible to put Stern side rails (with the button guards) on this machine. Only wear on my cab is around the buttons, would love to cover it and add protection.
I too like the choice of color for the powder coat. I think that bronze color looks sharp. I've been working on art blades for TFTC. I've never been happy with the ones floating around out there to be purchased. I decided to make my own art blades that include the comic book covers. I have two different versions. (still undecided on which one I want to go with) One has all the comic covers from the series and the other has a little less but larger images. Attached are the ones that are larger images with less covers.
Quoted from Nightmare:I too like the choice of color for the powder coat. I think that bronze color looks sharp. I've been working on art blades for TFTC. I've never been happy with the ones floating around out there to be purchased. I decided to make my own art blades that include the comic book covers. I have two different versions. (still undecided on which one I want to go with) One has all the comic covers from the series and the other has a little less but larger images. Attached are the ones that are larger images with less covers.
These are great
Quoted from Pommy:Hi @cobrasvs. I powder coated mine same color of the handle. Quite a nice look IMO but i hope it will help you
Wow, I never considered gold but that looks absolutely fantastic. Wound you mind a close up of it so I can see the texture?
These are awesome. Love the comic art from this series. A backglass that was similar would be great too.
Quoted from PanzerKraken:How do you get to the light in the start button to change the bulb? Thing perplexes me
With the game off, you grab the white switch/button with the wires on it, kinda work it back and forth side to side, and pull it out from the black housing. It will 'snap' out, and after replacing the bulb you reverse the process and 'snap' it back in, lining up black button tabs with switch button. After you've done it a couple times you'll get a feel for it. I put a red led in mine just to make it even redder-er-er, but leds have that raised plastic ring around them and sometimes are tricky to get into lit button housings. Also, in free play mode the start button is ALWAYS blinking, which kinda annoyed me, so I unsoldered the bulb wires and tapped them into my lit flipper button power, so start button just stays lit.
(sample button pic added)
Thanks guys for your comments !! Sorry for the late respond. I powder coated my TFTC with a Metal Shop in my town. Some pics as wanted. Was supposed to have forged also the head with the same finish but the project is on ice
IMG_1736 (resized).jpegIMG_1737 (resized).jpegIMG_1738 (resized).jpegIMG_1741 (resized).jpegQuoted from Nightmare:Here are the ones that have all the covers. It's a little more busy however.
Great Nightmare !!! Superb idea !!
Quoted from Pommy:Thanks guys for your comments !! Sorry for the late respond. I powder coated my TFTC with a Metal Shop in my town. Some pics as wanted. Was supposed to have forged also the head with the same finish but the project is on ice
Looking great!
Quoted from Pommy:I powder coated my TFTC with a Metal Shop in my town. Some pics as wanted. Was supposed to have forged also the head with the same finish but the project is on ice
Do you know what the powder coater guy called that texture? Crinkle? Pitted?
I'm guessing the head mod would consist of routing a groove in the front edge as if for plastic t-molding, but using 4 pieces of metal 't-molding' trim instead? Or, less permanent, maybe just using flat metal attached with small nails?
pretty cool powdercoat on that TFTC for sale in GA. anyone else done this?
https://pinside.com/pinball/forum/topic/for-sale-tales-from-the-crypt-124
Quoted from Crispy77:pretty cool powdercoat on that TFTC for sale in GA. anyone else done this?
That is pretty neat. I think I’d have to see it in person. I’d still probably prefer the chrome but I have been thinking about shopping mine and adding glow rubbers instead of the purple ones on it. Think this one sold me.
What are the GI lights? I see the bulbs are lit in one of the pictures, but the PF/Plastics don’t really look lit up.
Quoted from miracleman:Do you know what the powder coater guy called that texture? Crinkle? Pitted?
Sorry but I don't know what type or name of the paint finish but it took several steps to get to this result. Regarding the metal head, the guy explained to me that it was necessary to make 2 molds of the original head. The first step was to make a copy of the head in latex and then made the mold which looked like a pumice stone texture in which he was to pour his metal in fusion to make an exact copy. Thereafter, it remained to do the painting..... and all for the ironic modest sum $$$ which is not really worth it
The powder coat style is typically called "veined".
As far as the neon green ramps and habit trails...I'll just say to each their own. They're a little too much for my taste, and I would definitely not buy the game because of it (if I were in the market). But obviously no offense to anyone who does like it.
Quoted from miracleman:With the game off, you grab the white switch/button with the wires on it, kinda work it back and forth side to side, and pull it out from the black housing. It will 'snap' out, and after replacing the bulb you reverse the process and 'snap' it back in, lining up black button tabs with switch button. After you've done it a couple times you'll get a feel for it. I put a red led in mine just to make it even redder-er-er, but leds have that raised plastic ring around them and sometimes are tricky to get into lit button housings. Also, in free play mode the start button is ALWAYS blinking, which kinda annoyed me, so I unsoldered the bulb wires and tapped them into my lit flipper button power, so start button just stays lit.
Thank you!
Quoted from FatPanda:The powder coat style is typically called "veined".
Thank You!
This page was printed from https://pinside.com/pinball/forum/topic/tftc-owners-fang-club-the-morgue-the-merrier/page/93 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
