My Crypt I bought a couple months ago had several cracked or broken plastics, but already had the thicker repro (long) air ball stopper and thicker red plastic. The stopper works fine (I'll likely get one of the new 'shorter' ones), but the back left point of the repro red plastic broke yesterday. The back points of the red plastic support with hex posts the back of the skill shot artwork plastic, which also rests on the bumper cap.
Obviously the back red points take a ton of hits from balls coming from below and above, and the original and repros can be broken.
So since I intend to at some point get a set of CPR repro plastics (and protectors), I decided to cut/file the red points off the red repro plastic and lose the support hex posts. 20201209_222724.jpgThe left side now ends over two posts and the right ends where the playfield wireform ends. 20201209_210830.jpg20201209_221345.jpgI attached the lamp reflector to the left hole of the skill shot art plastic with a screw and locknut, and drilled a small hole through the plastic so that the it can be secured by the right screw of the bumper cap.20201209_222824.jpg Unfortunately the art plastic stops short of the left cap screw because of the lamp underneath. The empty right hole could be filled with a short screw and locknut.
I consider it a mockup for now until I make/modify a nicer red plastic and maybe a longer art plastic, but they both line up, and the two lamp sockets and wiring help hold the art plastic pretty snug in place. Played a few games banging on the targets and all is good.
BTW those one-piece black WMS/Bally reflector sockets are sweet, got 'em at Pinball Life.
