Opto trough board mod complete!! Thanks Davi
A few more mods added. I also rigged my electric chair prop to activate when the shaker motor activates.
Quoted from renoman22:A few more mods added. I also rigged my electric chair prop to activate when the shaker motor activates.
Your game looks amazing. So much attention to detail. Where are the color changing lights coming from in your game?
Quoted from PinballGiant:Your game looks amazing. So much attention to detail. Where are the color changing lights coming from in your game?
Thanks! I installed Pinstadium lights. Highly recommend them for any machine. Made a huge difference.
Quoted from renoman22:Here's a video of the new door handle head in action.
So Mr Renoman kan you make more i WANTS it
Finally just joined the club! Been looking for several years now. Different deals kept falling through, but finally got one.
Not the best condition cabinet, but the playfield and mechanics and backglass are great!
Question, my lockdown bar is a little bent and scratched up. Anyone know where to get a replacement? Is it unobtanium?
The one on marco/pbl seem to indicate it won't fit. Seems weird that they don't make a repro one.
Quoted from damadczar:Question, my lockdown bar is a little bent and scratched up. Anyone know where to get a replacement? Is it unobtanium?
I have been looking to no avail for a nicer/new lockdown bar as well.
Mine is not bent but it was poorly repainted to cover bubbling rust spots.
Will likely strip it down and get re-powder coated.
Quoted from miracleman:I have been looking to no avail for a nicer/new lockdown bar as well.
This?
According to the description of that item, sadly not...
"A few DE games use lockdown bar #500-5021-10. Games calling for that lockdown bar are not compatible with this lockdown bar."
- PinballLife
TFTC, BTTF, JP, and some others require lockdown bar receiver assembly 500-5020-00 .
I do not know if you could replace the original receiver with the one that fits that PBL Stern bar and then use that.
If you COULD, at $70 for the bar and $40 for the receiver you'd be in for $110 to have shiny/black new stuff.
EDIT: I do not think the new receiver has holes for the 2 pf hangers at the bottom of the pf.
Quoted from miracleman:According to the description of that item, sadly not...
- PinballLife
Update. I spoke to Terry at PBL. His words on if the lockdown bar here (https://www.pinballlife.com/sternsegadata-east-black-front-molding-lockdown-bar-no-tournament-button-hole.html) would work:
"Yes, it will fit, but it is slightly different stylistically."
So there you go.
Quoted from Jon9508:I know this might not help. The extra one I got had the measurements written on it. If you know someone with a laser cutter. Maybe you have have one made
I *do* know some folks with a laser cutter. Making sense of this chicken scratch is another issue. . It's likely just messing with my brain since it's upside down.
Appreciate you posting this.
Quoted from damadczar:Does anyone have a spare djshakes air ball plastic? He said he's done with all that, and I need one since my TFTC doesn't have one.
Thanks,
Steven
That airball plastic makes a world of difference! Gluck in your search.
Quoted from damadczar:Update. I spoke to Terry at PBL. His words on if the lockdown bar here (https://www.pinballlife.com/sternsegadata-east-black-front-molding-lockdown-bar-no-tournament-button-hole.html) would work:
So there you go.
AWESOME!
Take pics of it on your game when you get it, if it looks good it will save me the paint stripping and powdercoating,
Could someone post a picture of this airball plastic in the machine?
I think i am missing it (but didn't know it existed). Only recently joined the club.
Quoted from Phantasize:Could someone post a picture of this airball plastic in the machine?
Thank you very much. I definitely don't have that one. Is it an original piece, or did I misunderstand?
Quoted from Phantasize:Thank you very much. I definitely don't have that one. Is it an original piece, or did I misunderstand?
No. It isn’t original and doesn’t come with the plastic set either. DJshakes use to make these but I think he isn’t doing another run.
Agreed, it is not a factory original piece, it was made by owners afterwards to prevent the ball from bouncing into the above plastics or nearby ones causing breakage or damage.
One or two people on pinside have made and sold the clear and the red plastic above it here and in the marketplace.
They sold out but if someone has an extra they usually post it FS in this thread.
I will say that both that came on the game I recently purchased have mounting holes that are too big, the locknuts can tighten down into the hole. So I have added washers above and below the holes. Also with the clear protector and red repro plastic being thicker than the normal plastics the nut barely had enough post thread showing to tighten, so I bought two posts from Pinball Life with a taller thread on top.
https://www.pinballlife.com/machine-poststud-530-5008-00.html
530-5008-00 (resized).jpgIf anyone else has a speaker hum on their TFTC I just wanted to pass along how I got rid of most of mine. There are plenty of in depth forums about this too. I just added a 12V buck boost converter on the +12V to the sound board and had great results. Cleaner and cheaper than an entirely separate power supply and plug and play after you build it.
Since I had to take off the door handle to remove a lockdown bar receiver bolt to re-paint, I took some pics of it. Save 'em on your phone so in case you find something out in the wild you can check the pics.
20200923_230347 (resized).jpg20200923_230422 (resized).jpg20200923_230510 (resized).jpg20200923_230928 (resized).jpg
Quoted from PinballGiant:If anyone else has a speaker hum on their TFTC I just wanted to pass along how I got rid of most of mine. There are plenty of in depth forums about this too. I just added a 12V buck boost converter on the +12V to the sound board and had great results. Cleaner and cheaper than an entirely separate power supply and plug and play after you build it.
[quoted image][quoted image]
Where did you get the buck boost? Looks like you added the connectors...and the box? Just looking for some more info...btw, what power supply do you have in your Crypt - original or aftermarket? I found a huge improvement by ditching the stock power supply board for an Xpin....
Matt
Quoted from Sonic:Where did you get the buck boost? Looks like you added the connectors...and the box? Just looking for some more info...btw, what power supply do you have in your Crypt - original or aftermarket? I found a huge improvement by ditching the stock power supply board for an Xpin....
Matt
Yes, just added the two connectors. The 5v and -12V go straight to the board and the +12V and ground go to the buck boost converter in the plastic box and then to the board. I tried to explain it with visuals in the video too.
Here is a list of my supplies:
6-pin z connector
2 female 6-pin 0.156 molex connectors with trifurcon pins from pinball life
Buck/boost converter from amazon (https://www.amazon.com/gp/product/B07NTXSJHB/)
ABS plastic project box off amazon
18 or 20 gauge wire
It's funny you say that. I have a Rottendog board and had read that the aftermarket boards were worse for the hum than the originals. Interesting.
Quoted from PinballGiant:Yes, just added the two connectors. The 5v and -12V go straight to the board and the +12V and ground go to the buck boost converter in the plastic box and then to the board. I tried to explain it with visuals in the video too.
6-pin z connector
Buck/boost converter from amazon (amazon.com link »)
18 or 20 gauge wire
Rottendog perhaps, but Xpin - no...very different boards in the way they get things done (I'm not a great fan of RD boards, just my opin)....it wasn't my goal to reduce hum - it was an aftereffect that was noticeable when I replaced the original with the Xpin....
Mmm, after a lot of play the tombstone starts giving hits even if the ball is dancing threu the popbumpers. Hitting it once gives 2/3 or 4 hits.
Switch broken?
Should i try to bend the arm of the switch?
Quoted from Indepocket:Mmm, after a lot of play the tombstone starts giving hits even if the ball is dancing threu the popbumpers. Hitting it once gives 2/3 or 4 hits.
Switch broken?
yes sounds like the switch needs to be adjusted
Left the club, unfortunately, but what a fun game with Chads code installed.
Have a new set of cliffys, never used, not sure what they are new? Thinking $65 with shipping?
Where do you get the toys i like them
Quoted from Indepocket:Just got mine out of storage, 3 years of collecting dust. Had it checkt out and having a blast now.
Great find this forum, lots of things still to do!! Already started to incorperate some fun!
Quoted from Don44:Does anybody have airball plastics or the red plastic behind drop targets they would part with?
I'm currently reproducing about 20 of each that I plan to offer for sale shortly.
Quoted from damadczar:I'm currently reproducing about 20 of each that I plan to offer for sale shortly.
I would definitely be interested. My ball is constantly flying in the air
Okay. Prototype art pieces fitted. Final plastics soon. Gonna make holes like 1/32 or 1/16 smaller as they are way too big.
Also, the large airball piece that was cut is similar to the original one offered. But I think it's just too big. I measured with it in place and it hangs too far out for me. So I measured where a ball would hit the drop target and am going to shave some off the end.
There is no reason for that plastic to extend that far out. I'll ensure it completely covers the ball, and that's it.
Also, I'm thinking of printing the red piece orange instead. Seems like it'd match better.
Thanks,
Steven
Quoted from damadczar:Okay. Prototype art pieces fitted. Final plastics soon. Gonna make holes like 1/32 or 1/16 smaller as they are way too big.
Thanks,
Steven
Looking pretty awesome
Here is my TFTC that I purchased about 2 months ago. So far I have replaced the Tombstone motor, upgraded to LED lighting, color DMD, replaced all rubbers and added some playfield mods and fixedxthe coin door. I used to play this a lot when I was younger. I could never afford to purchase a machine until now. Being in the high risk category for COVID complications, Ive been staying at home when I'm not at work. Having this machine has made a world of difference for me. It keeps me busy and gives me something to do. Ive learned so much reading all your posts. Im saving up for another horror related theme machine. What do you think? What's the next best pinball machine to own that has a horror theme?
20201025_220933 (resized).jpg20201025_220944 (resized).jpg20201025_221006 (resized).jpg20201025_221014 (resized).jpg20201025_221026 (resized).jpg20201025_221040 (resized).jpg20201025_221121 (resized).jpg20201025_221133 (resized).jpg20201025_221154 (resized).jpg20201025_221205 (resized).jpgQuoted from emarfniam:Here is my TFTC that I purchased about 2 months ago. So far I have replaced the Tombstone motor, upgraded to LED lighting, color DMD, replaced all rubbers and added some playfield mods and fixedxthe coin door. I used to play this a lot when I was younger. I could never afford to purchase a machine until now. Being in the high risk category for COVID complications, Ive been staying at home when I'm not at work. Having this machine has made a world of difference for me. It keeps me busy and gives me something to do. Ive learned so much reading all your posts. Im saving up for another horror related theme machine. What do you think? What's the next best pinball machine to own that has a horror theme?
I love horror theme pins and cannot recommend Bram Stoker's Dracula strongly enough. It's one of my long term keeps. And once you get BSD, you should get a Creech to go with it. But if you're looking to buy newer, you can't go wrong with Monster Bash remake.
What kind of LEDs did you put in? I just recently put in 2SMD Frosted comet in my inserts, and it's just too bright. I guess I need to buy some 1SMD? Yours looks good.
Quoted from damadczar:I love horror theme pins and cannot recommend Bram Stoker's Dracula strongly enough. It's one of my long term keeps. And once you get BSD, you should get a Creech to go with it. But if you're looking to buy newer, you can't go wrong with Monster Bash remake.
I just ordered a kit off of pinballbulbs.com. i was reluctant to order a kit but I love the way it turned out the kit was so well put together and made install so easy. I played BSD a long time ago. I remember it having a ball float across the playfield and "winds...winds...winds!" I will definitely be keeping my eyes out for one.
Quoted from Mister_Swede:Where do you get the toys???????
The zombie is from ModFather...the rest I made. The crypt keeper head is off a old candelabra...i made the skull piles from a 2 dollar bottle opener...it is hard resin...drilled a hole in it and added a post screw...dollar store spider i painted and dilled holes to mount...
Tales from the crypt magnet that I attached with black heavy gauge wire and attached to right ranp, the little figures are from Halloween village display...
This page was printed from https://pinside.com/pinball/forum/topic/tftc-owners-fang-club-the-morgue-the-merrier/page/76 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
