New! Dark mode!
(Topic ID: 55059)
TFTC OWNERS: "Fang Club" - "The MORGUE, the merrier!"
By E_N_3
7 years ago
  • 3,797 posts
  • 309 Pinsiders participating
  • Latest reply 3 hours ago by emarfniam
  • Topic is favorited by 127 Pinsiders
There have been 1,210 images uploaded to this topic. (View topic image gallery).
There are 3797 posts in this topic. You are on page 69 of 76.
#3401 1 year ago
Quoted from Sgtmax:
Hey guys
how do I contact chad in regards to the updated code for my tftc?
You can see the changes, donate, and download the patches at Pinballcode.com
I can help if you don't burn your own roms.
#3403 1 year ago
How about the extra ball button below the start button? When does that come alive if ever?
#3404 1 year ago
Quoted from MG7322:
There is an adjustment you can make in the game settings that allows the player the option of buying one extra ball after their game has ended. Normally they would have it set for 25 cents or 50 cents for an extra ball. You would put your money in and hit the extra ball button to get a 4th ball without the game resetting your score.
#3405 1 year ago
Is anyone elses TFTC knocker sound weak. Compared to my other pins this is the weakest. I haven't even raised the playfield yet to look at it to see what coils in there or anything. Just wondering if this is a common thing for this game
#3406 1 year ago
Quoted from fatality83:
Mine is strong and loud.
#3407 1 year ago
Quoted from Boat:
Ditto.
#3408 1 year ago
Mine was very weak as well.
#3409 1 year ago
Quoted from Jon9508:
Joined the club today. I am going through the machine and I am having a problem with the scoop shoot kicking back. It doesn't kick back to the flippers but instead it kicks out to the right towards the upper flipper. Kinda strange. I inspected the scoop for warped or a broken weld and also looked at the coil. Both look good to me and cant seem to find a problem with it. Has anyone else encountered this problem before?
Mine had a similar problem but fixed it with a VUK rebuild kit and new solenoid. It was pretty easy to do and you can get the parts from Marco. The part numbers are in the TFTC owners manual.
#3410 1 year ago
Quoted from Cyrus:
Thought I deleted that comment.
Yea it ended up being a worn/dished out plunger. I swapped it with my knocker plunger. Seems to be working fine now
#3411 1 year ago
Still looking for a set of reese rails for TFTC.
Condition doesn't matter. Thanks!
#3412 1 year ago
Anyone do the chad h code? I think I am doing something wrong. I downloaded the 3.03 roms from IDPD and extracted them. I then downloaded the patched files and extracted them. I got that lunar IPS patch tool It says select IPS file, I navigate to where the patched 4.0 cpu file is and select it. It then brings up a new box, select file to patch. I navigate to the Tftc original 3.03 rom, I have to select show all files because they don't show up on this list. I select TFTC 3.03 which is listed as a 303 and the other one is listed as a 301 file. It gives me a message it was patched. It creates a new text file. I load that new file in the rom burner and burn it to it, but it isn't working.
#3413 1 year ago
I tried burning the 3.03 rom from IDPD and when I start the game it says unofficial for the version
#3414 1 year ago
I may be figuring it out. After you patch the file you need to load the file that is located where the original 3.03 rom is and not the new created text file
#3415 1 year ago
Left the club over the weekend. However I think I will be joining a new one.....Casters club perhaps
#3416 1 year ago
Yup I figured out what I was doing wrong. I didn't know I had to burn the original rom file instead of the new tex file created by the patch program.
#3417 1 year ago
Can y'all help me out with an accurate LED bulb count list for TFTC. I'm trying to make a comet pinball order soon. Any help would be appreciated. And or any recommendations on bulb types and colors for certain area. Please let me know.
#3418 1 year ago
Does anyone have an extra airball plastic that they are not going to use? Maybe you bought a couple and would like to sell one. Since I put a set glo balls in my game they like to fly everytime I hit a drop target.
#3419 1 year ago
#3420 1 year ago
Quoted from bigcat68:
I’d be interested too! Mine has a lot of green and uV lamps that I’d like to change up.
#3421 1 year ago
Quoted from MG7322:
I just went by the manual when I made my recent order. (TFTC manual page 39)
#3422 1 year ago
Put up a monster score on tuxedomask23 ‘s Tftc last night!
#3423 1 year ago
Quoted from Boat:
Put up a monster score on tuxedomask23 ‘s Tftc last night![quoted image]
I witnessed this greatness!!
#3424 1 year ago
Damn you boat!!
#3425 1 year ago
Well I finally hit crypt jam tonite!! It took me nearly two years but it finally happened!!
#3426 1 year ago
How is this game fully loaded not valued at 4k+? I’d rather play TFTC than 90% of my collection! Such a fun tourney pin with the Chad code! She’s a top 10 for me!
#3427 1 year ago
Quoted from MeNaCeFiRe:
Agree 100%. Most die hard Williams/bally fans will glance over because it’s data east.
If you guys have future code suggestions I will compile them and try to convince chad to do another release!
#3428 1 year ago
Quoted from Boat:
Honestly, what would you change on the Chad code???
#3429 1 year ago
Got a problem with my tales. I lost one of my columns. Controls the tombstone, skull cracker , left spinner. Q51. I replaced the tip and the switches are working. Now while checking the diagnostic every time a flasher is triggered it does a coil. So the game goes nuts while trying to play. Everything is firing off. Tombstone doesn't move up and down now. Any ideas?
#3430 1 year ago
I had to adjust my tombstone switch and clean it. It wasn't registering hits half the time. I got it to where it registers most of the time. A lot better then it was.
#3431 1 year ago
Quoted from TheHueManatee:
I took mine to the NW Pinball and Arcade Show this weekend with a For Sale sign on it. Before I packed it up I got to Crypt Jam 'manually' and rocked out to the funky tunes. It was 40 minutes after the show opened that I was contacted by an interested collector, that says something about how great this game is. Good bye TFTC, it's been fun and gory. The new owners are opening up an arcade in Vancouver, BC so I'll get to visit it on occasion.
#3432 1 year ago
Quoted from Gogojohnnyquack:
What do you mean by getting crypt jam "manually?" Hand fed it to crypt jam just to listen to the tunes? lol, if so that's funny.
It's such a fun pin. Gory, funny, punny, absurd, politically incorrect and somewhat deep. I'll never get rid of it. Even if I changed my mind one day and wanted to sell it, the wife wouldn't let me.
#3433 1 year ago
Quoted from mymalibu:
I feel like you'll be regretting that decision.
#3434 1 year ago
Yeah, used a ball and my fingers to push everything. It took a while even manually!
It was a super clean example with great cabinet art and no wear. I very much enjoyed it but when I went down to play I ended up on The Walking Dead (Pro) or Lord of the Rings . Plus, I finally have my Judge Dredd overhauled and playing, I am babysitting my buddy's Dialed In, and I have an Indiana Jones: The Pinball Adventure that I'm updating with LEDs, Pinstadiums, and ColorDMD for someone. It's a full house and Tales from the Crypt unfortunately had to go to make room.
#3435 1 year ago
That's just the way she goes
#3436 1 year ago
Check to make sure the diodoes on those coils/ components are not touching metal where they shouldn't be. ie shorted.
#3437 1 year ago
I made a post a few back, mainly mode stacking improvements, game balancing for video mode, more high score modes/features.
#3438 1 year ago
Quoted from Boat:
Yep. I must have shorted out a flasher bulb. It fried the tip122 that controls the relay. Q29. Replaced it and it's back. I didnt know that data east games are multiplex on the first 8 coils. That's what was throwing me off.
#3439 1 year ago
Got another good one at my house! Lol
#3440 1 year ago
Quoted from Boat:
Got another good one at my house! Lol[quoted image]
I got your tftc high score fever!
#3441 1 year ago
I just noticed there is a diverter in the very back. When does this diverter activate and what for? It appears to be off the playfield too much to do anything
#3442 1 year ago
The diverter will only be enabled when you spelt out crypt by bashing the tombstone and multiball is ready to be awarded. Then....when you fire a shot up the right spinner, the diverter will activate and stop the ball from going into the pop bumpers and will divert the pinball down into the upper right VUK. This gives you a chance to fire the pinball into the tombstone from the upper right flipper to get multiball.
#3443 1 year ago
Soon to be new member of the club! Scrolling through the posts, I have a few questions.
1) Does anyone still have the airball protectors for the drop targets? The one I'm getting doesn't have one and is missing the plastic behind it as well.
2) Did the Hazzard pinsound mix ever get complete?
3) Has anyone put a pinwoofer kit on it?
#3444 1 year ago
Quoted from Joniano:
Cant find the airball protector. I have been looking for a month now. The guy that made them does have a few red plastics left. I ended up buying it from Ebay though.
#3445 1 year ago
I have a TFTC topper i was hoping to brighen up a little. I hope someone can tell me if adding additional LED flashers (3) and a uv led strip to GI may cause problems in these DE machines? From my limited understanding, even LED's, can cause some voltage drop issues causing the sound issues? Alternatively I was looking at an Arduino run lightening simulator completely separately, maybe triggered by the shaker motor.
On a separate note, I recently refurbed the cabinet, added nvram and rom and now notice the crypt keeper is cut off mid sentence when I turn the machine on. I had this problem a few years ago but was fixed during a service and now suddenly returned. Does anyone have any ideas?
Thanks for any help.
#3446 1 year ago
Quoted from CryptKeeperAUS:
I just tied everything together using the matrix system. Then attached it to my 5 volts on my power board. I didnt added any flashers. Just the LEDs.
#3447 1 year ago
I believe that's normal with the new 4.0 Chad roms. Mine does the same....kinda sounds like "no pets..." and then he gets cutoff.
#3448 1 year ago
“No payem, no game”
It’s the sound board booting/rebooting. As far as I know that’s normal. I have nvram as well.
#3449 1 year ago
I just tied everything together using the matrix system. Then attached it to my 5 volts on my power board. I didnt added any flashers. Just the LEDs.[quoted image][quoted image]
Nice work. Thanks for sharing the pics. Looks good with the candelebra keeper!. I beleive there are 3 to 4 different flasher sequences running at 13v that could be attached to.
#3450 1 year ago
Thanks. Nice to know im not the only one. I did have the same issue years ago. Glad it isn't a sign of an underlying problem..
€ 95.00
FlipperLED
£ 32.00
