Quoted from Antennaejim:I've never seen this issue before as it worked perfectly fine with the original dmd! Any thoughts as to what the issue may be? Everything is hooked up correctly.
Curious if it works the same when you install the old DMD? Wonder if something happened when you installed new one. I plan on getting LCD and curious if this will be a potential problem.
