Quoted from pinchamp:Had to steal post 1000... never done that before. No idea why but so the opportunity so had to go for it.
Peace,
The DEVIL made you do it right?
Peace,
Quoted from MustangPaul:The DEVIL made you do it right?
Yeah for sure! He also makes me take a photo of my car odometer when it turns from 99,999 to 100,000
Haha
Quoted from pinchamp:Yeah for sure! He also makes me take a photo of my car odometer when it turns from 99,999 to 100,000
Haha
Oh I've done that too.
Anyone have a picture of the coil under the playfield arch? I put in all of the ball trough switches tonight as they were all gone, and the game now has some really strange behavior that wasn't there before, and I'm hoping that is it. Here is what it is doing, in case anyone recognizes the problem:
Before when the ball trough switches were all missing or unattached, when I turned on the machine I could go through test mode and see what was going on, no problem. The tests would all work, yada yada. Everything else more or less worked, the flippers are still a bit wonky because I need to switch their EOS switch, but tey are functional enough.
Today, I swapped all new switches onto the trough (following the pics from Chad before, thanks again!) and I the game recognized the balls... but it wouldn't kick them out. The under the arch coil is consistently energized, which is bad (obviously). I finally detached it - it was not an issue before the trough switches were replaced, which I think is odd. I also think it's odd that it didn't blow a fuse - it was on for a minute before I found it.
The second thing is that it's locking on some flashers, specifically the ones behind the eyeball targets, however again it's unique - when I start the game, it works just fine, including flashing them with the light show for the ball launch, but after about four or five times, it locks them on (one on each side and one on the backbox). As far as I can tell, there are no other lock ons.
I'm thinking I need to check for transistors being there and orientated correctly tomorrow, but I don't understand why adding the trough switches properly would suddenly make all this stuff happen. I can swap boards from JP, but don't want to yet. Anything I'm missing?
I'm *so close* to getting it functional, this is annoying. Oh, and I need some good US roms for it, running the tests in whatever language it's in is weird.
Try changing the bridge rectifiers that hook up to the big blue capacitor (or at least test them). They cause weird things to happen when they go bad, and they go bad a lot on DE machines. The flasher and coil issue makes me think it is definitely a bridge rectifier issue!
Quoted from goatdan:Anyone have a picture of the coil under the playfield arch?
can someone post a pic of your eos on your flippers or just tell me how to hook them back up, someone cut them on my machine before I bought it, I would like to hook them back up, I have the new switches , I just need to know where the colored wires get hooked up and do I need a diode on there also , thanks
I have always been a fan of the TFTC series and finally got a chance to play this machine at the local arcade. I think my wife approves of it because she said I could get one instead of taking her out on our anniversary this year! (might need this in writing) Needless to say I am now looking for one of these for my game room and hope to be part of the club soon.
Quoted from h3xd:I have always been a fan of the TFTC series and finally got a chance to play this machine at the local arcade. I think my wife approves of it because she said I could get one instead of taking her out on our anniversary this year! (might need this in writing)...
My suggestion--do both, they never forget...
Quoted from h3xd:I have always been a fan of the TFTC series and finally got a chance to play this machine at the local arcade. I think my wife approves of it because she said I could get one instead of taking her out on our anniversary this year! (might need this in writing) Needless to say I am now looking for one of these for my game room and hope to be part of the club soon.
WATCH OUT...IT'S A TRAP!!
Quoted from Mudflaps:75% of my balls are going SDTM after the plunge into the drop targets. The follow up ball is usually okay. Anyone else have this issue? I may need to adjust the incline... I just inboxed the game after a move.
Recheck your level and incline.
Easy adjustment. The metal ball guide where the ball launches, remove the top most screw and then bend the guide to correct the shot. I leave my screw out and every so often need to slightly bend the guide to correct the shot. Was a major issue when I first got the game. Everyone would get annoyed at the SDTM even though the ball save is generous and one of the relaunches would be fine.
Thanks for the tips. I'll readjust the incline and check the guide plate.
I really enjoy this game. There is so much to do and so much to shoot for!
Quoted from Billy16:I find myself playing this one more than any of the others...not sure why!
It's a great game.
I'm not sure I'm loving the look of that many eyeballs. I think it would look better with a more diversified look.
I will say that I purchased the PVC toys mentioned earlier in the thread (seen here: ebay.com link: itm ), and the caldron model looks absolutely fantastic with a green LED jammed in the middle. It looks like it was designed for the pin.
Quoted from bobbyt:has anyone else done the eye ball mod yet? looks great when they are lit up with the led'sI'm not sure I'm loving the look of that many eyeballs. I think it would look better with a more diversified look.
20140905_094158.jpg 308 KB
20140905_094143.jpg 220 KB
Yea too many eye balls for me !
Halloween is coming so should be a chance to pick up a topper and some other bits!
Quoted from urbanledge:Halloween is coming so should be a chance to pick up a topper and some other bits!
My thoughts exactly, but I'm going to wait til after Halloween when stores are discounting stuff to get rid of it. Previous years I've seen some foam skulls and other good stuff that'd work well for the pin....I just didn't own the pin at that point.
Spirit Halloween has great stuff for this game. Wait until the day after Halloween and the entire store is 50-75% off.
Ever get the feeling that you're being watched?
Quoted from PoMC:Spirit Halloween has great stuff for this game. Wait until the day after Halloween and the entire store is 50-75% off.
What's a sprit Halloween?!!
It is a merchandiser here in the US that sets up storefronts in vacant buildings in many cities just before Halloween and sells Halloween merchandise. It is a very cool store--but kind of pricey. http://www.spirithalloween.com/
Anyone overwhelmed by the flashing when multi-ball is ready (and a few other times I think)?
My TFTC is loaded with bright LEDs which are fine normally but when that steady flashing starts it's way overkill/headache inducing unless the room lights are maxed out. I changed adjustment 35/flash lamps to off and it still happens.
Any way to reduce the flashing overkill or do I just need to start pulling bulbs?
Quoted from gtown:Anyone overwhelmed by the flashing when multi-ball is ready (and a few other times I think)?
Yes there is and I just did it a few days ago. You need to pull one of the plugs on the right side of the power supply. This will disable the relay that causes the flashing. Instead the lights will remain on. Totally fixed the issue for me! If someone knows which plug it is post here otherwise I'll double check when I get home.
Quoted from gtown:Any way to reduce the flashing overkill or do I just need to start pulling bulbs?
i just picked up 2 new blue plastic domes and blue flasher bulbs to dim down that flashing a bit, I still didn't install them yet but I am hoping it cuts down on that bright flashing, I will let you guys know if It works out or not
Huge thanks to you both, we will definitely put both of those suggestions to work. Great to know there's an easy fix and we're not the only ones driven crazy by it. Fangs for the help!
Did quite a few modifications on my TFTC. I put clear star posts on the sling shots with clear rubber. I took both rubber sleaves off the captive ball and put two glo balls in there. I added a couple of spotlights, blue LED strips and scoop lighting. I changed the pop bumper caps to clear with blue LED rings and outfitted all GI and spotlights to black lights. I put a couple of glo balls as well and they move fast. I took out most of the lights in the back box and disconnected some of the strobing effects shown above. I played it in total darkness and boy was it fun!IMG_20140913_034310.jpg
Quoted from holmstarrunner:Did quite a few modifications on my TFTC. I put clear star posts on the sling shots with clear rubber. I took both rubber sleaves off the captive ball and put two glo balls in there. I added a couple of spotlights, blue LED strips and scoop lighting. I changed the pop bumper caps to clear with blue LED rings and outfitted all GI and spotlights to black lights. I put a couple of glo balls as well and they move fast. I took out most of the lights in the back box and disconnected some of the strobing effects shown above. I played it in total darkness and boy was it fun!
Nice! I was going to go with glow balls too but wasn't sure how they would affect gameplay since they are lighter than the standard ball. Do you notice a difference? Is it a good or bad difference?
Quoted from AndHart120:Here you go. Second plug from the top on the right. Unplug this and you eliminate the headaches of flashing GI.
Awesome! Thanks for sharing! I always thought there would be a way to trick the relay or something. I can't wait to try this out on my next DE.
I may join this club again soon. Any way to reduce the crypt keeper cackling? We all love him but if I remember before it drive me crazy hitting the left ramp.
Quoted from billsfanmd:I may join this club again soon. Any way to reduce the crypt keeper cackling? We all love him but if I remember before it drive me crazy hitting the left ramp.
You can remove the wire gate or disconnect the gate switch.
Glo balls definitely play different. I put two in the captive ball and only two in the playable balls. I like having the difference as they play faster and put you on your toes. If you nail the left ramp, it's very satisfying as it really rips around. It's hard to describe the difference but they seem to go smoother around the ramps/habit trails. Maybe because they make a different sound on the metal.
Quoted from PoMC:You can remove the wire gate or disconnect the gate switch.
I did that before but does that make hitting the ramp not register ? Or is switch just fir cackle
You will lose out on points by disconnecting switches. It can add up when you are in a mode awarding 1 million points per switch.
Quoted from Billy16:I've found after a while you just sorta get used to the insane cackling and live with it...
Not if I have my way.
Quoted from ChadH:Not if I have my way.
Oh Chad, you gonna mess with the program and make it a better game like with DE Star Wars?
Alright! If you do some code manipulating, I'm sure it will be well received. Some of the scoring could be more balanced, the captive ball and the right ramp made more fair, Crypt Jam more attainable. etc. Have at it!
Quoted from Billy16:Alright! If you do some code manipulating, I'm sure it will be well received. Some of the scoring could be more balanced, the captive ball and the right ramp made more fair, Crypt Jam more attainable. etc. Have at it!
And combos added to game
Combo is a cool idea!
There is a combo for two orbits isnt there?
one for left ramp/right ramp would be nice too.
Has anyone ever heard the Cryptkeeper say "put a little meat on your bonus" when you increase your bonus multiplier? Or any other time in general?
Quoted from ChadH:Has anyone ever heard the Cryptkeeper say "put a little meat on your bonus" when you increase your bonus multiplier? Or any other time in general?
I've had my game for a couple years now and never heard that any time. I'm on latest rom revision.
Quoted from brad808:I've had my game for a couple years now and never heard that any time. I'm on latest rom revision.
ditto
ChadH, sounds like you are doing some serious digging around. That mean you are gonna do some new code? Don't tease us--just do it, dude!
This page was printed from https://pinside.com/pinball/forum/topic/tftc-owners-fang-club-the-morgue-the-merrier/page/21 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
