(Topic ID: 643)
TftC not working
By Phil
14 years ago
  • 38 posts
  • 18 Pinsiders participating
  • Latest reply 11 years ago by markmon
#1 14 years ago
Hi All,
My TftC machine has stopped working and was wondering if you could help me.
I was playing and all was fine with the machine, when suddenly there was a "pop" and the machine froze. Now when I switch the machine on the d.m.d just displays random dots and there is still power to the backlights and the various lights on the playfield but nothing happens when I press any of the buttons.
Initially I checked the fuses and they all seem to carry current. I noticed that when I switch the machine on, none of the 3 LEDs on the CPU board light up at all. So could it be that there's a problem with power to the CPU board and if so what could the problem be if it's not a fuse?
Thanks,
Phil
#2 14 years ago
Do you have the manual? Most likely the LEDS on the CPU board are feedback to what the other boards are or are not doing. Since those lights aren't working I would assume something blew on your CPU board.
Check this link out
http://www.pinrepair.com/de/index2.htm#poweron
Apparent CPU "Failures".
On Checkpoint to Guns N Roses (all games with small 128x16 and mid-sized 128x32 dot matrix displays), there is a unique problem that can make the game look very broken. Random horizontal lines and garbage can be shown on the dot matrix display (but actually the game's CPU has booted correctly and is working OK). On games with the small 128x16 displays, random horizontal lines can appear first, followed by the entire display lighting and staying lit.
If the backbox 18 volt lamp matrix fuse (8 amp slo-blo, with the blue/white wire connecting to the fuse holder) fails, this can cause the dot matrix display to "crash", causing these problems. Another way to identify this problem is the lack of any playfield CPU controlled lighting. The game will "play" (that is, the game will start and play balls), but with score display problems and no CPU controlled lamps. Simply replacing the 18 volt lamp matrix fuse (in the backbox) will fix this problem (providing the associated components such as the bridge and capacitor are OK). If there is a lamp matrix power short, or the lamp matrix backbox bridge is bad, the problem will need to be fixed or the fuse will continue to immediately fail.
This problem occurs because the +12 volts needed for the dot matrix display is generated by the 18 volt lamp matrix bridge and the capacitor/fuse bolted inside the backbox (through connector CN5 on the power supply). The 12 volts generated by the power supply board (for the sound board which comes from connector CN6), does not provide this voltage to the dot matrix display! Hence the power supply could be working perfectly, and this problem could still exist.
A Babcock 128x32 display where the 18 volt lamp matrix backbox
fuse has failed. Notice the horizontal "garbage" line across the
bottom center of the display. This problem only seems to affect
the Babcock brand dot matrix displays.
Interestingly, on 128x32 displays, this problem will only occurs on games with "Babcock" brand dot matrix displays. The 128x32 displays made by Cherry and Dale seem unaffected by a failed 18 volt backbox lamp matrix fuse. This happens because the Babcock displays require 12 volts to function, where Cherry and Dale 128x32 displays do not. This problem can also arise on Cherry brand 128x16 dot matrix displays.
This stange problem was solved with the advent of the 192x64 super-sized dot matrix display (Maverick to Batman Forever). An additional backbox 18 volt fuse (F3), bridge and capacitor was added. This backbox voltage supplied power to a switching power supply, implemented on the 192x64 DMD display driver board. This way if the lamp matrix (F2) fuse failed, the dot matrix display remained unaffected.
The Game Will Not Boot or Stops Booting.
On games Simpsons and before, the game just will not boot. The GI lights come on (and if the game has a dot matrix display, EPROM version is show), but little else happens. There is something wrong with the game CPU board.
First check for +5 volts on the CPU board. The voltage range should be 4.9 to 5.1 volts. Test for this voltage at the +5 and ground test points, just to the right of the battery on the top of the CPU board. If there is good +5 volts, next check the power on LED flashes, to see if they give any information as to the cause. Turn the game on and immediately examine the LEDs.
#3 14 years ago
Could you describe in some more detail what happens when you turn the game on? And most importantly, does the display show any info before it goes "nuts"?
#4 14 years ago
No LED's on the CPU = No 5 Volts.
On the power supply you have a 12pins square connector. I thought is was CN1. Big chance that this one is the problem. Try to reseat this connector. If this is the problem you have to replace this connector.
Thare are a couple of testpoints on the powersupply in the right top. Check for +5 VDC.
#5 14 years ago
Thanks for the responses everyone
@ eabundy: I'd seen that link too and initially thought this was the problem as I do see "Random horizontal lines and garbage...on the dot matrix display". But then I checked all the fuses with a multimeter and they all seemed OK.
@robin: When I switch it on, not much happens. Various lights on the backboard and the playfield (non-CPU controlled I assume) switch on and the DMD instantly displays random crap. And that's it. No info on the display at all I'm afraid.
@ Benboogaard:I checked out CN1 and there is no 12 pin square connector there. Instead, it looks like the various wires have been taped together and soldered directly to the board. I've not yet checked the testpoints on the powersupply. But it's too much of a coincidence that you suggest checking CN1 and I find it in this condition so I'm guessing that the problem is here? Although I couldn't see which, if any, of the wires had come loose.
I'm not technically minded so what's the way to sort this out? Apart from haranguing the company I bought it from...
#6 14 years ago
Get the schematic from here:http://www.ipdb.org/search.pl?any=tales+from+the+crypt&sortby=name&search=Search+Database&searchtype=quick and start checking one wire @ a time to that location.
I'll take a pic of the suspected area and how it's wired on my machine for you. Will post later today.
#7 14 years ago
Are you able to post pictures of the area of those connections? (And, www.flickr.com, run by Yahoo, is a good FREE service that allows uploading to host your pictures). Sounds like a hack job has been done at some point.
#8 14 years ago
I'll try and take some pictures so you can check it out.
#9 14 years ago
My Future Spa had the wires soldered directly to the pins on J1 connector and also right to the circuit board where the pins were missing. I had to resolder on new pins and a J1 connector, plus the real problem which were the bad Bridges. I know these are different boards but if you don't feel up to the task of rebuilding a circuit board, you should contact [email protected] or [email protected] to see how much they will charge to fix and upgrade it. They both do reall good work, and super quick turnaround. Ship it on Monday and you will likely have it back by the weekend. They will probably want pictures of the board to make sure it's repairable so I would have them ready.
#10 14 years ago
Some people are complete ...soles when it comes to electrical parts, why oh why do they just bodge it together? and hope for the best. CHEERS to the people who believe in doing things right, no matter how long it takes or what the costs are. In the past I have found wires soldered directly to board connector pins and it sux. Come on, how much is a new connector and bits, to me it seems ridiculous.
Good luck with your fix.
#11 14 years ago
This was my first circuit board repair. I figured, if I mess it up, no big deal, it's already broken and hacked. Makes me wish I didn't throw away the original Meteor's board. It wasn't in nearly as bad a condition as this one. But I didn't know any better at the time. Oh well, you live and learn.
#12 14 years ago
Phil, Once you post your pics. I'll take some and attempt to mirror yours to the "T" so you can compare them.
#13 14 years ago
I meant this one. I had to many DE games with this problem.
But please check the 5 volts on the CPU.
And do yourself one favor. Remove the the COIL fuse from the power supply when the game is not booting!
#14 14 years ago
Sealchubber i think Phil is looking at the GI input of the power supply.. The plug is soldered in to the board most of the times
#16 14 years ago
@Benboogaard: so I should check for 5 volts on the CPU board or on the power supply board?
And why is it good to remove the the COIL fuse from the power supply when the game is not booting?
#17 14 years ago
Sorry SealClubber my mistake.
Phil you should check the 5volts on the powersupply first.
If there is no 5 volt check for +12.
Most of the time problems with 5 volt relates to the square molex plug of leaky capacitors on the power supply.
If the 5 volt is not working you have a big chance some of the transistors energize some coils witch results in smoking transistors and coils. This happend to often to me.
#18 14 years ago
No problems Ben. It gave me a laugh.
#19 14 years ago
Hi All,
I finally got round to taking some photos of the machine. 1st one shows the random crap on the DMD when I switch it on. The 3rd and 4th are closeups of CN1 from different angles. Let me know what you think!
IMG_7350.JPGIMG_7350.JPG IMG_7352.JPGIMG_7352.JPG IMG_7362.JPGIMG_7362.JPG IMG_7363.JPGIMG_7363.JPG
#20 14 years ago
Looks like the CN1 connector pin#12 is burned. Too much power thru it, likely. Will need to replace the burnt pins. Also need to look at what feeds that pin and replace those bridges, diodes etc... And hope it didn't do much damage down the line.
#21 14 years ago
All that electrical TAPE in those pictures reminds me of a party I went to awhiile back.....in 1988.........when things were GREAT........you could get a cheap DATE........pinball machines were shipped by FREIGHT.........when they didn't care about WEIGHT.........but WAIT!!!!!!!!
..yep getting off topic again.
Lots of hacks on that board....ouch! did you know that nothing rhymes with orange?
#22 14 years ago
Wow! I didn't even notice the tape holding the batteries. Or the tape on the wires on the ppb board. Or the two other brown connectors. Or the burn marks on the backbox and the wires below the power supply board. That is worse than my Future Spa was. Are you decent at soldering? I ask this because you are not only going to have to repair at least two circuit boards and the wiring harness as well. This will be expensive to replace or send to someone else to repair.
#23 14 years ago
This is what i call a McGuyver rerairment
The first step would be replacing CN1's header and connector. But this could not fix your problem, but it needs to be done anyway.
Any progress on mesuaring (arg difficult word and i know its wrong ) the voltage?
2 months later
#24 14 years ago
Hello again everyone,
Sorry for taking so long in getting back to you all. Yes, I am rubbish...
So yes, the voltage has been measured and there is no 5 volts on the power supply board but there is 12 volts.
So Ben, you said "Most of the time problems with 5 volt relates to the square molex plug of leaky capacitors on the power supply.
If the 5 volt is not working you have a big chance some of the transistors energize some coils witch results in smoking transistors and coils. This happend to often to me."
I am rather naive, so please could you point out the plug of leaky capacitors? And should they be replaced? Also, which would be the transistors and coils that would be affected and how can I test them to find out which ones to replace? I ask, as you say that this has happened often to you - so I figured I'd pick your brains
On a different note, about Pin 12 on the CN1 connector which looks burned. In the schematic it says that it's a ground so how come it got burnt (naive question I know, feel free to laugh at me!)? And in the photo that Ben posted, there doesn't even seem to be a wire connected to Pin 12. Any suggestions?
Thanks, and sorry again for not posting for so long.
Cheers,
Phil
#25 14 years ago
Phil..
The best thing to do it to buy a new connector and some new pins. In your case i would replace the header too. This can be a very tricky operation and you need a molex crimper.
I coult give you a lot of suggestions, but the best thing is to remove "the hacked stuff" and replace it with original connectors.
You can find the wirecolors in your schematics.
The connectors can be bought at http://www.greatplainselectronics.com/
3 months later
#26 13 years ago
It does make me feel better about my DE board.
I know this is probably way too late, but... there are some modern replacements for this board on the web or ebay that would set you back less than $100.
I have been tempted to change out mine and it still works. This board tends to run hot and work a lot better with jumpers, so it is one that begs to be hacked. I'm not a purist when it comes to repairs, but I do insist that everything works well.
#27 13 years ago
After you get this working, I'd definitely get a repair guy with a good reputation, and have him go through the machine to un-hack all that stuff. Quickie field repairs like I'm seeing there should only be temporary in nature, and only cause more problems down the road.
Where you located anyway?
-Hans
#28 13 years ago
Hey Guys,
Havn't been on here for a while and just saw your messages.
So I should say that a friend of a friend came round a while ago armed with a multimeter and the schematics and nailed the problem. And it turned out not to be a problem with the wires soldered directly to the board. But instead it turned out to be a diode with a dry connection! I'll put up a photo marking the diode in question below. He poked around the diode and it actually started working again at least for a few hours worth of play until the connection broke again.
So now it's a question of just getting a drop of solder in the right place to solve the problem for good. The problem now is that where the solder need to go is in a very awkward place because of the components around it. Making it very hard for the soldering iron to gain access to it. We could just take out the whole board except one of the connectors is stuck and can't be removed! All very annoying!
And now I noticed over the weekend that the rubber on the left slingshot snapped. Not a difficult job to replace though? And I'll order a set of new rubbers on the interweb today (parts4pinballs.com I think).
Hans - I'm in Barcelona. So if you (or anyone else!) can suggest a good repair guy that would be great as I'm tempted to get the machine overhauled as well.
Donjagra - I think I know what you mean about modern replacements for the board. Would this one do the job?
http://www.parts4pinballs.com/product_info.php?cPath=159_163&products_id=2730
Cheers,
Phil
#29 13 years ago
Hmm, that board might work, it doesn't look quite right though. I would want to see a list of games for it before buying it.
However, before you go down that road...
Since that little guy is your problem, take a pair of needle nose pliers and give him a slight twist. I can't stress how important it is not to over do it. If you twist too hard you will break it off the board and no one wants that.
A resolder would be the best, but if it is too hard to reach, a slight twist would reconnect the pins and can last a long time.
1 year later
#30 12 years ago
Same issue with mine. It doesn't seem to be the resistor that Phil had. I'd hate to buy a new DMD if it is something minor. I have checked all connections but I will recheck tomorrow.
#31 12 years ago
future, did you get my email? Did that help any at all?
#32 12 years ago
I got the email about the scoop and I got that issue resolved, I can now play with the glass in place . I never got an email about the dmd.
#33 12 years ago
This thread is a year old...
#34 12 years ago
Quoted from Crash:
I know, right? Forums should auto-lock threads after a couple months of inactivity, so people create new threads instead of responding to ancient, and usually only tangentially related topics (as was the case here, assuming i'm reading Future's last post correctly - it sounds like the game is playable, with only the DMD failing, whereas in the original poster had no functionality)
#35 12 years ago
Youare right. I skipped past the frozen part. Saw the picture and assumed we had the same problem. I will open a new thread after work. Just bought multimeter and solder. Ready for action
#36 12 years ago
So I have this flipper problem with my TFTC...
10 months later
#37 11 years ago
The lights in the back of my machine on the playfield are not working anymore..everything else is fine. Any ideas of what might be causing this issue??
#38 11 years ago
Yes. A blown fuse is a good start. Use a dmm and test them all. Or a burnt GI connector. Start a new thread rather than redirect a 2 year old one
$ 27.95
Metal-Mods
$ 59.95
pinballmod
4,850
Lake Elsinore, CA
$ 18.00
Mitchell Lighting
$ 18.95
$ 64.00
$ 59.95
pinballmod
$ 38.00
PinballReplacementParts
$ 70.00
Creekside Hideaway, LLC
Metal-Mods
$ 54.99
£ 32.00
PinballToys
YouBentMyWookie
6,900
Plainfield, IL
$ 18.95
$ 18.95
$ 19.95
Mitchell Lighting
$ 12.00
$ 59.95
pinballmod
Playfield - Plastics
Mad Czar Games
$ 345.00
This page was printed from https://pinside.com/pinball/forum/topic/tftc-not-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
