I got a TFTC yesterday in very nice condition. The only thing I can find wrong so far is the drop targets don't reliably fall. When I lift the playfield, the left target has 2 springs attached. The middle target has one. The right target has one but someone has threaded part of the spring up through the hole in what looks like an attempt to strengthen the spring. It seems like the target is having a hard time clearing the plastic ledge which holds it up.
During play, the middle target seems to be fine. I also noticed the left target has dropped a couple of times if all the other targets are up but if the middle is down even direct hits don't cause it to fall. With the glass off, if you press it with your finger pretty hard, they all work.
Hopefully this is an easy fix. Any thoughts?
Darin
