Having a problem with a missing ball issue with TFTC. After reading posts I thought I had found the problem. What I thought was my problem is not.
Here's the issue.
See the red circle around the most common problem switch that everyone ends up replacing. well it works sometimes.
When there is no 2nd ball in the trough (I circled it blue) the other switch works fine. When a ball is in 2nd position the other switch stops working(circle in red). I think this is causing my missing ball issue?
Any Ideas? or is this normal?
