In my TftC four of the flashers will not work at all, those being with the wire black/orange to orange. I have removed the connector and placed it back, as I do with everything, and it didn't fix it this time... Any recommendations on how to fix this?
Note: If you find the manual anywhere for the wire schematic - it is on page 64
FIX: One of the sandstone resistors was loose at a solder join, re-soldered and now working again!
Quoted from viperrwk:As long as the duck flasher and the drop target on the playfield are both working, then Kris nailed the problem. Check the middle connector on the right - the black/green wire is the one that goes to the right firework flasher. Check R5 on the board (fifth resistor down from the top) to make sure it is attached. Also check it with your new meter <g> - it is a 4 ohm 5W resistor.
viperrwk
https://i1.pinside.com/a/f4/af4015d7a6e8159fe2e43111af6f7e0ea08e6635/resized/512/af4015d7a6e8159fe2e43111af6f7e0ea08e6635.jpg
