Hi guys n gals,
Tried searching pinside but couldn't find any clarification on my query.
Been shifting through info on testing the high voltage on a gottlieb system 3 and I think I'm either reading PinWiki wrong or it contradicts itself?
http://www.pinwiki.com/wiki/index.php?title=Gottlieb_System_3#Power_Issues
In the section it describes clipping your black lead to a good ground (backbox corner) but not long after it says in order to test the high voltage connector you will need to use pins 4 and 5 for certain pins.
So which is it? Any help appreciated.
Cheers
