I'm testing a power supply that is supposed to deliver 5v ac. It is a cord with a household plug on one end and a switch with two leads coming out which will get wired to a little ac motor that it goes with.
Using my Fluke 101 multimeter, I get a reading of 5v with the switch in one position. When the switch is in the other position it reads 120v with a little high voltage indicator on. I sure thought the other position would be OFF.
I think it is supposed to be an on / off switch-- one side of the switch is marked with a -
The back of the switch says 3A / 120vac 125 vl. Also, 303, which I guess is a part number.
Did I get a bad switch? Am I misunderstanding something?
undrdog
