I am still fighting this issue.
I purchased a 4N35 chip, but it has not arrived yet. I also purchased a new prox board made by pinpoint. Board arrived yesterday.
I plugged in the pinpoint board last night hopefully to confirm all my issues were with the board. Popped the 3 amp fuse for the 12 volt supply. Was not expecting that. Only would blow the fuse with the pinpoint board. Emailed the manufacturer and they suggested I clip the C4 cap on the board. I guess that cap was creating an inrush of current and popping the fuse. It worked. Fuse did not pop, but switch 26 would still not register even though the led on the board shows that the prox is detecting metal.
If the connection to the CPU was bad, I would have a row or column of switches out. I do not. I have not double confirmed there are no other switches out, but I have certainly tested switches in the same row or column and they work. Also play several games.
Has to be a connection issue. I rechecked the resistance. From U2-5 of the prox board to J208-7, 1.2 ohms. From D2 diode on the prox board to J206-2, 1.4 ohms. Connections seem fine.
I hear of folks soldering the connections. Does anyone have a photo they can send me? I was thinking most were soldering the connection between the prox and the board. I have no issue with turning the led on the board on. I just can not get a signal to the CPU.
Do I have anther bad board? Out of ideas and need advise from someone smarter than me. CPU issue???
