Hey hey!
Stumped on what might be an easy one for the pinside audience. Flippers on T2 don't function the way they should.
The right flipper hardly has enough power to pull in to the coil. The left flipper will work once or twice and then stops working and then in a couple seconds will work again. When the playfield is up and I'm testing the flippers you can visibly see that it's trying but almost just doesn't have enough power to pull in the bat.
If you push in the flipper the coil does have enough power to hold it up.
Tested the coils and they are getting over 50V
Other notes
- right flipper & left flipper buttons both work on switch test
- middle lug to ground on both flippers works
- clean and rebuilt flippers, sleeves
- eos switch is brand new and closed on rest
- coils test fine, as do the diodes
All other machine functions look to work great. My guess is it's Q 99 but don't know. Any thoughts or help is appreciated!
