I was working on my Bride of Pinbot pin today. Sitting next to it is my T2 pin. I was wearing a t-shirt and my arm was resting on the side rail while I was testing the MPU with my meter. I felt a tingling shock on my bare arm as it pressed against the side rail of the BOP pin, my other arm pressed against the T2 rail of the pin next to it. The T2 was plugged into the 120V electric outlet, but not turned on. The BOP was turned on with full power. I tested the AC voltage across the rails of the two pins and it measured 27VAC. What could be causing this? I am sure it is the T2 pin because I tried measuring voltage across the rails of other pins and they were all 0VAC. Only T2 registered voltage. Bad ground?
