(Topic ID: 169299)
Terminator 2 Q91 Transistor predriver?
By DanielStrijker
2 years ago
  • 11 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by ChrisHibler
#1 2 years ago
Hello,
I'm was busy finishing my restoration when suddenly a row of lamps were flashing when they were not supposed to...
So I checked the transistors and there it was; Q91 was shorted... So I removed the tip 107 and installed a new 1. Checked and measured resistance on all 3 pins and the soldering, everything looks fine.
Now the entire row is not working, I checked the continuity in the wiring off board and this proves fine.
So the problem has to be onboard, the predriver for this 1 must be an array U18"MP9112". I suspect this could be the problem.
My question is: Is it known for these arrays to blow random or must there be a reason? Like shortage somewhere?
Could there be another problem not taken in consideration by me?
#2 2 years ago
Oh, and if anybody knows how to turn on the profanity it also would be nice since I installed all the chips, turned profanity "on" in settings.. And then, nothing... I mean, FU shoulde be a database option, right? Well it doesn't show there...
#3 2 years ago
Quoted from DanielStrijker:
One dirty word every 20 games, don't wait to be amazed.
#4 2 years ago
Seriously...
Quoted from LTG:
#5 2 years ago
Every electronic component has the potential to fail.
Use a logic probe to verify your theory.
Chris Hibler - CARGPB #31
http://ChrisHiblerPinball.com/contact/
#6 2 years ago
Quoted from ChrisHibler:
Thank you for your reaction, but it is rare for these parts to malfunction, so I checked for shortages in the wiring offboard, nothing.
Continuity is good. (yellow-gray, Q91) I'll just continue to replace parts up the ladder... Just wanted to know if somebody had a clue, would be easy right?
#7 2 years ago
Please don't just shotgun parts. You're running the risk of damaging something more every time you do. The logic probe is a good recommendation. Use it to determine if the predriver and transistor are active. You can also disconnect the playfield wiring and measure the DC voltage on the column output connector. You should see something in the area of 3V. If it's 0V or 18V, you have a board problem.
#8 2 years ago
Quoted from LTG:
Every 20 games may be... generous I'd say every 50-75 games is more the norm
And, you have to LAND on the option in the database...
#9 2 years ago
You MUST have free-play enabled to have the FU A-hole to show as an option in data-base................Joey
#10 2 years ago
Quoted from herg:
I've measured all of the pins from J137 they all read like 2.7 V except for the pin where yellow gray is connected, I have no current there... So the predrivers for this particular transistor is an array "ULN2308", replaced that 1, no difference then replaced the 74ls374 8bit thingy... Still no difference. All of the other columns connected to these parts still work... I really, REALLY don't know what to do anymore...
Maybe it helps if I give you more insight...
The troubles on the board were:
-J115 GI was completely burnt so I jumped all connections. Works fine now.
-Transistor from the droptarget was broken, replaced the TIP 102 and the predriver and it works
-Transistor from flashers left poppers was broken.. removed screw that was screwed in next to the fittings (touching) and fixed the shortage and replaced the TIP102 and predriver. Works fine now
-Transistor Q91 TIP107 lamp column (present problem) was flashing out of control. In the single lamp test 1 of these lamps started to burn when I tested another single lamp from a different column. Very weird. So I tested the tip 107. Result: 0.00 Ohms. Broken right? So replaced everything up to the 8bit controller. Now the lamps don't flash at all. No power coming from the tip 107 on that particular yellow-gray pin. All of the other pins read fine.
I suspect shortage beneath the droptarget that is were the most yellow grey column lamps are wired and maybe touched the droptargets frame somewhere. (because the droptarget transistor was broken too). Also, The flashers that were broken too also resided in that area.
But I checked the wiring and voltage when operating these parts and no voltage on the yellow gray wiring.
Phew... That was all the info I have.. Any clues? Doesn't matter how trivial please give me some input! I know for sure it's something stupid I'm overlooking...
Quoted from johnwartjr:
Quoted from Breaking_Dad:
I am very disappointed
#11 2 years ago
Get the schematics for the board, and with your DMM on continuity, buzz from the .100 dual row header all the way to the parts in question. I want to ensure you don't have a blown trace.
Watertown, WI
$ 26.50
$ 50.00
$ 16.50
$ 55.00
Pinball Photos
€ 4.95
Multigame
Trade
Machine - For Trade
Newnan, GA
€ 3.70
€ 222.00
Buthamburg
$ 45.00
Pinball Photos
Yorktown Parts and Equip
$ 399.95
KAHR.US Circuits
$ 48.00
$ 40.00
Metal-Mods
$ 159.99
$ 19.99
