I have a T2 that has an issue with some lamps that flicker or appear to flash in double time. In this video:
you can see the right hand set of inserts from 250,000 up to the 5,000,000 flicker at an incorrect rate. Also the eyes seem to do the same. When I look at the lamp matrix these are all on the same column. Other than the lamp matrix on the cpu is there something else this could be? Machine has a new driver board due to the old one being hacked up by the operator and would prefer not to have to replace the cpu. Also that white number two target stays lit like the socket is getting power all the time just weakly when its supposed to be off, pretty sure that is a different issue but thought I would mention it.
Anyone else run into something like this?
