Hi,
Just got my 'new' T2.
When the ball loads into the canon it swings out as usual to the bottom of the range and then on the way up the solenoid fires the ball out. This happens without pulling the trigger.
I have checked the switches on the ramp leading in to the cannon. The switch inside the canon. I check the two switches under the canon and also adjusted the switches. All switch tests perform perfectly and the canon always finds the 'mark' and the 'home'. All connections are perfect and all diodes are in place.
What could be firing the canon automatically?
Is this a hidden software feature? I have the L-8 ROMS.
Thanks!!!!!
