Quoted from Richard-NBA-SF2:Thanks man! Starting to clean tonight. To replace the back box / head decals I would need to sand this down I assume? The wood has lots of “splitting” in it like planking.
To fill in the lower corner. Wood filler? [quoted image][quoted image]
If the game is running 100%, then I work on the cabinet.
Completely disassemble the head.
Sand it down to the wood with an orbital sander.
Fill the corners with bondo it they arent too badly missing.
Any cracks can be clamped and glued with titebond III glue.
Any loose joints can be countersunk and wood screws applied deeply and glued with titebond.
Use bondo to cover the screw heads.
For bad planking and unstable fibers, I mix titebond glue with about 25% water and paint it on then let it dry.
It sands out pretty good.
Fill any voids with Half-Time filler, it dries and is sandable in 10 mins, so you can keep working on it until your satisfied. You can also "butter" any end grain with half-time to give the front a more finished appearance.
Sand everything square, but very slightly round off sharp edges to keep wood fibers from splitting out.
Use Kilz oil based primer on the wood. 2 coats sanding very smooth, both coats.
You can get Kilz in gallon cans and use a foam roller and foam brush. For hard to sand areas you can get Kilz in a spray can.
Let the primer dry at least one day, maybe 2. It should not be super cold to the touch, but room temperature.
Primer has to be dry to sand properly. Dry sand, never wet (it raises the grain of the wood)
Use Rustoleum satin black paint or similar, 2 coats or more if you need to sand it out. It will take a week to dry if you have to sand out runs.
DONT PAINT THE BOTTOM OF THE HEAD. Leave it primer white or if it looks good enough, leave it alone. If you paint it, it will stick like glue to the bottom cabinet. It takes a LONG time for the paint to dry.
Apply decals, Trim them back 1/8" from the edges so they dont catch on things and lift off.
Seal the white edge of the decal with Sharpie oil based paint marker.
Reassemble, and your done!
It takes about 6 months for the paint to dry super hard and durable, until then its super easy to touch it up if needed.
Do the same with the lower cabinet, they dont have to be done at the same time.
