(Topic ID: 27799)
Terminator 2 Club....Members Only!
By spfxted
10 years ago
  • 9,867 posts
  • 701 Pinsiders participating
  • Latest reply 34 minutes ago by Averell
  • Topic is favorited by 258 Pinsiders
There are 9,867 posts in this topic. You are on page 196 of 198.
#9751 51 days ago
That's the reason why I decided to restore my T2 the original way with only some unique improvements.
#9752 50 days ago
Quoted from KJS:
I'm about to embark on my 4th t2 resto.
I've done 2 beautiful chrome editions but I think it's time for a change as they are a bit common now...
mmmm let's see !
I’m in the market for a T2. Are the Chrome editions more valuable?
Cheers!
Richard
#9753 50 days ago
Quoted from Richard-NBA-SF2:
Cheers!
Richard
I can tell you the chrome parts are not cheap to procure, so in that sense they’re certainly worth more!
#9754 49 days ago
There are lots of iterations and interpretations of a chrome editon. All personal taste.
I don't like the original blue theme myself.
A machine is worth what it is to you personally I think.
#9755 49 days ago
Fellow T-2’ers
I found out why my skull wasn’t always working.
Where can I buy the plastic ball cradle driver rod?
Here’s a pic with the broken part and a faint red arrow pointing at it.
Thanks in advance!!
#9756 49 days ago
Quoted from JohnTTwo:
Fellow T-2’ers
I found out
Marco Specialties. ( Marco pinball).
#9757 49 days ago
Quoted from Santis:
Thanks I am not very efficient at finding the correct item at Marcos.
It leads me to this part
515-5352-00 plunge
From this kit:
VERTICAL UP KICKER (VUK) COMPONENT KIT
#565-0029-01
Vertical Up Kicker (VUK) repair kit contains plunger, cap, spring, spring compression clips and roll pin.
Order this kit if you need the 545-5227-00 Vertical Up-Kicker ball "cup".
Ships un-assembled.
Contains the following components:
545-5227-00 ball popper cap
515-5352-00 plunger
266-5025-00 spring
270-5010-00 compression ring (3)
251-5004-00 roll pin
Reference:
Data East / Sega / Stern 565-0029-01
Wico 18-002900
Weight: 0.1 lb
But doesn't say it is for T2
Product Compatibility
DATA EAST
STAR WARS (Data East) , TALES FROM THE CRYPT,
And mine is black not natural nylon.
PLUNGER ASSEMBLY 3.875 INCHES
#A-11336
Ball popper armature and nylon tip extension assembly.
Overall length 3.875 inches (98 mm)
Reference:
D-12642 bottom ball popper assembly
B-12505 bracket
D-11335-2 ball popper assembly
B-11631 bracket
A-11336 armature
D-11335-1 ball popper assembly
20-9314-7 roll pin dowel 3/32 inch diameter x 1/2 long
515-5352-00
Weight: 1.73 oz
BALLY
ATLANTIS (Bally), BLACK ROSE, DR DUDE, DR DUDE, ELVIRA, PARTY ZONE,
WILLIAMS
BANZAI RUN, BLACK KNIGHT 2000, F-14 TOMCAT, FISH TALES, HURRICANE, SPACE STATION, TERMINATOR 2,
#9758 49 days ago
515-5352-00 plunge
From this kit:
#565-0029-01
Ships un-assembled.
515-5352-00 plunger
266-5025-00 spring
Reference:
Wico 18-002900
Weight: 0.1 lb
DATA EAST
#A-11336
Reference:
B-12505 bracket
B-11631 bracket
A-11336 armature
515-5352-00
Weight: 1.73 oz
BALLY
WILLIAMS
Are you looking for this?
https://www.marcospecialties.com/pinball-parts/03-8053
#9759 49 days ago
Thanks for taking the time and looking at this for me. I need the shaft that fits into the plunger cap.
If you look at my pic I need the part that get driven up by the coil the top of it broke off and you can see where the pin goes into it cuz it is broke there.
#9760 49 days ago
Oh, I see you found it in the post I quoted.
#9761 49 days ago
The manual has all the parts listed (you can download the manual from IPDB if you don't already have it)
You'll need parts 2, 3 & 4 in the below pic, and you should replace the sleeve (#10) while you're at it
#9762 49 days ago
Quoted from Manny65:
Thanks I have the manual and the part I need is not on that fig. That’s why I was asking for help.
The part I need is between arrows 4 and 10.
Maybe it is part 2 if it’s one piece???
#9763 49 days ago
Correct the armature (#2) is sold as one piece
#9764 48 days ago
Theres no such thing as a T2 that the VUK didn't self destruct at some point... Mine is HUO and i'm the original owner, and mine blew up many years ago too!
#9765 48 days ago
Thanks so much!!!
John
#9766 48 days ago
I had mine blow up in October - fired the cap and ball up into the wireform. Here's the plunger, cap, and roll pin I ordered from Marco to get it going:
Plunger: A-11336 - https://www.marcospecialties.com/pinball-parts/A-11336
Cap: 03-8053 - https://www.marcospecialties.com/pinball-parts/03-8053
roll pin: 20-9314-7 - https://www.marcospecialties.com/pinball-parts/20-9314-7
I would also replace the spring while you have it apart. It's a little tricky to get it all back together so you won't want to do it again until you need to.
Spring: 10-135 - https://www.marcospecialties.com/pinball-parts/10-135
Edit: yes part #2 "plunger" could be sold as two pieces but is only sold as one piece. You can also probably reuse your cap but if you are in there I'd just replace it.
#9767 48 days ago
Recently lost my right flipper, no power.
On the power driver board Fuse 112 was good ,but Fuse 102 was blown, replaced it and it blew again. I am suspecting BR3 rectifier, but haven't pulled the board to tested it yet. My pins don't break down often but when they do I need to go into learning mod, but there is much to learn, so I am looking for advice if I am on the right path from someone who knows these old Williams boards better than me.
#9768 48 days ago
Quoted from Rascal-911:
When mine was doing this it was my right flipper leaf switch making contact with the plunger. Took me a while to figure it out.
#9769 48 days ago
I ill check that tonight. You are referring to the EOS?
#9770 48 days ago
No, for me it was the right flipper cabinet mounted leaf switch, the one actuated by the flipper button. It started happening when a I installed a new leaf switch and didn't realize it was touching the plunger, there's not a lot of clearance between them. I had to rearrange the blocks on the new leaf switch to make room and I added a strip of electrical tape for good measure.
#9771 48 days ago
Thanks I will certainly check the clearance in that area.
#9772 48 days ago
I'd doubt that it's BR3, as it powers all your solenoids as well as both flippers and you only have an issue with the right flipper (I assume that the left flipper and solenoids all work fine?). Does the fuse blow immediately or only when you start a game or only when you press the flipper button?
Replace F102 and disconnect J109 and J110, then power the game on - if F102 blows then the issue is on the power driver board, otherwise it's on either the PF or cabinet.
#9773 48 days ago
Thanks I will try this to narrow it down.
I had a Dirty Harry with one right flipper out and blowing fuses and I found a bad rectifier on the Fliptronic board that fixed it. Thought it might be similar with the Power Driver board on T2.
I will dig deeper. Thanks.
#9774 48 days ago
T2 is pre-fliptronics, so BR3 powers all coils.
When is the fuse F102 blowing?
#9775 48 days ago
I changed the fuse last night, powered up and started a game, no power to flipper. I didn't check to see if it blows on power up or just when a game starts.
I need to find more fuses.
Would you know what q # transistor on the Power Driver board would be associated with the Right flipper? The manual doesn't have good schematics or board layout.
#9776 48 days ago
T2 doesn't use transistors for the flippers, it's more like a simple circuit with a switch (the flipper button switch). BR3 sends power to the coil (so before starting a game you should have 50V power on the coil lugs - assuming F102 hasn't blown). The circuit then goes to the flipper button switch (hence the need for a high power leaf switch, compared to what is used on fliptronics games), and then back to the power driver board. The relay on the power driver board is how the game controls when the flippers can and can't be used, when the game is started the relay closes connecting the flipper button leaf switch to ground, such that when the button is pressed current will pass from BR3 through the coil and then the flipper button leaf switch to ground.
Here's the associated schematics for the flippers
#9777 48 days ago
I robbed the fuse from the working left flipper and put it in F102, power on, tested voltage on coil lugs, 70 VDC, fuse didn't blow till it hit the flipper button.
#9778 48 days ago
Either a bad coil or wrong wiring at the coil.
#9779 47 days ago
I checked the clearance at the leaf on the cabinet switch and it does hit the ball plunger when button is hit, never did it before but something must have changed. Would that cause a short. I need to round up some fuses to do more testing. Out of stock of 3a slo blow.
#9780 47 days ago
That's your huckleberry!
#9781 47 days ago
After the restoration of my T2 I figured out that there a two different switches for the Flipper buttons available, an old version and a new version.
The difference is the height of the switch, but it didn't convince me at all.
I made some custom modification to ensure nothing will be short circuited.
#9782 47 days ago
Damn!....you guys are good!!
#9783 47 days ago
I am waiting on 3A Slo fuses from Digikey, but in the meantime, would 4A slo be too much to test with? It is a 2.5A from factory spec but had 3A installed, but I am worried 4A may be too big to use temporary to see if the cabinet switch shorting on the plunger is the problem.
#9784 47 days ago
I wouldn't, but that's just me. I've turned small problems into big ones by taking shortcuts too many times
#9785 47 days ago
I better wait for the right size. I am modifying the switch now to get more clearance. I am hopeful that is all my problems.
I have to say, I love this fucking game, even though it is pissing me off right now. I am just mad I am not playing it.
#9786 46 days ago
I have a few of these in my fuse kit with different amp ratings. It might be overkill for you but if you are going through a lot of fuses, these work great for testing purposes. I just solder 2 inch wire with alligator clips to the terminals.
https://a.co/d/7bT0Qax
#9787 46 days ago
That looks like a great idea for testing. Much better than going through several fuses to check for problems. I may get these for future issues. Thanks.
#9788 46 days ago
Quoted from Scoot:
You can also solder a blown fuse to them and then snap right into the fuse holder.
#9789 46 days ago
Update, I got a buddy to borrow (steal) a couple fuses from work, put it in and blows F102. Removed coil and installed a different known working one and boom we are back in business. I can't see that coil blowing but maybe one or both of the diodes is cooked?
But thanks for all the help from everyone. We are back in business.
#9790 46 days ago
Test the resistance between the faulty coil lugs (https://flippers.com/coil-resistance.html shows you should have 4.0 ohms and 133.0 ohms on the 2 wirings). Suspect you have a short on one of them - as you mentioned possibly a shorted diode
#9791 45 days ago
Quoted from tripplett:
Smart!
#9792 42 days ago
Looking for terminator 3 club?
Can anyone point me in the right direction.
#9793 42 days ago
Quoted from CNKay:
https://pinside.com/pinball/forum/topic/t3-clubrise-of-the-machine
#9795 41 days ago
Thanks so much for help, I did the spring and new cap as you suggested.
Everything is working perfectly now!! Whoot Whoot!!
ONe last question is there a easier way to get that little pin put back into the new plunger plastic hole. OMG it took me forever and the way I was pushing, pulling, and grabbing that thing I can't believe I didn't wreck something.
So please you guys have to have some trick or tool to getting that thing back in there. And don't tell me to spit on it!! LOL
#9796 41 days ago
Have a few more original parts to sell if anyone is interested:
Original T2 apron (does not have wireform protector)
Sling plastics and the two plastics that surround the skull (new, in great condition)
Original speaker panel (used in. Players condition)
Legs, channel housing, and various cabinet parts
Cannon mod cover with blue inserts
Hit me up for pictures or any questions. Could have more parts that I’m forgetting about so just send me a message if there’s something you’re looking for.
#9797 40 days ago
You ain't lying here. I cussed at that pin for a while. I took the whole assembly out of the game and to my workbench. Don't try to do it in game, go ahead and unsolder the coil. The switch you can unscrew and leave in the game. The way I did it was to get it started by hand then 'press' it in by squeezing with a pair of channel lock pliers. Don't try to hammer it in or you'll just be frustrated (spit or no spit).
#9798 40 days ago
Quoted from atg1469:
Wow, wish you had posted this before I just spent $50 ($25 each) for them from Marco.
#9799 40 days ago
Okay glad there was not a easier trick way to get it in. I left the assembly in my game and what I did was file the one end of the pin to a point. The first time I did not take enough off of it. Then it helped me get it started and I pushed it in using a vise grip on both sides of the assembly. But as you know that pin needs to in a bit deeper so it doesn't hang up on the cup itself so I used a needle nose and a small wire to push it in the final 1/16" and man did my back let me know how stupid I was for leaving it in the game. For anyone doing this in the future follow the advice from tripplett and remove it from the game all together. Oh and I was going to use a hammer I just didn't have the guts to swing it hard inside the cabinet!
Thanks again,
John
#9800 40 days ago
Sending you a PM!
$ 5.95
The Pinball Scientist
Protection
Other
$ 299.95
Pin Stadium Pinball Mods
Led
$ 399.95
Led
This page was printed from https://pinside.com/pinball/forum/topic/terminator-2-clubmembers-only/page/196 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
