I’ve been on a mission to figure out a way to adjust the T2 kickback to feed into the rollovers and pop bumpers every time. Not sure if SR originally designed it to, but I feel it only makes logical sense… (E.G. Getaway kickback into the mountain). In fact, most T2 owners say their kickback just feeds into the chase loop and falls right back down. Well I finally got it to work 100% of the time.
I replaced the kickback coil, plunger, and return spring (not sure if you would have to, but I did it before I figured out the solution). Basically, I installed 2 small thin washers under the red screws and 1 under the yellow screw in between the coil bracket and PF. Also, the coil needs to be adjusted as far left as possible without the plunger hitting the bend out in the side rail right before the coil. The idea is that the plunger hits the ball at dead center along with pushing it left for a smooth feed along the kickback left guide rail.
Under the cannon, There’s 2 screws on the side rail that need to be removed (marked in blue). Lightly hand bend this side rail towards the right, flexing it towards the cannon base and GI Bulb (green arrow). Unfortunately in order for this to work, you have to leave those 2 screws out to allow the guide rail to essentially flex during the impact. After bending the rail to the right, I tried drilling new holes in the PF and screwing the rail back in using the newly drilled holes, but unfortunately it doesn’t work…. it acts like a solid wall and doesn’t allow the ball to move up into the chase loop. The rail must be able to lightly flex to mitigate and sponge the impact. I’m not really concerned about PF wear along the rail, as it barely moves when the ball impacts it anyways. Worst case, maybe I’ll put a thin strip of Mylar under the side rail.
Good luck!
11C0ABBB-95A8-4CAD-8328-4561AB86B38B (resized).jpeg8769D2CC-AD10-4B18-B063-5290B181CF7B (resized).jpeg
