Anyone knows what controls the bulbs to the "auto fire" insert?
If they are not working, where/what to troubleshoot except for the obviuos (lamp sockets)?
Quoted from Sehested:I have brought a pair of the T2 eyes mod from Gnassel and I can highly recommend them. He is a straight up guy and if you want to make either your skull or a custom topper more inactive this T2 eyes mod is the perfect way to go The mod is really well put together and top notch quality. Instead of using the eyes in the skull on the playfield I worked with Gnassel to be able to install them in my custom T-800 topper. He was really helpful getting the size and cable length to fit for a topper compared to the playfield skull. The eyes are really bright and even the small LED used gives more than enough light for the eyes in the topper.
Beside Gnassel's T2 eyes the topper is 3D printed with silky silver PLA to give it the metal likeness of the T-800. The base is printed in Black and then the T-800 letters are painted with silver metallic paint. The model was found on thingiverse https://www.thingiverse.com/thing:3163402 and printed in 60% size of the original (the reason for this was due to limited ceiling clearance above the machine. Behind the shield is a cool white flasher installed. I also want to install a red LED strip on the back of the base to light up the wall behind in red, but I didn't have one in stock so have to wait until I get one.
Here is a couple of video of the topper in action [quoted image][quoted image]
That's pretty cool, but the first video shows a flutter/glitch type movement in the eyes? Is that really happening? Not good, if it is.
Quoted from rx3:That's pretty cool, but the first video shows a flutter/glitch type movement in the eyes? Is that really happening? Not good, if it is.
That is the sequenze it use when you hit the hunter ship with the Canon. It looks really cool. If you miss then it have an led above the 5 it have In a straight Line so it can emitate Roll eyes.
I'm sorry. What exactly does that mean?
Quoted from Gnassel:I'm sorry. What exactly does that mean?
Watch the first video Sehested posted - I noticed something strange with the eye movement as well but it doesn’t happen the the second video or on any of the clips you’ve posted, so I wonder if it was an issue with the video??
In the first video we see the game end sequence. Here all flasher are wildly controlled and here also all patterns of the eyes run through. Except for the rolling eyes, because that would look strange here.
As Sehestedt already mentioned, this is a special effect as soon as the huntership is hit. It would be conceivable to take this out here, but then it would look exactly like the Payback Time. A little bit of variety is allowed
@Brett, I haven't forgotten you. I'm still waiting for feedback from Scott.
Frank
So how many T2 owners have changed out their skull eyes for something a little more fitting? I think we all feel there’s just something “off” with the eyes the way they are. Well I was lucky enough to purchase the skull eyes mod from Gnassel (Frank). When he first posted his mod I knew I had to have it. It is exactly what the game has been needing. The eyes look towards the ball at certain times such as when the ball is on the wire ramps, in the left saucer, in the pop bumpers…an absolutely must have mod for this title. If this game was currently being produced by Stern this a mod that would probably only be available in the Premium edition and we’d all gladly pay the extra for it! Frank is a great guy and made sure I was happy with the mod. Even though he’s located in Germany he was always available to me via text in case I had any questions or problems, but installation was very easy. Trust me, if I can do it anyone can. Take a look at the quick video I made, then contact Frank. He’ll help make your T2 skull look the way it should have when it left the Williams factory. Oh and by the way, you might as well snag the lit ramp signs from him while your at it!
Hi friends . I need I need help... it was happening to me that a line of light was very weak... now it doesn't turn on anymore and maybe it turns on a little and stays off... I don't know what to do anymore... please help me!!!
20220508_220202 (resized).jpg20220508_220222 (resized).jpg20220508_220224 (resized).jpg20220508_220231 (resized).jpgQuoted from Asanteiro:Hi friends . I need I need help... it was happening to me that a line of light was very weak... now it doesn't turn on anymore and maybe it turns on a little and stays off... I don't know what to do anymore... please help me!!!
What's the issue? You need to describe what you are doing and what is happening. I'm not sure what you mean by "a line of light was very weak"
Are you saying that the machine doesn't start up when you turn it on (but you've posted pics of the PF with lights on)? Or are you saying that you can't start a game?
Quoted from Pin_Fandango:Looks like he lost power on a lamp column.
As far as I can tell by the pics…
I think he means a GI string is out. Probably just a fuse if that's the case.
Quoted from EStroh:I think he means a GI string is out. Probably just a fuse if that's the case.
Arh yes possibly - it looks to me that both the central string (CPU lights) and the right string are both out
Asanteiro if it's your GI lights that you are referring to you can go into test mode and check which light strings aren't working. Then use the below to check the fuses for those strings and if they are ok then check the connections / connectivity from the power driver board to the GI lights.
T2 GI Fuses (resized).jpgT2 GI connections (resized).jpgQuoted from Averell:Hello,
I have a question regarding the adjustment A.2 21 "Drop Target Down Multiball" in the service menu.
I can't find a description for this function.
Can someone tell me, for what this setting is used for?
During multi ball the drop target normally starts in the up position, so it takes 2 shots (the first to drop the target) to lock a ball into the skull. With this setting enabled, the drop target does not raise at the start of multi ball so the first shot to the skull will lock.
You're correct about the setting (it lowers the drop target at the start of multiball if it happens to be up.) Although a slight clarification - the game doesn't intentionally raise the target at the start of MB, it just stays in whatever position it was in. Most often it will be down anyway, from when the gun was loaded to start multiball.
The exception is for starting multiball via the escape route, in which case the drop target will be up, unless this setting is set to drop it.
The other exception is if you just barely beat the timer into the skull, such that the drop target timed out and reset before the ball settled onto the switch in the skull.
Excellent - thank you for information.
I think that the drop target function must work differently.
When a multiball starts, it must stay down.
As soon as a ball is locked in the skull, the drop target must stay up.
Hey all. I was having some battery issues with my MPU board, so I replaced it with a new Rottendog one. I installed it and everything was working great at first. I went back in a few minutes later to tighten the screws on the board a bit and now my gun / plunger isn't firing. I checked all the wires etc and nothing seems loose but just curious if anyone here had any first troubleshooting solutions. Not sure if I blew a fuse on it or something. Thanks so much! G
Quoted from Luckdragon100:Hey all. I was having some battery issues with my MPU board, so I replaced it with a new Rottendog one. I installed it and everything was working great at first. I went back in a few minutes later to tighten the screws on the board a bit and now my gun / plunger isn't firing. I checked all the wires etc and nothing seems loose but just curious if anyone here had any first troubleshooting solutions. Not sure if I blew a fuse on it or something. Thanks so much! G
Go into test mode - check the shooter lane switch is working and test the plunger solenoid. This will determine which is causing the issue
Battery problems? …. Acid?
If yes check your molex connectors at the cpu and see if the terminals are green.
Green= corrosion due to battery acid, and this will cause intermittent connections at the switches.
Has anybody ever replaced the spring that goes into the gun? I bought a new spring from marco, but I feel it's too big because I can't push it down far enough to get the screws back on
Quoted from JakePG:Has anybody ever replaced the spring that goes into the gun? I bought a new spring from marco, but I feel it's too big because I can't push it down far enough to get the screws back on
If you're talking about the gun handle/shooter grip, I have, part #10-304 from Marco, and it works fine.
Quoted from jibmums:If you're talking about the gun handle/shooter grip, I have, part #10-304 from Marco, and it works fine.
yes, that's the part I got. I'll snap a picture of it later today
Was playing with test menu and settings and suddenly in test the menu freezed up, no exiting via black left button possible !!
Did an on/off and now I have a scrambled screen at start and no sound and LED D19 and D20 in on position.
When I remove the ribbon cable for audio on the MPU (upper left) the playfield comes alive and I can play, but no display, no sound.
Did a reseat of all ribbon cables and cables going to MPU board, no effect.
The LED on the DMD board is on. Also did a reseat of display cables.
Suggestions ?
3C61E1A3-824A-4B2D-B0C5-EED795556B54 (resized).JPGI believe the cable you unplugged also goes to the dmd board? My guess will be the issue being on the dmd board itself.
Try leaving the ribbon cable connected to the mpu and sound board but unplug it from the dmd board. If it works with sound then you know it’s the dmd board.
I had this problem recently as well. Was working fine then one day nothing worked. Tried re-seating all the ribbon cables a number of times but still didn’t fix it.
In the end I re-flowed solder on the ribbon cable pins on the actual dmd board and this sorted it out.
68178EC1-9D9F-4CE9-9D14-1098A2626901 (resized).jpegLeft cable connected on sound board and MPU, MPU LED's are reacting ok
D20 blinking, D21 fix on; D19 off
No audio, (and of course no display)
Playing a game goes ok...
Quoted from rvermeire:Left cable connected on sound board and MPU, MPU LED's are reacting ok
Ok so the game boots when the dmd board is disconnected, but with no audio either. I still think the issue is with the dmd board.
Do you have another working Wpc game? If you do, Put the dmd board from that game in T2 and then plug everything in and try again.
If it all works, that would confirm the issue is with the dmd board. You could also try the ribbon cables from the other game as well. It’s a case of process of elimination.
Or have you tried plugging the ribbon cable into the mpu and dmd boards in but leaving the sound board unplugged? If it dosent boot that would also indicate the dmd board being the issue.
I would try re-flowing the solder on the ribbon cable pin connectors on the dmd board.
Quoted from Ant-H:Ok so the game boots when the dmd board is disconnected, but with no audio either. I still think the issue is with the dmd
Took DMD board from my Getaway, no changes !!
so as soon as I connect a DMD board the MPU board seems to start flipping, D19 on, D21 on, D20 off...
Quoted from rvermeire:Tried :
another display : same result
Cable only between audio and mpu : works but no audio
Cable only between DMD and MPU : LEDs not ok : D19 on / D21 on / D20 off
Have a couple of other games, will first try swapping cables but doubt that will be it as this one looks quiet new compared to the other 2 ribbon cables...
If that doesn't work I'll take DMD board from my getaway, same age, so should be ok and will put T2 board in getaway as well as test.
Keep you posted...
If It doesn't boot with just mpu and dmd connected, that does point to the dmd board imo.
Yeah I don’t think it will be the ribbon cables but worth testing just in case.
Swapping the dmd board out for the one in your getaway will confirm. I put the one from my Addams in and it worked straight away.
Quoted from Ant-H:If It doesn't boot with just mpu and dmd connected, that does point to the dmd board imo.
As written , Getaway board works the same way (no display, no sound) in T2 and....
T2 board works fine in Getaway !!!
So it's something else..... anyone, ideas?
Quoted from rvermeire:As written , Getaway board works the same way (no display, no sound) in T2 and....
Ribbon cable?
I assume you swapped the ribbon cable between the 2 games... If you didn't mess with any hardware when the game went nuts in test mode, I would suspect the RAM chip.
If you swapped over the ribbon cables from getaway as well and still have the same issue, then it could be the ram chip?
swapped cable... no effect...
RAM chip is not something I have in spare ...
You mean the L-x chip (Have a L-8)
Quoted from rvermeire:swapped cable... no effect...
Thats the ROM. The RAM chip is U8 on this diagram... It will likely require some soldering skills to change. install a socket and upgrade to NVRAM if you're going to do it.
WPC CPU Board Diagram (resized).jpgQuoted from rvermeire:swapped cable... no effect...
Did you swap both ribbon cables to the DMD board or just the top one that daisy-chains with the sound board? My understanding is that the daisy chained ribbon cable sends command signals & addresses. The addresses reference the specific call-out and music held on the sound ROM (that is on the Audio board); as well as addresses to animations to display on the DMD from the DMD controller board. However the DMD controller board doesn’t have a ROM with the animations on it, but rather it has a RAM chip that is loaded with the animations at boot time from the game ROM chip on the CPU board. These animations are passed to the DMD controller via the second ribbon cable that only connects the CPU and DMD controller boards. If you haven’t already tried swapping the 2nd ribbon cable, I’d suggest doing this - make sure the game is off when swapping the cables. Typically scrambled DMD images are ribbon cable or RAM chip.
Of course this doesn’t explain why you aren’t getting any sounds - when you turn the game on, do you get the single “dong” sound? This indicates that the sound board is working correctly
If you want to confirm the issue is on the CPU board, you could swap the CPU boards b/n the T2 and Getaway - you’ll need to also swap the game ROM chips on the CPU boards.
Quoted from Manny65:Did you swap both ribbon cables to the DMD board or just the top one that daisy-chains with the sound board? My understanding is that the daisy chained ribbon cable sends command signals & addresses. The addresses reference the specific call-out and music held on the sound ROM (that is on the Audio board); as well as addresses to animations to display on the DMD from the DMD controller board. However the DMD controller board doesn’t have a ROM with the animations on it, but rather it has a RAM chip that is loaded with the animations at boot time from the game ROM chip on the CPU board. These animations are passed to the DMD controller via the second ribbon cable that only connects the CPU and DMD controller boards. If you haven’t already tried swapping the 2nd ribbon cable, I’d suggest doing this - make sure the game is off when swapping the cables. Typically scrambled DMD images are ribbon cable or RAM chip.
Just swapped other cable as well but no effect
Have one dong at start, when only flat cable is connected to audio board and not to DMD board. If DMD board is connected as well NO dong...
Wille change CPU board with Getaway one today (CET time)
Quoted from TheOnlyest:Thats the ROM. The RAM chip is U8 on this diagram... It will likely require some soldering skills to change. install a socket and upgrade to NVRAM if you're going to do it.[quoted image]
Chip I have on mine is a MS6264L-10PC, are both types ok to use ?
NVRAM ? you mean there is a RAM chip integrating Nvram ? model ?
Quoted from rvermeire:Chip I have on mine is a MS6264L-10PC, are both types ok to use ?
FM1608
Quoted from Manny65:Go into test mode - check the shooter lane switch is working and test the plunger solenoid. This will determine which is causing the issue
Thanks Manny! I went into test modes. Shooter lane switch is working but plunger solenoid isn't. So weird since it was working when I had the new board loosely installed, then stopped working when I tightened it up. I tried loosening it a bit but didn't make a difference.
The manual says the plunger plugs in at J127, so I checked that, replugged it etc.
Here's a little video of the new board installed, in case anything leaps out.
https://www.dropbox.com/s/k10aik9ucd2d04g/IMG_3048.MOV?dl=0
Thanks so much for the guidance! G
Quoted from Luckdragon100:Thanks Manny! I went into test modes. Shooter lane switch is working but plunger solenoid isn't. So weird since it was working when I had the new board loosely installed, then stopped working when I tightened it up. I tried loosening it a bit but didn't make a difference.
So check you have 50v at the plunger coil. Check the resistance of the plunger coil. If both of these test good then try grounding the driver transistor tab for the plunger solenoid, if that works then test your driver transistors - the Pinwiki WPC webpage will give you details of how to test
Quoted from Zigzagzag:FM1608
Thx!!
Gonna see if I can get hold of on quickly, in the mean time I'm gonna try my Getaway CPU board...
Just did a swap and now it works fine...
Is there a way to test this U8 to be sure that's the exact cause before soldering it out ?
Quoted from rvermeire:Is there a way to test this U8 to be sure that's the exact cause before soldering it out ?
Unfortunately not with it soldered in place, you'd need a Williams test set for that. All your symptoms indicate a RAM issue, and i'm quite confident that is the problem. The fact that this started when you were in the game settings (which are stored in the RAM chip) when the problem started, is the primary factor in my diagnosis.
Quite a few people see their RAM chips fail in games 20-22 years old, especially ones that were heavily routed and powered on the majority of its life. Upgrading to the NVRAM will give you the benefit of current tech and eliminate the need for batteries. You should also de-solder and remove the battery holder from the board while you have it on bench.
Quoted from Manny65:Ah, sí, posiblemente, me parece que tanto la cadena central (luces de la CPU) como la cadena derecha están apagadas
Asanteiro , si se refiere a sus luces GI , puede pasar al modo de prueba y verificar qué cadenas de luces no funcionan. Luego use lo siguiente para verificar los fusibles de esas cadenas y, si están bien, verifique las conexiones / conectividad desde la placa del controlador de alimentación hasta las luces GI .[quoted image][quoted image]
Hello friends ...
How are !!!!
I tell them that I solved the problem of the lights, under the Pf had a cable almost cut .. black / red color.
I cut it and put it back together.
Issue solved !!!!
Quoted from TheOnlyest:Unfortunately not with it soldered in place, you'd need a Williams test set for that. All your symptoms indicate a RAM issue, and i'm quite confident that is the problem. The fact that this started when you were in the game settings (which are stored in the RAM chip) when the problem started, is the primary factor in my diagnosis.
ok, thx
Last question: I see FM 1608 P (64KB) and FM 1608-120-PG (no idea what 120 and G stands for)
Is first one ok as that's the one my regular supplier has available.
Quoted from rvermeire:ok, thx
Standard RAM is a 28-pin FM1608-120... 120 is the chip speed, ignore the letters after. This is probably NOT NVRAM unless it specifically says so.
For NVRAM, google "RAMTRON FM1608 NVRAM" and order one from a pinball supplier that will ship to you, sorry I cant be much help for the German market.
Make sure you get a 28-pin DIP socket for it and solder that onto your CPU.
Quoted from Manny65:So check you have 50v at the plunger coil. Check the resistance of the plunger coil. If both of these test good then try grounding the driver transistor tab for the plunger solenoid, if that works then test your driver transistors - the Pinwiki WPC webpage will give you details of how to test
Thanks Manny. You've always been a big help to me (and lots of others on here).
I'm still learning, so I got scared of some of those tasks and terms haha, but I sacked up and turned on the machine to get started....
And now the plunger is working again... haha
Will see if it starts acting up again but hopefully not.
Thanks again,
G
Quoted from TheOnlyest:Standard RAM is a 28-pin FM1608-120... 120 is the chip speed, ignore the letters after. This is probably NOT NVRAM unless it specifically says so.
so this is ok despite the 120 is missing ? Or do I need to make sure it has a speed of 120 (ns I guess)
fm1608 (resized).pngQuoted from rvermeire:ok, thx
FM1608 is nonvolatile : https://www.farnell.com/datasheets/82469.pdf
There are no "volatile" versions of this chip.
I have ordered from AliExpress and have not had any issues whatsoever.
Quoted from rvermeire:so this is ok despite the 120 is missing ? Or do I need to make sure it has a speed of 120 (ns I guess)
Yes, that will work.
This page was printed from https://pinside.com/pinball/forum/topic/terminator-2-clubmembers-only/page/182 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
