(Topic ID: 27799)
Terminator 2 Club....Members Only!
By spfxted
7 years ago
  • 7,570 posts
  • 554 Pinsiders participating
  • Latest reply 17 hours ago by Frogman
  • Topic is favorited by 194 Pinsiders
There have been 2,532 images uploaded to this topic. (View topic image gallery).
williams-terminator-pinball-playfield_1_24c6bc70ba237494809ad1e191a49ee3 (resized).jpg
There are 7570 posts in this topic. You are on page 152 of 152.
#7551 10 days ago
Umm, those post sleeve rubbers come in several colors! You can make it any color you want! Mine is a Titan red, because I wanted it to be and put it there! My Special inserts are also red.
#7552 9 days ago
yeah we know, mine are getting changed to blue. I believe they are saying those are still the original factory sleeves?
the special insert being clear IS unique
#7553 9 days ago
Quoted from TheOnlyest:
How about some pictures of those red post sleeves installed?
#7554 8 days ago
Can someone do me a huge favor and post a picture of the wiring to the drop target coil behind the skull? The 26-1200 coil, not the smaller 26-600 coil.
#7555 7 days ago
Quoted from aztarac:
Hope these help.
#7556 7 days ago
Quoted from jibmums:
Hope these help.
Perfect - thank you!
#7557 6 days ago
Anyone who has a good picture on how the metal for the light in pop bumpers are connected? I know some where soldered together.
#7558 6 days ago
I’m having a problem with my drop target popping up multiple times when it resets in between balls or the start of a new game. The game will pop up the drop target 3-5 times instead of popping up once. Anyone know how to fix this?
#7559 6 days ago
Quoted from tezting:
Anyone who has a good picture on how the metal for the light in pop bumpers are connected? I know some where soldered together.[quoted image]
You're in luck - just got done stripping a playfield. Hope this helps- white wires from the harness were soldered at the 'V' in the metal tabs at the bottom of the picture (by the t-nut) and the yellow wire was soldered at the 'T' in the metal tabs in the middle of the picture.
#7560 5 days ago
You're in luck - just got done stripping a playfield. Hope this helps- white wires from the harness were soldered at the 'V' in the metal tabs at the bottom of the picture (by the t-nut) and the yellow wire was soldered at the 'T' in the metal tabs in the middle of the picture.[quoted image]
Thats perfect! Thank you so much
#7561 5 days ago
Bump, anyone?
Quoted from jugood20:
#7562 5 days ago
Bump, anyone?
I'd start by looking at the switch on the drop target assembly. If its misaligned or broken, it may be causing the issue.
#7563 2 days ago
Anyone know a place that has this in stock? (I think its the right one forT2)
#7564 23 hours ago
I'm looking for an EPROM that fixes the attract sounds always playing. I had read a little while back that you could get an EPROM that fixed this, seemed to be a modification of L-8 (I think, I'm new here). If anyone knows where I could buy one and could let me know, I'd greatly appreciate it.
#7565 20 hours ago
Yes, there's a version available without this disturbing "Bäng Bäng Bäng".
#7566 19 hours ago
Quoted from Metroshica:
Here you go:
https://www.vpforums.org/index.php?app=downloads&showfile=6347
The sound made me nuts and this EPROM is the fix!
#7567 17 hours ago
If you have pinsound installed in you T2, you can delete "explosion5" from your usb drive and that will get rid of the attract sound as well. Although it does also delete the match sound because they are the same sound. But I usually turn off match anyway.
#7568 17 hours ago
Can't you just go to adjustment #16 in the Feature Adjustments and set if to "off"?
#7569 17 hours ago
That didn't work for me. I assume others have had that problem as well.
#7570 17 hours ago
That would make sense...but no.
Flashinstinct
$ 70.00
The Pinball Vault
