(Topic ID: 27799)
Terminator 2 Club....Members Only!
By spfxted
7 years ago
  • 7,480 posts
  • 549 Pinsiders participating
  • Latest reply 1 day ago by J_Striker
  • Topic is favorited by 194 Pinsiders
There have been 2,495 images uploaded to this topic. (View topic image gallery).
There are 7480 posts in this topic. You are on page 150 of 150.
#7451 23 days ago
Quoted from Manny65:
I assume you mean the actuator arm (the metal strip that the ball makes contact with) has come off the black plastic knob on the switch body, that the actuator arm pivots on. In this case unscrew the switch off the wireform so that it is easy to handle, the actuator arm will have 2 holes that clip onto those knobs on the switch (1 on either side of the switch). If that area of the actuator arm has been stretched you may need to press the metal sides slightly together so that it doesn't pop off the knobs on the switch. If the knob has been completely worn down and won't hold the actuator arm in place then you'll need a new switch. Once you have clipped the arm back into place, you should be able to press the arm and hear the switch click. Then just screw the switch back into place (note that the switch will need to be positioned such that a ball passing by will trigger the switch but still allow the ball to continue on down the wireform).
Thanks so much for all the advice and help with the lingo! I took it apart and was able to click it back into place. Best, G
#7452 22 days ago
Quoted from Glycerin:
Any one got some used slingshot plastics I could buy from them?[quoted image]
I got them...
#7453 22 days ago
Does everyone think this is the best idea to re-chrome the shooter gun? Thanks! G
#7454 22 days ago
Mmmh, no good idea!
#7455 22 days ago
Quoted from Luckdragon100:
The best idea is to send it out to someone who does chroming. There's tons of businesses that do this. It's not that expensive and will look amazing.
#7456 22 days ago
Does everyone think this is the best idea to re-chrome the shooter gun? Thanks! G[quoted image]
No, send it to Chris at Hot Rod Arcade for a quick exchange. Price is reasonable and quality is superior than spray paint...
#7458 21 days ago
I'm working again on the playfield, it's a hell of work but I'm confident to end the preparation for the final clear coating this weekend.
Some areas had been worn to the wood and I refurbished that step by step.
All the holes had been heavily damaged and were maintained again.
Now I have to do some fine artwork and redraw some inserts, clean the playfield and then it's done.
#7459 21 days ago
Quoted from Rob-T-800:
Here is the reason my pop bumper caps are opaque white. They light up red and the center flashes blue when struck
I'm interested in doing something similar in my HS2. What are you using to create the 2-color LED effect under the opaque caps?
#7460 20 days ago
I recently moved and noticed my T2 isn't playing as fast as before. Where should the feet be positioned on front and back legs? Thanks for all replys
#7461 13 days ago
Hello to all
We are busy rerunning the Terminator 2 playfield plastic set. The plastic will be printed in Silk Screen with the flouresent orange / red
If you wish to purchase a set, then please send me an email to peter at buthamburg dot de with your postal address. The plastics
should be ready in 3 weeks, Begining of Nov. The plastic set will go for 155 Euro + shipping, USA / Can 45 Euro. Shipping to Aus. 55
We still have some Terminator cabinet decal sets available, also printed with silk screen.
Regards from Hamburg
Leon and Peter
#7462 11 days ago
Added chrome molding to my T2 to cover up some rough wood patches and add a little pop. Thanks calico1997 for the idea!
#7463 11 days ago
Doing a restore and lost some of my pictures, can someone post pictures of the front inside corner of their cabinet that shows where these wires connect?
20191006_143031 (resized).jpg20191006_143041 (resized).jpg20191006_143046 (resized).jpg
#7464 11 days ago
#7465 10 days ago
Do someone know what size t-nut that are used to hold the plastic close to the flippers? (2*3)
Image has the original one and one I thought was the right one (a little to big)
#7466 10 days ago
Quoted from tezting:
Image has the original one and one I thought was the right one (a little to big)[quoted image]
U have 3 choices: 6-32, 8-32 or 10-32
#7467 10 days ago
I guess it must be that one then as I have tried the other two
#7468 8 days ago
I have a near complete used plastic set. It’s only missing the the hands that overlay the slight shots. PM me if you are looking for a set.
#7469 7 days ago
Quoted from jjoravec:
Doing a restore and lost some of my pictures, can someone post pictures of the front inside corner of their cabinet that shows where these wires connect?[quoted image][quoted image][quoted image]
#7470 6 days ago
Hi, Can anybody post Pictures from the connectors j115, j120 and j121?
#7471 6 days ago
Quoted from lash:
#7472 6 days ago
lookie what I bought at whiterose, thanks pindoctor
#7473 5 days ago
Quoted from Malenko:
I hope its just the photo quality, otherwise the colors on that PF are very badly faded... And if so, I hope you got a killer deal on it!
#7474 5 days ago
Don't worry, if it's a BUT playfield it es balanced perfect!
#7475 5 days ago
Quoted from TheOnlyest:
Its my crummy cam, the PF is pretty much perfect. There is an ever so slight raise in the "you'll be back" insert but I'll take that over the wear at the hotdog insert on my current PF.
#7476 5 days ago
Do ALL the hotdog insert problems occur right there?! I had a devil of a time clamping mine down so it laid flat.
#7477 4 days ago
No they don't, the most damaged are the chip and the hole under the skull, but easy to fix.
#7478 4 days ago
Hello to all
The Terminator 2 Playfield Plastic sets are printed. The red / orange came out fantastic.
We are starting to mill the sets today. If anyone wants to purchase a set, then please send me
an email directly to peter at buthamburg dot de . We still have a handfull available.
Leon & Peter
#7479 4 days ago
Hi,
I need to order new rubbers for my T2 restoration.
What should I buy? The standard sets must shops have? Or something else? If - please share image and pro/cons
#7480 1 day ago
I have a T2 VHS from Williams released with the original launch of the pinball machine. Anyone here interested in it? Don’t really know what it’s worth.
2,900
San Diego, CA
