My kickback has never failed to run it back up to the pops. I’ll check my coil size when I get home and report back with the info
Quoted from embryonjohn:My kickback has never failed to run it back up to the pops. I’ll check my coil size when I get home and report back with the info
Thank you.. I've tryed alot to get it there ,every 6 times it may make it once....
Quoted from Milltown:Thank you.. I've tryed alot to get it there ,every 6 times it may make it once....
Mine is off route, have not done a thing to it (hey ive been busy) and it makes it to pops every time. Is your game leveled left to right and at what pitch?
Quoted from PeterG:Which Nr. Coil or color (blue, red, green)?
I put FL1-11629 (Blue) coils in. Also gets the balls up the ramps nicely. I do get an occasional fly ball, but not very often. FL1-15411 (Orange) would also probably work, but a little less powerful.
Quoted from CoPinfan:I put FL1-11629 (Blue) coils in. Also gets the balls up the ramps nicely. I do get an occasional fly ball, but not very often. FL1-15411 (Orange) would also probably work, but a little less powerful.
Cool thank you very much...,
Quoted from Langless28:Mine is off route, have not done a thing to it (hey ive been busy) and it makes it to pops every time. Is your game leveled left to right and at what pitch?
No shit.. Haha . ya I triple checked the level ,. Re sleeved the coil . waxed everything up. ECT ect...
Not sure on the pitch... Have not checked it actualy .. Whats yours at ?
Wait on the kicker ? My flippers kick ass but the kicker rarley makes the pops...
Quoted from Milltown:Wait on the kicker ? My flippers kick ass but the kicker rarley makes the pops...
No sorry, I was talking about the flippers.
Here’s my kicker.
Could you be missing the rubber tip at the end?
Quoted from embryonjohn:One last thing to check on. If the micro switch got bent up during an over zealous cleaning, it might trigger prematurely. It’s best when it kinda triggers late during the ball roll over, giving it the full push/kick up.[quoted image]
Thanx man .., im gonna check,my coil # and make sure the switch isn't outa wack...
Quoted from embryonjohn:Here’s my kicker.
Could you be missing the rubber tip at the end?[quoted image][quoted image][quoted image]
Is this were yours naturally sits ?
Quoted from Milltown:Is this were yours naturally sits ?
No. I pushed it out from behind the coil to show the tip
Quoted from embryonjohn:No. I pushed it out from behind the coil to show the tip
Ok cool...i was like wtf ? Mine is way off.. Haha
Quoted from PinKopf:Trying to figure out if I have a problem with mine, or just buggy software: do you guys frequently have multiball rounds end unexpectedly/jackpots seem to cancel out before shooting the cannon?
Everything works normally with mine, all switches test out going through each in the edges test. I don't think it's just losing track of balls or a normal trough switch issue and thinking I've drained, as the ball doesn't end and I've never had it think I drained improperly in single ball play. But I guess I will recheck those. I also don't think it has ever offered the pity jackpot grace period to load the cannon either when it does this... it's just boom back in single ball gameplay. Several times I've started payback time right in the middle of a multiball, I was thinking that shouldn't be happening.
Yes, I run into this all the time on multiple T2s and it seems like a software bug. I'm so fed up with it I'm currently in the preliminary stages of figuring out how to fix it... disassembling the ROM and going through the code that keeps track of number of balls in play.
Here is how it usually manifests for me: Start multiball. Now, lock the ball that is in play quickly before the game manages to get the other two balls on the field. At this moment the game becomes confused and loses track of the number of balls in play and believes that multiball is over -- if you locked the first ball in the gun, it has you take the shot to start multiball again; otherwise, it just ejects it from the lock and goes into normal single-ball play but with 3 balls on the field. Every time you drain a ball, you hear the "end of ball" music but then the game keeps going. This is super frustrating because when you get good enough at the game you start triggering it accidentally all the time by locking balls too fast and screw yourself out of your jackpot shot.
Quoted from tezting:Hi,
When I toke my T2 apart 4 years ago I forgot to take a picture of where the plastic where the glass slides under the siderails where placed. Do someone have an image or can tell me the distance?[quoted image]
Easy. Just slide the channel all the way to the back.
Quoted from Scoot:Easy. Just slide the channel all the way to the back.
Thank you!
Can someone tell me when the CPU inserts are supposed to light up in the center of the playfield. When I got my T-2 they stayed on all the time like they were part of the GI, however i had some burnt GI connectors and hacked wires. I redid everything and got rid of the hacks and now I noticed the CPU does not lit up all the time like it was. It does flash at certain times during game play. What is this light supposed to do?
hello friends how are you ... I need to consult them .. change all my T2 to LED. some give me ghosts .. few, but I have some.
I read looking for information that you have to change a room? this is true?? I tried all kinds of lamps. Bone change from one place to another and it is by sector ... example the lights of the target card under the hunter. Can somebody help me ?? thank you
I need some help.. again..
Has any one installed the "newer style lockdown bar receiver"?
My old T2 one was in very bad shape so I bought a new one. The only one I could find in EU was the new style one.
I think I had read somewhere that I could install the new style one without any issues.
But now I have tried and it does not seem to align up correclty?
Has anyone installed newer style lockdown bar receiver in a T2? And can you give advice? Or have I just wasted 110 euro
Receiver (resized).jpgQuoted from fatality83:Can someone tell me when the CPU inserts are supposed to light up in the center of the playfield. When I got my T-2 they stayed on all the time like they were part of the GI, however i had some burnt GI connectors and hacked wires. I redid everything and got rid of the hacks and now I noticed the CPU does not lit up all the time like it was. It does flash at certain times during game play. What is this light supposed to do?
The CPU inserts are part of the GI and have a separate string (White-Green & Green). You can test the specific string in Test Mode under "Gen'l Illum"
... additional info
Just had a quick look and the manual doesn't mention the CPU string - here's a comparison between the manual and the test mode info from my machine for your reference:
Top Insert - White/Brown (manual) White/Brown (machine)
Bottom Insert - White/Green (manual) White/Orange (machine)
Left Playfield - White/Violet (manual) White/Violet (machine)
Right Playfield - White/Yellow (manual) White/Yellow (machine)
CPU - (not listed in the manual) White/Green (machine)
Not Used - White/Orange (manual)
So just check if you have all 5 strings connected to the PD board
The 3 playfield strings connect to J121 as shown below
cf40d2b9b8e0d798ed5e18c6ccfe89b219233114 (resized).jpgQuoted from tezting:I need some help.. again..
Has anyone installed newer style lockdown bar receiver in a T2? And can you give advice? Or have I just wasted 110 euro [quoted image]
No T2 members have changed there lockdown bar receiver?
Quoted from Rob-T-800:I found a better ship im ordering. This one is from led pinball mods.[quoted image][quoted image][quoted image]
Did you mean Lighted Pinball Mods? Or have you got a link where you got this from? As I can't find it
My lockbar is old and rusty but I will fix it later. Just a polish will do. No experience on any bally williams machine with replacing the lockbar....sorry
Quoted from Manny65:Did you mean Lighted Pinball Mods? Or have you got a link where you got this from? As I can't find it
Yea lighted pinball mods. Im waiting to get one still
Quoted from tezting:No T2 members have changed there lockdown bar receiver?
pretty sure I have with no issues.
same on getaway, bop and creech.
show pics of your issue?
Quoted from KJS:pretty sure I have with no issues.
Love the avatar mate!!
Been meaning to drop you a message - I was looking at a post of your T2, is your Hunter Killer ship the Cinemachines Die-Cast HK one?
Quoted from KJS:Hi Manny
yes and modified[quoted image][quoted image]
Hadn't noticed the thruster LEDs - fantastic mod! You are truly the mod master and such an amazing looking pin!!
Quoted from Manny65:The CPU inserts are part of the GI and have a separate string (White-Green & Green). You can test the specific string in Test Mode under "Gen'l Illum"
... additional info
The 3 playfield strings connect to J121 as shown below[quoted image]
Thank you!
Quoted from embryonjohn:Here’s why my T2 had poor left speaker sound...
It was stuffed in between the speaker and the grill.[quoted image]
Wow, that is an odd one!
Likely the work of some dumbass (probably an operator) who doesn't know how to adjust the volume!
Quoted from rjsoeps:I really like these apron cards.
Does anybody have these?
And is willing to share them.
Thanks[quoted image]
Yep you can get it here http://www.pinballrebel.com/game/pins/instruction/t2_custom_cards_2011.pdf
Have any of you had to repaint any of the bright orange keylines around your playfield inserts? If so, what brand and color did you use, and how close a match was it?
What's your record for consecutive orbits?
Hitting that 3 or 4 times back in 1992 was one of the first things to really cement my love of pinball.
Quoted from jibmums:Have any of you had to repaint any of the bright orange keylines around your playfield inserts? If so, what brand and color did you use, and how close a match was it?
You can get perfect match with createx fluorescent. I also think there Vid also talks about it in he’s playfield thread. (Might be wrong. But read about it when I had to do it)
Hi T2 owners I’m building a T2 from scratch and have a playfield and cabinet. I’m after any spare parts you might be willing to sell. Ramps , rails, assemblies, plastics anything you can spare. I’m in Australia and got the $$$ for shipping So if you’re willing to help me out let me know what you have cheers Brendan
Quoted from Brendo78:Hi T2 owners I’m building a T2 from scratch and have a playfield and cabinet. I’m after any spare parts you might be willing to sell. Ramps , rails, assemblies, plastics anything you can spare. I’m in Australia and got the $$$ for shipping So if you’re willing to help me out let me know what you have cheers Brendan
Should it be NOS? Or can it be used? Mint or with damages?
Parts can be nos, used, damaged just let me know what you have
Quoted from tezting:Should it be NOS? Or can it be used? Mint or with damages?
Hi Brendan
I've got some used parts - off the top of my head .... a translite, plastics, a wireform, speaker panel etc but will need to check exactly what I have if you are interested.
Cheers
Brett
Quoted from Manny65:plastics
Hi Brett I have sent you a message through pin mail let us know what you got very interested cheers
This page was printed from https://pinside.com/pinball/forum/topic/terminator-2-clubmembers-only/page/148 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
