Hey pinsiders, this is my first post question. I have a T2 machine that was refurbished a few years ago. Recently been having trouble with the cannon motor running constantly on start up. Read the posts here and did suggested tests. Also changed batteries. No corrosion.
In test mode the cannon motor runs but the cannon does not turn. Under deck you can see the motor trying to move the cannon but it seems stuck. If you try to help it rotate you can see the rotator circle but it won't move the cannon on its own.
Any thoughts ? Fixable or buying a new cannon assembly? Thanks for any help !!
