New! Dark mode!
(Topic ID: 158927)
Terminator 2 Cannon Problem
By troxel
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by SOKOL
#1 4 years ago
I cannot figure out my cannon problem on T2. The cannon will not swing all the way back in the home position, and therefore, the ball get's stuck in the rail and won't drop into the cannon. I have adjusted both switches, but doesn't make any difference. The cannons seems to make the same trajectory no matter where the switches are (or open/closed). Both switches register as open and closed during gun test.
I have taken apart the cannon and gave it a good cleaning.
What in particular needs to be adjusted so the cannon can go more to the right?
#2 4 years ago
I think I just physically nudged mine over when it looked like that. It almost clicks into place it felt like.
#3 4 years ago
Try to adjust again home position with the "home" switch: open two screw and set grade "+" or " -" .
$ 159.99
PinSound
