(Topic ID: 262718)
*SOLVED* Tell me what was wrong with my F-14 and win a prize.
By Beechwood
1 year ago
  • 79 posts
  • 38 Pinsiders participating
  • Latest reply 1 year ago by fireball2
    There are 79 posts in this topic. You are on page 1 of 2.
    #1 1 year ago
    **EDIT: Added another prize as some felt my original package was underwhelming (My wife said my package was "fine" but I was disappointed with the tone she used). Added a metal novelty sign for the winner. See pic.**
    My F-14 started acting oddly all at once. The left lane save kickback coil would start firing like a jackrabbit on a date for no apparent reason, and stop just as quickly. Soon into the game, the upper VUK wouldn't fire the ball into the lock, and then two balls would be loaded into the shooter lane, rendering the game unplayable. Turn game off and back on, and in attract mode whenever the game fired up sound and the topper, the ball save coil would fire again like a desperate red head swiping right on Tinder. I looked high and low for shorts and re-seated cables/connectors to no avail. And as these coils were not in the same row or column, I was baffled.
    Eventually, I found the culprit. Do you have a guess?
    First one to correctly post the answer wins the prize. If no one does, the closest guess will win.
    Grand prize is: 2 BRAND NEW Solo Cups (red in color), 4 gently used 555 bulbs, and a piece of string (manufacture and length unknown)
    Good luck, and remember... H.I.O.P (Hey, it's only pinball)
    #2 1 year ago
    A/C relay for solenoid bank select?
    #3 1 year ago
    Quoted from barakandl:
    No, but thanks for playing! Unfortunately I can't afford a consolation prize... I have pinball machines
    #4 1 year ago
    Loose screw fell behind circuit board.
    #5 1 year ago
    "I'm sure it just needs a fuse"
    #6 1 year ago
    Quoted from chad:
    My wife did find a few screws loose, but that was me. Not the pin. Thanks for your guess!
    #7 1 year ago
    Quoted from bluebomber:
    That was going to be my selling point if I couldn't figure it out
    #8 1 year ago
    Transistor on a coil or switch?
    #9 1 year ago
    Nice prizes, but I am stumped.
    #10 1 year ago
    Quoted from 2manypins:
    Ah, dude... so close. But no. Maybe you have too many pins.
    #11 1 year ago
    Did I mention the Solo Cups are dimple free??
    #12 1 year ago
    My guess is that you had a switch matrix wire wire coming into contact with either your GI string or the light matrix. This was sending false closures the the MPU, triggering coils.
    #13 1 year ago
    Short to ground somewhere on the driver board
    #14 1 year ago
    Left a tool that shorted stuff out.
    #15 1 year ago
    All great guesses. Obviously you all have experience with some crazy shit.
    But no....
    Thanks for playing. Vanna please show them the door.
    #16 1 year ago
    Loose/bad ribbon cable?
    Nevermind saw you checked that.
    Bad / broken diode?
    #17 1 year ago
    Quoted from erak:
    "and re-seated cables/connectors to no avail"
    Good day... I SAID GOOD DAY.
    But thanks for the guess
    #18 1 year ago
    Corrupted roms? (I've heard and seen a lot stranger things, and all the obvious stuff has already been said lol)
    #19 1 year ago
    Quoted from Frax:
    Stranger Things is not like F-14, but thanks for playing.
    NEXT!
    #20 1 year ago
    Loose CPU or game ROM chip.
    #21 1 year ago
    diode reversed on the upper vuk switch
    #22 1 year ago
    Quoted from GRUMPY:
    Ugh. That reminds me of the No Fear I had...the ASIC socket was cracked. I missed it, and my wife found it. Replaced that sucker and it was great after that, but that was some fun soldering times..
    #23 1 year ago
    Power supply capacitors....
    #24 1 year ago
    Awe, shit Morty. They are trying so hard.
    But NOPE suckers.
    Thanks for playing!
    #25 1 year ago
    You replaced a flipper coil and a drop of solder fell on the large diode board on the bottom of the playfield causing havoc.
    #26 1 year ago
    Quoted from pinballplusMN:
    I wish... that would have been an easy find. But Wrong!!
    NO SOUP FOR YOU!!!
    Thanks for playing
    #27 1 year ago
    Too many balls?
    #28 1 year ago
    solder splash on a switch....
    #29 1 year ago
    This game has 4 balls... already 2 too many. So no.
    No solder drips.
    The reason was so damn stupid... but the symptoms were so weird.
    Keep guessing!!!
    #30 1 year ago
    A literal bug in the machine
    #31 1 year ago
    Quoted from TreyBo69:
    Gremlin is the accepted term in my f**ked up mind.
    But, no.
    Thanks for playing.
    Keep the line moving.
    #32 1 year ago
    Got a mouse in there ( under the cups now)
    #33 1 year ago
    Quoted from rvdv:
    If the mouse was under my cup now, it would be pretty fucked up.
    It's happy hour in Hudsonville.
    But no.
    Thanks for playing, get your parking ticket validated on your way out.
    #34 1 year ago
    One of the wires in switch came unsoldered or if ball trough has led switch it was out?
    #35 1 year ago
    Did this start happening on its own or had the game been worked on just recently?
    If no recent work done, battery acid damage on driver board causing switch matrix confusion or a cracked diode lead on a switch or flipper coil.
    If recent work done, diode installed backwards
    #36 1 year ago
    Quoted from holminone:
    Getting closer, but NO!
    Thanks for the response
    #37 1 year ago
    Quoted from PNBLWZD:
    Nope, worked great then just went to shit.
    #38 1 year ago
    Drunk gremlin
    #39 1 year ago
    Broken spring in a coil?
    #40 1 year ago
    Quoted from guss:
    Drunk gremlin
    Hahaha... best answer yet, and very close.
    But unfortunately no.
    #41 1 year ago
    Getting closer, but no.
    C'mon... who wants those bitchin Solo cups?? That is like a $0.49 value.
    Gawd....
    #42 1 year ago
    Broken ball trough switch actuator broke off and found its way over to the kickback rollover switch.
    #43 1 year ago
    Quoted from mikat11:
    That sounds fricken cool... but no.
    You guys have seen some shit, I gotta give it to you.
    But this was not that.
    NEXT!!
    #44 1 year ago
    Broken leaf from contact switch slid down and shorted
    #45 1 year ago
    Quoted from Manimal:
    So close but no.
    Now back of the line you go!!
    Thanks for playing
    #46 1 year ago
    Benthic monkfish lay an egg in the VUK again?
    #47 1 year ago
    Shorted flasher?
    #48 1 year ago
    Quoted from EasternBloc:
    It didn't smell like fish, and I checked my fingers to be certain...
    So no.
    Thanks for playing.
    #49 1 year ago
    Quoted from ryan1234:
    Shorted flasher?
    Ryan my man, you are the closest so far.
    Make room for some sweet ass solo cups if no one else gets closer.
    #50 1 year ago
    Fun thread!
    Lighting - Under Cabinet
    $ 310.00
    Merf's Pins
    $ 9.00
    $ 4.49
    $ 36.99
    $ 12.00
    $ 119.99
    Cabinet - (Alt) Translites
    FlyLand Designs
    $ 69.99
    $ 54.99
    3D MODS
    Various Novelties
    GC Pinball
    $ 74.99
    Playfield - Plastics
    Pin Monk
    $ 209.99
    PinballBulbs
    $ 47.00
    Cento Creations
    $ 19.99
    $ 14.95
    Metal-Mods
    $ 229.99
    $ 54.99
