New! Dark mode!
(Topic ID: 212685)
Teenage Mutant Ninja Turtles Power board problems
By steveoc
2 years ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by steveoc
There have been 14 images uploaded to this topic. (View topic image gallery).
#1 2 years ago
I have a Teenage Mutant Ninja turtle Pinball machine.
I have owned for a few years now and up until a recent move, it was functioning ok. I have to admit, I rarely even opened her up as the lamps didnt even blow.
However after the move - I noticed she took longer to boot up - until eventually all she did was hum very loudly.
I have attached pics of my power board. 2 things are of concern. the first is the fix to what looks like damaged track. the second is the way that the cables going into the top right of the board have been crimped and have melted - as in overheated at some stage.
1) Do you think I need a new board, I have seen a service on ebay that replaces the caps. unsure whether worth it if the board is going to keep blowing caps
2) is this the normal way for the cables to go into the board? should they not go into the connector?
Any help gratefully received
Kind regards
Steve
#2 2 years ago
%100 not the way the cables are supposed to go. It's not hurting anything, but if you got a new board, it wouldn't just be plug and play. What happens is that the general illumination, being on all the time, gradually overheats the wires that carry the voltage to and from the lights. The plug gets all burny and melty, and then the connection fails. So here they just combined all the wires into two bundles, and then soldered a connection to the board. It works, but it's not correct.
#3 2 years ago
Tip: Scrap those batteries and get NVRAM.
#4 2 years ago
right I have moved along a bit now...got a new board from x-pin....
got a connector and getting closer...
But fuses kept blowing and with the help from the guys at Pinball heaven - I have got further - game boots - flippers now full , but wont hold , ball wont release from sewer, yet sewer pops up at first boot..
got a couple of dodgy solenoids,
first one was just the free play one, so leaving that... the other two were the ball release.. and there is one by the ball pinger - didnt even release that it had a solenoid to assist.
Slowly slowly getting there but it seems one step forward finds a new problem.
thinking about just replacing the ppb board completley rather than trying to find the trannies out
any advice ??
#5 2 years ago
It sounds like your sewer has a switch problem, if the solenoid will fire but it's not behaving correctly. What you need to do is go into test mode, and try and fire the problem solenoids through there. If you hear any noise at all, the problem is in the mechanism or the related switch, and not the solenoid.
It depends how much you feel like soldering for the ppb board. It's really easy to find out what transistor goes with what solenoid (look in the manual on page 29). If you still have trouble or aren't sure, tell me which solenoid it is and I'll tell you which transistor goes with it. Worse to worse, you can always just replace them all. They're cheap 36c transistors. The catch with the ones that run through the PPB is that either the transistor on the ppb is bad, or the one that triggers it on the mpu is bad. And it could be neither - it could be a broken wire! So make sure to check your wire continuity.
#6 2 years ago
just replaced the whole board instead with a new xpin one - sorry but think I am running two posts now - anyway to merge?
#7 2 years ago
Quoted from mikat11:
how do I do that - very new to pinball machines - despite owning for a while, not had to do much
Professor Pinball
$ 23.00
$ 54.99
COINTAKER.COM
$ 54.99
$ 7,599.00
