Quoted from DaddyManD:Love the new code, Thanks xaqery
Installed a new shaker motor. It is perfect except when Pizza Multiball starts it goes nuts and rattles the entire machine. I have screwed in the threaded rod as tight as it can go without warping the shaker motor. I switched shaker motors from another machine so its not the motor. Lowered to minimal use...anyone having this issue during Pizza Multiball?
Here is how I toned down my shaker motor, because merely setting to minimal use, does not tone down the shaker motor, it just makes it so it is not used as much in the game software:
Solved the issue and can again enjoy the shaker motor without fear of my motor ruining the game elsewhere.
Removed it from the cabinet: remove two top case screws. Then remove four bolts holding unit to table cabinet base.
Also tried using an Allen wrench, only to strip it. Attempted torque wrench and broke head. Wishing I hadn’t started this project, lol. Used Vise Grip Pliers to finally loosen 1/32nd screw nub. Destroyed screw nib getting it off. Purchased new screw and put it in the 90 degree angle hole to retighten. 90 degrees position offset it to the other side weight. Putting only a drop of lock tight on the screw before inserting.
Real issue with original screw is that it had tons of lock tight, so it was not coming off without brute force. Had to finally clamp screw nib into bench vice and then used a screw driver inserted through weight hole to turn entire weight till it came off all the way.
Now at 90 degree offset position to opposite side weight, it works perfectly as a shaker motor and doesn’t shake the table glass any longer, but keeps the fun effect of the shaker motor. I left the other side untouched. You could move it 90 degrees also, but then they’d be 180 degrees opposite of each other and diminish shaker effect too much.
I’ve included photos below to see exactly how I positioned weights and where screws were placed. Have fun adjusting! It would have been a simple process without the heavy dose of lock tight. It is worth the effort as now shaker motor adds to the experience instead of being too violent.
1032C38A-D7EE-4921-B847-8FC557C478DC (resized).jpegAF153104-855E-4FE5-BFD3-38877D0394A4 (resized).jpegDD6D38F1-5A73-413C-8805-3BB1DD6C0EA1 (resized).jpeg
