New! Dark mode!
(Topic ID: 271489)
Teenage Mutant Ninja Turtles Club(Stern 2020): Cowabunga! It’s Pizza Time!
By Tuxedomask23
4 months ago
  • 4,270 posts - Hot topic!
  • 384 Pinsiders participating
  • Latest reply 27 minutes ago by shaub
  • Topic is favorited by 172 Pinsiders
Topic poll
“Which model are you going to purchase”
  • Pro 148 votes
    46%
  • Premium 75 votes
    23%
  • LE 99 votes
    31%
(322 votes)
There have been 1,003 images uploaded to this topic. (View topic image gallery).
5 key posts have been marked in this topic (Show topic index)
There are 4270 posts in this topic. You are on page 74 of 86.
#3651 33 days ago
Quoted from bemmett:
Oh I'm too late, looks like it could be months and months.
Besides bending wireforms which is Tough, put one or 2 washers under the anchor point near the pizza parlour and the lair. This can slow the ball down just a hair. You could also bend the left wire in the wireform that attaches into the ramp near the backboard. This could also lift it slightly.
#3652 33 days ago
Quoted from gumnut01:
Also report it to stern.
#3653 33 days ago
Quoted from shaub:
Also for the multiballs,
NPMB: destroy 6 foot to light Mondo JP at the Krang Loop, collect Mondo to light double mondo, collect double Mondo to light triple Mondo JP. Double and Triple Mondo are lit on a timer. Collecting the 1st Mondo will also light Jackpoto Grande/Super JP at the LAIR Lane.
TPMB: 4 lit shots to light mondo, double/triple/super is the same as NPMB. Plus shoot the 4 turtle shots to light add-a-ball at the right ramp.
That's how I understand it.
I think this is correct, and if it’s not 100%, it’s almost entirely correct.
Also, I find in MB’s that the Krang loop is the hardest to hit. There’s just too much congestion in the middle and Krang is a tight shot anyways. Therefore I end up trying to hit a few other jackpots quick and then (skillfully) drain while ball save is on. This puts a bunch of balls back up top quick, a few of which will fall back through the Krang loop. Depending on what you’ve done before, you just got some of the Mondos or lit Max Krang at the center ramp.
Then with 2 balls on the left flipper you can backhand the Jackpoto Grande and cross that off the Cowabunga checklist as well.
#3654 32 days ago
Quoted from Aniraf:
Yeah, it worked perfectly until I removed that ramp to fix the diverter. Here is what is tripping me up, I can tell where they must plug in based on the first image. However, when I meter the connections I get 3.4v on the ground line!
Yeah, that's a weird one. Are you sure you didn't get something plugged in wrong?
#3655 32 days ago
Quoted from vireland:
Yeah…it took me half the day, but I found it. Honestly I can’t even believe I did, but I did. Basically what it comes down to is this tiny molex pin not being crimped correctly. I ended up running a lead from the ground strap to the pin and magically the switch started working again. I cut it off and put another pin on it and we’re all good. It is pretty impossible to see in there, but I think the primary lead does not have enough bare wire showing to make good contact.
Thank you for trying to help, this was an insane one. Maybe it was cut short to begin with and the simple motion of moving it retracted the wire into the sleeve. Who knows.
#3656 32 days ago
Quoted from Aniraf:
Congrats to you for finding it! You're probably right that removing it disturbed it just enough that it wasn't making contact in the pin anymore. Back to enjoying the game!
#3657 32 days ago
So I got my pro this weekend. Is there a way to combat the balls getting mangitiezed and not feeding correctly out from under the van for pizza multi ball? (Or releasing one ball at a time if playing 2 players) I got the game set on 7 degrees.
#3658 32 days ago
Quoted from Jon9508:
Are they stock balls? They shouldn't be getting magnetized. Some of the fancy pretty-boy balls will magnetize very quickly and are not recommended.
#3659 32 days ago
Yea factory balls. About 15 games on them.
#3660 32 days ago
Have you used a steel paperclip or compass to verify that the balls are indeed magnetized? That shouldn't have happened in 15 games with stock balls.
#3661 32 days ago
I haven't. Just watched them. They were all chained together. (3 or 4 balls) Had to shake the machine to get them to break loose. Maybe it was just a fluke.
10
#3662 32 days ago
Quoted from Thunderbird:
This should be a “game of the year” contender, but is a tough year going against AIQ as well.
TMNT is game of the year as far as I am concerned.
Rob
#3663 32 days ago
I'd do a magnetism check with a steel paperclip or compass, then.
Is your machine left to right leveled? Out of level can cause ball hangups.
#3664 32 days ago
Stock balls that come with games have been getting magnetized. We’ve been sending out replacements.
#3665 32 days ago
Thanks for the tips. I will do them in the am.
#3666 32 days ago
Quoted from FlipperFreak:
Wow, that's new for stock Stern balls, isn't it? I played almost 60 games while testing temps and never magnetized the balls on the TMNT Pro.
#3667 32 days ago
even my titan standards may be starting to magnetize. Just had two balls brought into the shooter lane today. Only once though so well see what happens.
#3668 32 days ago
Yes...it is something new. However, it’s not happening in all of the games we’ve sold. So, there must have been a batch of balls that weren’t carbon core. We’ve had no reports from LE owners. So far only with Pro’s.
#3669 32 days ago
Agree with vireland now. I just did the tape on the centre ramp optos. No point having another shield that I don’t need and could impact flow of ball. Thanks Pinmonk.
I did make a shield for the right ramp though as suggested by prodoshi. I changed it a bit though. Added a small spacer to the right post and attached there. Also used 0.8mm thick Flexible polycarbonate on a roll. Can cut it with industrial shears. And punch holes with leather punches. I think it looks ok. Hopefully doesn’t scratch or colour through the years. Much easier to work with than lexan. Even if this is not as good, could be useful for prototyping shields and getting measurements.
72572137-503C-49D6-A58B-4A959AFC8C5F (resized).jpeg9BBB6EB0-7063-4133-A52D-5F7E3EA47027 (resized).jpeg
#3670 32 days ago
The $64,000 question is...did it solve your missed ramp completions problem? If it did, it's 100% an opto issue, and it's good to have that confirmation (and the 1 cent per opto fix). If it did not, it's potentially a software timing issue for xaqery to look into.
-1
#3671 32 days ago
For the record I’ve been using the ninja chrome ball baron balls on my LE with no magnetism. I am actually surprised they have lasted this long and I have tested them weekly.
#3672 32 days ago
That was hands down one of the hardest things I have solved in pinball. I appreciate the encouragement as you know how much of a pain something like that can be on a perfectly new game.
14
#3673 31 days ago
Finished making these today finally.
20200920_130538 (resized).jpgIMG_20200920_130504 (resized).jpg20200920_130851 (resized).jpg20200920_130907 (resized).jpg
#3674 31 days ago
How do I get one?
Quoted from garretswinning:
#3675 31 days ago
I’m throwing money at my monitor but nothing is happening. How do I get one of these bad boys? So awesome!
#3676 31 days ago
Just a quick rule check. How do u start to requalify both multiball locks
#3677 31 days ago
Quoted from John1210:
After team up multiball both regular multiballs are relit to play again
#3678 31 days ago
Hit the ramps x times to start Turtle Multiball. I don't remember what x is, I think 3 or 4?
#3679 31 days ago
Quoted from post-hitter:
Ok interesting. So its a progressive set up not qualified by physical shots.
#3680 31 days ago
Yeah. So if somehow you're on your 4th episode and have only played Ninja Pizza MB, make sure to start Turtle Power. Or if you're playing Coop, go for both MBs quickly.
#3681 31 days ago
nice that you protect the plastic ramp. I noticed more stability of the ramp and less ratteling after installing the protector, but i also used thicker material (2mm), I can't tell if your soft material helps with that too.
#3682 31 days ago
Quoted from Prodoshi:
My first attempt failed. A flip on the fly usually resulted in a reject from the shield rather than the gate now. I went and studied your shield and studied and studied... and I noticed you did not attach the the top left screw that holds the left ramp protector. You skipped that and attached to the gate above it. This gives more headroom for the shield. I also wondered why is the Ball jumping? And I thought it may be the angle of the ramp is too steep. So I made 2 adjustments.
1) put rubber grommets under my shield at the top to lift it 3mm
2) I lifted the base of the ramp by .8mm by using some of my polycarbonate as a packer. This makes my connection point to the playfield slightly less steep and lessens the bend in the spring steel.
As of 2 games I can report ramp is much easier and I have not had a reject. Early days but I will let you know.
74F28EDF-E9F0-4122-B320-5F7C03E22EEA (resized).jpegA0C5D8FE-EEEA-437A-91A6-2C80F93C3817 (resized).jpegE7F19018-F850-4EF4-8A67-39576D654151 (resized).jpeg
EDIT: Put on 6 games with lots of multiballs, hitting right ramp now much smoother and no rejects. So packing ramp underneath and adding shield has solved the problem.
Also tape on optos has solved my centre ramp problems so far.
#3683 31 days ago
Okay now those are cool!!
#3684 31 days ago
yeah I didn't thought of back rolling balls at first and my protector stopped the switch this direction, so i cut the protector that the gate switch can pass.
I also saw that those rubber posts where much too low for the ball and didn't want to mess with those. I guess I was lucky with the first try
nice to hear it works for you too!
#3685 31 days ago
Thanks! Wouldn’t have solved it without your original post. You have been very helpful. Sad to see you leaving TMNT. I’m actually finding a lot less clunk and a lot more charm. I like the call outs now and I think the animations are really great.
#3686 31 days ago
This game seems to be getting overshadowed much sooner than usual for a new release but guessing bc of the soon after reveal of avengers which does look pretty good. However this is a really good game and I think many will be coming back to this one as soon as the avengers hype wears off once some le and pros start getting in people's hands. Tmnt lay out is very good and the game is very fast and flows well but the game is also pretty difficult bc of the speed ....especially the left outlane. Looks like whatever tmnt that are out there is all that will be for a while do to a big backlog of orders for stern. Seems if u want a new one it may be early next year before it's on the like again? Has anyone else heard this? I know there is very little stock available from distros and seems the price is high if u do find one? Anyhow I hope more people get to enjoy this really good game .
#3687 31 days ago
Just trying to understand the problem you guys are attempting to solve. So on your machines are you getting alot of rejects or airballs coming from the ramp entrance?
#3688 31 days ago
Are premium translites available to purchase anywhere?
#3690 30 days ago
Quoted from Pinstein:
Email Terry at Pinballlife.com. It should be less than $100.
#3691 30 days ago
Quoted from arcadenerd925:
in my case the balls got tangled up and hit the training sign. After that the ball was not able to get up the ramp anymore.
In other cases the ball got disturbed and flew out of the ramp after the Training sign.
in the picture is the version i did, the version Prodoshi did seems to be much better.
In my version there is the danger that balls hit the low lying protector and bounce back. With a higher entrance as in Prodoshis version this should not happen.
But since i but the Protector on, i don't think i had a ball hit front and got rejected.
The Airballs and hits to the Training Sign stopped almost completly
#3692 30 days ago
Quoted from cabal:
The Airballs and hits to the Training Sign stopped almost completly[quoted image][quoted image]
But why were you getting airballs there? Is your pizza wheel not level or even raised slightly to make a lip above the playfield? That will cause airballs.
#3693 30 days ago
It's the right ramp i had Problems with, it did not even go over the pizza for this ramp.
I think the ball jumped a little up and then got tangled in the flapping metal piece below the sign.
Sometimes it just hit hard again this piece and bounced back and sometimes it got through but behaved very weird.
And sometimes it bend the whole sign above it. I think it was jumping up and the ball was above the metal spinning thing and got caught in U-Form of it.
Now with the protector it seems to have the right height and just slides down below the sign without problems.
sorry i am not that good in explaining.
#3694 30 days ago
Quoted from Pinball-NJA:
How do I get one?
Quoted from acons017:
look for the thread Nuclear Lit Cupholder here on pinside
#3695 30 days ago
Quoted from cabal:
Ah, of course, the training sign should have made that obvious to me. It's weird you were having airballs there. I never had anything like that. Is your ramp flap flush with the playfield? Sometimes if the ramp is too tight, the flap will curl a little and raise up. It takes almost nothing to launch an airball, and that could do it.
#3696 30 days ago
New game code!
PRO V1.22 - September 20, 2020
Fixed:
- Removed a sound that happens during game over on the right outlane.
(from V1.21)
- Feature adjustment "FORCE DIFFERENT TURTLES" was not working correctly with
left flipper button. It will now remove turtles that have been selected.
- Cowabunga progress of a 2-player+ game was not being reset correctly.
- Fixed 48V messaging when coin door switch is open.
- Fixed font spacing on the timer in the UI
New:
- Added shaker motor effects for 123 and Weapon awards.
- Added pricing string to most of the attract mode pages.
Tweaked:
- Made the shaker motor not shake at the end of a pizza spin from a target
- APRIL and LAIR are now enabled after Final battle and Team up
- Reverted to the older "Ralpheal" call at the start of the game.
- Tweaked some of the EQ of some of the speech.
- Made the shaker motor more interesting at the start of Ninja Pizza
Multiball.
Moved to system 2.57 -
- Updated to nodeboard firmware v0.64.0
#3697 30 days ago
As I said I did 2 things. One was to create the shield, the other was to pack underneath the right ramp so the angle of ramp to playfield is slightly more obtuse. Before you could see a bend in the spring steel. Now you can’t. At least 5 or more pinsiders have reported the ball hitting the gate at the start of the ramp. It’s not from a cradle shot or a normal flip. It’s after a couple of loops where the ball is already travelling at maximum speed and then a flip to the ramp launches. It may just be the packer underneath that fixes it. But the shield also does offer extra rigidity to the ramp entrance.
#3698 30 days ago
Thanks for the explanation. I have not had any airball issues with that ramp, but at the same time, its rare I hit it while it whips around the orbit with much speed. Something I will keep an eye out for sure.
#3699 30 days ago
No probs, at least it's solvable. If you do find it happening, try a really thin packer under the ramp first to reduce the angle that the ball hits. This may stop the jump and you may not even require a shield.
#3700 30 days ago
Quoted from bigd1979:
I think a lot of people are playing this before it is dialed in. If it's too steep, they just say it's frustrating and does not shoot well. It also did not help that it was number 1 for a while. That causes a backlash. The theme also turns people off. After owning for a few months and ironing out my flow issues I think it is awesome. Top 100 position does not bother me too much, it can be next to Munsters on the list as long as we enjoy it!
Also think the code is pretty good. Wish people would stop bashing game coders, music and animation guys. This pin looks like it is pretty much finished now, there is heaps to do, it mixes things up. And the animations are great, just watch the rocksteady and bebop scene. They are excellent with the nunchucks twirling. And Slash is great as well.
EDIT: talk about frustrating, the right orbit is TIGHT!!!
10,750
Houston, TX
$ 349.95
Pin Stadium Pinball Mods
$ 58.00
Chrome Candy
Trade
Sale Pending!
Chapel Hill, NC
