Quoted from BaxterStockman:How are you adjusting the shaker? All the allen wrenches that I have that fit in the hole aren't strong enough to turn it at all. Or am I doing it wrong? Already looks like they're a little offset. But it sure makes a rattle when it goes off. Looking to tone it down a bit.
[quoted image][quoted image]
Found a torch screw that fit. It broke. [quoted image]
Those are not offset in your photos. Put heat on the screw to remove lock-tight from the screw to loosen it. This is what it looks like when you’ve set up properly by using either the 90 degree or the 180 degree settings. (See photos below)
Here was my experience which sounds similar to yours, lol.
Remove two top case screws. Then remove four bolts holding unit to table cabinet base.
Also tried using an Allen wrench, only to strip it. Attempted torque wrench and broke head. Wishing I hadn’t started this project, lol. Used Vise Grip Pliers to finally loosen 1/32nd screw nub. Destroyed screw nib getting it off. Purchased new screw and put it in the 90 degree angle hole to retighten. 90 degrees position offset it to the other side weight. Putting only a drop of lock tight on the screw before inserting.
Real issue with original screw is that it had tons of lock tight, so it was not coming off without brute force. Had to finally clamp screw nib into bench vice and then used a screw driver inserted through weight hole to turn entire weight till it came off all the way.
Now at 90 degree offset position to opposite side weight, it works perfectly as a shaker motor and doesn’t shake the table glass any longer, but keeps the fun effect of the shaker motor. I left the other side untouched. You could move it 90 degrees also, but then they’d be 180 degrees opposite of each other and diminish shaker effect too much.
I’ve included photos below to see exactly how I positioned weights and where screws were placed. Have fun adjusting! It would have been a simple process without the heavy dose of lock tight. It is worth the effort as now shaker motor adds to the experience instead of being too violent. If I had put heat on the lock-tight to begin with, would have avoided all the hassle.
