New Game Code !
LE/PREMIUM V1.52 - AUGUST 2, 2022
**** FIXED ****
- During the start of NINJA PIZZA MULTIBALL, the upper left flipper will be
raised based on the number of balls in the PARLOUR to try and catch more
balls on the PIZZA MAGNET.
- Fixed some TOTAL display effects where the score was fading off screen
too soon.
**** STERN INSIDER CONNECTED ****
- Home Team
The Home Team features allows Insider Connected players to log in
and play without scanning their QR code.
When the game is registered to a home location and set to Free Play,
Home Team can be enabled via Standard Adjust #51 or from Guided Setup.
Up to 8 players can be added to the Home Team from the Stern Insider
Connected Setup menu.
The Home Team can be shared across all games registered at the game's
location by enabling the Home Team Standard Adjustment on each game.
Players need only be added once to the Home Team. Players can be
later removed from the Home Team, and guests can be temporarily
added to the Home Team.
Find out more about Home Team at http://insider.sternpinball.com.
**** MOVED TO SYSTEM 3.20 ****
Updated to nodeboard firmware/protocol v1.00.0
Correct the replay score boost when Standard Adjustment REPLAY TYPE is set
to DYNAMIC. All REPLAY LEVELS for all players are potentially immediately
incremented instead of only replay level 1.
Correct Standard Adjustment FREE PLAY LIMIT. Previously this adjustment
would not be honored in all circumstances. FREE PLAY LIMIT sets the
maximum number of free games which a player can win during a game. Once
the FREE PLAY LIMIT is reached, a player will not receive a free game
a REPLAY level (if REPLAY AWARD is set to CREDIT)
a SPECIAL (if SPECIAL AWARD is set to CREDIT)
Grand Champion/High Score (if HIGH SCORE AWARD is set to CREDIT
a match (if MATCH AWARD is set to CREDIT)
The default setting for FREE PLAY LIMIT is 5 games (per player per game
played).
NOTE setting the FREE PLAY LIMIT to a value less than the number of REPLAY
LEVELS will decrease the number of REPLAY levels available.
Fix redundant sound effect when scanning into Insider Connected in some
instances.
Added Standard Audit "Total Power On Time". This is a lifetime audit of the
hours, minutes, seconds the machine has been powered on. This lifetime
audit will start accumulating with this update.
Added the ability to unregister a machine via the Stern Insider Connected
menu. A machine must be unregister from an Insider Connected account prior
to being added to a new account. Hilighting and selecting "Yes,
unregister this game." will unregister the game from your account.
Stern Insider Connect Setup Screens:
IP, network name, and WiFi signal strength displayed in top corners of
display.
Added Net->About->Events page
This page will display:
The current date and time
The date and time the game was recently powered on
The play count since powered on
The coin count since powered on
The paid credit count since powered on
The service credit count since powered on
The coin door open count since powered on
The tilt count since powered on
The date and time the game was previous powered on
The date and time the game was previous powered off
The lifetime power on count
Update the factory default value of "ALLOW LEFT+START TO END GAME" to "FREE
PLAY ONLY".
Update Install Competition: set "ALLOW LEFT+START TO END GAME" to "NEVER".
Added new Standard Adjustment "COIN ACCEPTOR" whose value can be
"MECHANICAL" or "ELECTRONIC", and default value is "MECHANICAL". This
adjustment is only available when the Country is set to Italy and Free Play
is set to No.
The coin door for Italy with a MECHANICAL acceptor is configured:
left coin switch: EUR 0.50
center coin switch: EUR 0.10
right coin switch: EUR 0.50
4th coin switch: EUR 0.10
5th coin switch: EUR 0
6th coin switch: EUR 0
The coin door for Italy with a Electronic acceptor is configured:
center coin switch: EUR 1.00
right coin switch: EUR 2.00
4th coin switch: EUR 0.20
Guided Setup
Added "Coin Acceptor" setting, only available when Country is set to Italy
and "Free Play" is No. Hide "Game Pricing" when "Free Play" is set to Yes.
Add translation strings for some top level selections.
Fix game reboot issue at power on with coin door interlock switch in the open
position.
Insider Connected attract mode screen updated to display the location name
and green check mark with a verified Location if the machine is registered
to a pro account.
