I'm putting my STTNG back together after "restoring" it. I'm having an issue with the lower right flipper not working when the right flipper button is pressed. The left flipper and upper right flipper work fine. The lower right flipper switch registers as working in the diagnostics as well as the EOS switch. I checked for power on the right flipper coil lugs and I have 51 volts on all three lugs like the left flipper coil. I also did the following per the pinrepair guides and the right flipper did work:
"With the game on and coin door closed, use an alligator clip and attach one end to ground. Now momentarily touch each metal tab of the Fliptronics' TIP102 transistors (*not* the TIP36). You should see a flipper react"
I have also reseated all connectors and ribbon cables and that didn't help either. What should I do next?
