I've been racking my brain for a couple weeks now trying to find out why my Hulk will boot up properly sometimes and other times it does something random at boot up like no 5 second delay and displays coming right on or kicking out the ball at boot up or random sounds.
I've re-capped and re-flowed the pins on the power supply and have proper output voltages to the CPU and the displays. Replaced the two caps near the power connection on the CPU. Measured 5.08 v and -12.13 v at the caps on the CPU. All ground mods have been done as well.
I remote mounted the battery. There was zero corrosion on the board. All the boards look super clean and all the connection contacts are nice and bright. I also re-pinned all the connectors.
Made sure both slam switches are closed and both tilt switches are open
Point of interest:
I have the Hulk out in the garage where I've been working on it. Now that the weather has been getting much cooler, I can go out first thing in the morning (maybe 55 degrees in the garage)and it will boot up properly every time I try
it. If I leave it on for a while it warms up and starts doing the random boot.
Once I get it to boot up properly everything works and plays like it should with the exception of the knocker and one display which I'll address later.
I carefully and slowly looked over every square inch of the CPU board (front and back) looking for any cold or cracked solder joints but everything just looks too good.
What am I missing? Any help would be greatly appreciated.
Mike
