If the AV board is bad, the game may still boot up but with no video or sound. the only indicator this happens is the lights in the playfield. You can see it enter attract mode. But since you unhooked everything, we cannot see that happen. You have strongly assumed your AV board is fine and refuse to move past that. It's not possible to help you in this case as no further debug data can be received. In order to fix a problem, it has to be debugged. You can't just shotgun fixes.
I have suggested several ways to move forward:
- put a "you say its working" av board with its roms swapped into the other working wpc95 game. You say your av boards are both fine. Then what's the problem? Prove it. I personally think the issues are in the AV boards. But there's no enough data to prove it for sure. Swapping boards into other systems proves it.
- hook up the rest of the connectors so we can see what's going on in the playfield
I will stop responding to this thread until something is done to gather more data. Good luck with your repair. Hope you figure it out.
