Trying to repair an Whitestar board for a South Park. The boards were originally from a High Roller Casino. Anyway, when everything was installed and fired up the CPU LED 200 would flicker, flash , stay on, go off. I/O board LED204 would just flash.
Found I had flakey 5v on the CPU. Put a new connector on at C2 , repaired a partially broken trace, and now I have perfect 5v and LED200 comes on solid , but the I/O LED204 is still flashing. It appears something in the watchdog circuit is causing this thing to go into a constant reset.
Have swapped I/O with a confirmed good one, same thing LED204 flashes on the confirmed good board
I have a good solid 5v going into the U210(DS1232) on the CPU at all times.
Ideas anyone?
